Atomos finally released firmware update
Katrikura
After several months of Atoms announcement released the update to its atoms will, for low-end devices.
I own a Ninja Blade and these are the new features:
Ninja Blade 5.2 release notes FID: 050105200520
Features:
- Added AtomHDR monitoring including HDR waveform functions as outlined below
- HDR and Log to Rec.709 monitor modes. To access these settings, touch the new yellow "Monitor" button.
- HDR mode contains a slider to adjust the number of stops over SDR being displayed on the monitor.
- While in AtomHDR mode, a simplified HDR waveform line has been added to easily set the correct slider position for the dynamic range of the scene.
- HDR monitoring is supported for the Log output from the following cameras; Sony, Canon, Panasonic, Arri, JVC and Red. Bug Fixes:
- Fixed an issue where an extremely long recording could sometimes result in a corrupted file. - Add support for playback of 24-bit audio - Fixed an issue where some files exported from NLE's did not play audio.
During the weekend I will perform the update and see how things behave.
regards
Katrikura
