M Carter Posted July 19, 2016 Share Posted July 19, 2016 So after searching all kinds of terms with google, reading a ton of threads here and on DP review... I still have no idea how to find and install the bitrate hack, what the risks are, and how to control it. I don't even have a clear idea of what additional things it adds, how much is improved, is it there for 4K and 1080 and slowmo, etc... Any way we could have a sticky thread here, that's just the latest hacks, where they are, what they do, and links to installers and usage instructions? We have some threads here with scores of pages running the gamut from settings to speedboosters, but it's hard to find just a basic and focused resource. Or is there a homepage somewhere with all-of-that? (I'm no Einstein but I manage to get dressed every morning and I'm still completely confused about upping my bitrate!) Link to comment Share on other sites More sharing options...
NX1user Posted July 19, 2016 Share Posted July 19, 2016 https://github.com/ottokiksmaler/nx500_nx1_modding I just discovered that the KS2 mod no longer mods bitrate, so if that's what you are interested in, us the vasile mod. Yes, there are two different mods. Link to comment Share on other sites More sharing options...
sidi Posted July 19, 2016 Share Posted July 19, 2016 1) download: https://github.com/ottokiksmaler/nx500_nx1_modding/blob/master/nx-on-wake/nx-on-wake.zip 2) follow HOW TO instructions precisely: https://github.com/ottokiksmaler/nx500_nx1_modding/tree/master/nx-on-wake 3) check if you get 2 long then 3 short green LED blinks after Power ON 4) download https://github.com/ottokiksmaler/nx500_nx1_modding/raw/master/nx-on-wake/nx-on-wake.zip 5) follow HOW TO - INSTALLATION: https://github.com/ottokiksmaler/nx500_nx1_modding/tree/master/video-bitrate-mods/nx-patch 6) Open/print/download this table so you know what bitrates to modify: TABLE 6) Read HOW TO - USAGE/FEATURES part: https://github.com/ottokiksmaler/nx500_nx1_modding/tree/master/video-bitrate-mods/nx-patch Link to comment Share on other sites More sharing options...
NX1user Posted July 19, 2016 Share Posted July 19, 2016 2 hours ago, NX1user said: https://github.com/ottokiksmaler/nx500_nx1_modding I just discovered that the KS2 mod no longer mods bitrate, so if that's what you are interested in, us the vasile mod. Yes, there are two different mods. Looks maybe I was wrong about the KS2 mod not having bitrate. IT just changed locations in the menu structure. I just downgraded my FW though, so I can't check at the moment. Link to comment Share on other sites More sharing options...
M Carter Posted July 21, 2016 Author Share Posted July 21, 2016 Thanks guys, I'll check it out. I assume I can't use the latest firmware though? haven't updated to it yet. Link to comment Share on other sites More sharing options...
sidi Posted July 22, 2016 Share Posted July 22, 2016 7 hours ago, M Carter said: Thanks guys, I'll check it out. I assume I can't use the latest firmware though? haven't updated to it yet. You can and actually have to on both on NX1 and NX500 (fw 1.41 and 1.12) - nx-patch Link to comment Share on other sites More sharing options...
NX1user Posted July 22, 2016 Share Posted July 22, 2016 Both mods work on 1.41. Link to comment Share on other sites More sharing options...
M Carter Posted July 24, 2016 Author Share Posted July 24, 2016 Wasn't there a recent release to fix the app performance that also killed the hacks? Link to comment Share on other sites More sharing options...
NX1user Posted July 24, 2016 Share Posted July 24, 2016 13 minutes ago, M Carter said: Wasn't there a recent release to fix the app performance that also killed the hacks? It stopped the hacks for a week or two, then they adjusted. Link to comment Share on other sites More sharing options...
M Carter Posted July 25, 2016 Author Share Posted July 25, 2016 That's good news, I'd like to be able to use the app on the crane. Link to comment Share on other sites More sharing options...
sandro Posted August 14, 2016 Share Posted August 14, 2016 I'm trying the BT hack. So basically when you set a bitrate the "current bitrate" this will applied to all the resolutions? Will it stick through reboots? I would like to set a bitrate for 4k and one for 60p and 120p, seems like "HD PRO" is for both fps? Link to comment Share on other sites More sharing options...
sandro Posted August 14, 2016 Share Posted August 14, 2016 OK so I tried to understand, if I set 150Mbit for "4K Pro" it applies to all 4K and FHD framerates. Is that correct? Link to comment Share on other sites More sharing options...
لطفي بوعكاز Posted August 14, 2016 Share Posted August 14, 2016 also it doesn't remember the settings, you need to apply the setting each time the camera turns on and off. Link to comment Share on other sites More sharing options...
iamoui Posted August 15, 2016 Share Posted August 15, 2016 Use @vasile's hack. Link to comment Share on other sites More sharing options...
sidi Posted August 15, 2016 Share Posted August 15, 2016 10 hours ago, iamoui said: Use @vasile's hack. Exactly. Than see my answers below. Answers below are only for vasile's NX-Patch! 19 hours ago, sandro said: I'm trying the BT hack. So basically when you set a bitrate the "current bitrate" this will applied to all the resolutions? Will it stick through reboots? I would like to set a bitrate for 4k and one for 60p and 120p, seems like "HD PRO" is for both fps? Bitrate slots will be applied according to this table 17 hours ago, sandro said: OK so I tried to understand, if I set 150Mbit for "4K Pro" it applies to all 4K and FHD framerates. Is that correct? Slot pro1 on NX1 is for all 4K, UHD and FHD* (*only when shooting over 30 fps) PRO quality setting (see table above). You can actually use hq1 or nq1 slot for a higher bitrate if you want to. 15 hours ago, لطفي بوعكاز said: also it doesn't remember the settings, you need to apply the setting each time the camera turns on and off. Use make persistent in NX-Patch menu to save bitrates to flash memory, this will make them persist between reboots. Otherwise they will only be kept until power off, then they will return to previous values. sandro 1 Link to comment Share on other sites More sharing options...
Drew Veeneman Posted November 29, 2016 Share Posted November 29, 2016 Not sure if anyone else is having this issue. I just got my NX1 today and am having trouble with the Kinoseed app. It seems to install ok, but never actually fires up. I check to make sure my Bluetooth is on, but that doesn't help. Ironically the Kinoseed hack works great on my NX500. It is easy to use and remembers bit-rates in between reboots. I'll have to try Vasile's method on the NX1. Bit rates and recording limits is all I care about. Link to comment Share on other sites More sharing options...
