NX lens for PilotFly H2
Herb
Hey omega1978,
Thanks! I totally forgot to respond to to your post. Question about the H2. How do you like it?
Lot's of people seem to be having issues with it. One user has ventured to say he thinks that the 4.9 lbs weight limit is not true. That it is more like half that since it uses the same motors as the Came-TV OPTIMUS which has a weight limit of 2.6lbs. I have the NX1 and I'm getting the 16-50 S lens. Combined with the battery, the weight appears to be 2.74 lbs. If the H2 weight limit is that of the Came Optimus, then I'm kinda worried. Thoughts?
hi,
i think the limit is the lens lenght, not weight.
if mechanical good balanced, the nx1+ 16-50s work fine for me.
i have test nx1+adapter nx-ef+rokinon 35/1.5 and works,maybe a bit front heavy.
the only problems are some microjitter and a horizont drift(can solved with firmware)
  • 1 month later...
