DJI X5R arrived today - any requests?
Oliver Daniel
Something else I'm curious about, what if you wanted to shoot with a larger lens or a speedbooster and a big Nikon zoom? If the lens is on a tripod, can the X5r hang off the back or be rigged in some manner?
Just thinking aloud. There's a doc project I'm thinking about doing which would involve a lot of landscape and cityscape aerials, but when shooting on the ground I would want to use the same camera and not be limited to the 4 or 5 supported lenses.
Cheers.
Cheers.
I honestly don't think the X5R could take a Speedbooster and a bigger Nikon lens. There's no balancing at all. It's so tiny. Makes the BMMCC look huge.
I think anyone buying the X5R should do if they want an intuitive, quick and easy light setup with no bollocks - for the Osmo and Inspire.
The reason I got it is because I wanted a very high quality imaging device, with little setup, portable, light and intuitive to use.
I had the Ronin-M before. Used my A7SII. I loved the results but the gimbal is heavy after a couple of minutes. Monitor rigging is a pain. And the size of the package while transporting is a beast!
Move not had enough of a play yet. I feel it's something that will take a bit of time to get the best movement out of it. Like learning to ride and bike, and then doing wheelies and grinds.
1 hour ago, omega1978 said:
My workflow is to export premiere compatible cinema dng from cinelight, cut the proxys in CC and replace it with the RAW footage.it works very well
pw: omega
Thanks for sharing.
I think the Osmo X5R will probs need a well practiced Ninja walk to eliminate any walking bounce. Or a post stabiliser may help with that such as Coremelt Lock and Load.
I've heard there are plans to bring out a Z-axis for the X5 cameras - however I'd prefer not to have some bouncy spring thing as part of the rig.
Im working on getting the joystick movement nice and smooth. Feels a little abrupt on any of the factory settings.
