5D III RAW to DNG batch conversion
zerocool22
Hey,
I have a lot of 5D III RAW Files that I want to convert to dng. But I can not seem to find a simple tool to batch convert all my raw mlv files. I have seen that there is software that converts them in a batch like RAW2CNDG but they just export every file in the same folder, which means when I try to import the converted RAW video, it imports every video in one big file instead of 30 seperate files, which makes it very hard to edit.
What tool can you recommend (on windows 10). Or is there a option with RAW2CNDG?
Thanks!
Why would you do that? Use MLVFS if you want to work with your raw video files!
http://www.magiclantern.fm/forum/index.php?topic=13152.msg167826;topicseen#msg167826
Or use MLRawViewer for fast processing to folders
http://www.magiclantern.fm/forum/index.php?topic=9560.msg167870;topicseen#msg167870
Or use MLVProducer if you want to process lots of files together
http://www.magiclantern.fm/forum/index.php?topic=15271.0
You did not followed the magiclantern forums in the past 2 years do you? :)
edit: Probably you have a lot of raw_rec (raw 1.0) files, you have to dig a little in the forums, there is a way to convert them to MLV_Raw (raw2.0) and use MLVFS on them. With MLVFS you dont need any conversion, you can see your raw sequences in DNG-s
