Super anamorphic project
Vladimir
On 8/24/2016 at 3:39 AM, ken said:
Hi, I just used two different 2x front and rear lens and got at least 2.8x ratio.  But looks like it needs much longer FL taking lens to use.
Can u try one element from physically short attachment and one element from much longer one?
Basically, I have figured out some rules.
Longer lens has less dioptre than shorter lens.  I got help from a friend in optical shop, where has instrument can check the lens.
These are rear lenses of different 2x anamorphic lenses:
    Sphere/Cyliner
A. +6.00/-6.00
B. +5.00/-5.00
C. +4.75/-4.75
D. +3.50/-3.50
Front lens should be like this:
E. 0/-13.75
F. 0/-10.50
Many front lens are too thick, the instrument was unable to check.  Also some front lenses I did not take apart.
For example, if B+F is original 2x lens, then A+F would get about 1.7X, C+F would get 2.2X, and D+F would get 2.7x.
  • 1 month later...
