Switching mods
NX1user
I successfully installed and used the KS mod in my NX1. I filmed 4K at 180mbps for 10 days of shooting an indy film. The only glitch was if I left my camera plugged into a monitor and powered the camera off, I would have to remove the HDMI cable whenI powered it back up or the camera would lock up. The only fix was to remove and re-insert the battery.
After filming wrapped, I thought I'd try the Vasile mod. I love the quick startup! Unfortunately, there's a problem right now where 1080 footage at any speed doesn't record at the bitrate I set. Depending on the FPS, it records at 40-60mbps. Vasile knows about the issue, but he's on vacation until August. I have some filming to do before then.
So, my question is "Is it safe to uninstall the Vasile mod and re-install the KS mod?" I just want to make sure that the "nx-on-wake" thing won't be a problem. I know Vasile says it's okay, but has anyone uninstalled it and installed the KS mod after?
Well, I successfully un-installed the vasile mod and installed the KS2 mod. Idiot me, somehow I missed that the KS@ mod doesn't do anything with bitrate! Why did he remove the bitrate part? So now I need to go back to NX1 1.4 (down from 1.41).
Anybody have link to a 1.4 download?
1 hour ago, sidi said:
Already posted in your DPR thread
Thanks a million!
1 hour ago, SMGJohn said:
KS2 mod does have bitrate, ou just gotta dig in the menu, look in settings or options. in KS2 mod menu
Oh, so it just changed location? I'll look again. Thanks.
  • 2 weeks later...
