A vimeo 5x5
Snowfun
Thanks.
Yes, all realtime. Mix of 25/40k iso at 25fps (a7s, shogun, samyang 24mm).
The two on vimeo marked "javri" show most of the best display we had. One has the rapid, dancing movement (as in this 5x5), the other is a slow burner - the sky just gradually turns green. Biggest problem was with my "cheap" manfrotto head freezing so hence the jerky movement.  To be replaced by a Miller Airhead (ok to -40 apparently).
Sony found a niche market...
