Devon Posted August 10, 2016 Share Posted August 10, 2016 When I shoot video in Slog-2, then switch to manual for stills, it seems that PP7 is affecting the color of those images. I am shooting RAW, and from what I thought, RAW files were data straight from the sensor. How is this happening? Link to comment Share on other sites More sharing options...
The Chris Posted August 10, 2016 Share Posted August 10, 2016 Yes, PP's have an impact on raws, the minimum Iso still applies and such. I can't remember if you're getting a 14-bit file either, but its been awhile since I tinkered with slog stills. I would only use it for quick stills in my videos, otherwise no PP when shooting stills. Dpreview talked about it with the RX100IV, and I've seen discussions elsewhere if you search: https://***URL removed***/reviews/sony-cybershot-dsc-rx100-iv/15 This is from Sony's help guide: Since the parameters are shared for movie and still images, adjust the value when you change the shooting mode. If you print RAW images with shooting settings, the following settings are not reflected. Black Level Black Gamma Knee Color Depth If you change [Gamma], the available ISO value range changes. There may be more noise in dark parts depending on the gamma settings. It may improve by setting the lens compensation to [Off]. When using S-Log2 gamma, the noise becomes more noticeable compared to when using other gammas. If the noise still is significant even after processing pictures, it may be improved by shooting with a brighter setting. However, the dynamic range becomes narrower accordingly when you shoot with a brighter setting. We recommend checking the picture in advance by test shooting when using S-log2. Setting [ITU709(800%)] or [S-Log2] may cause an error in the white balance custom setup. In that case, set the exposure bright first and then perform custom setup. Setting [ITU709(800%)] or [S-Log2] disables the [Black Level] setting. If you set [Slope] to +5 in [Manual Set], [Knee] is set to [Off]. S-Gamut is a color space unique to Sony that provides a wide color space equivalent to film cameras. However, S-Gamut setting of this camera does not support the whole color space of S-Gamut; it is a setting to realize a color reproduction equivalent to S-Gamut. Link to comment Share on other sites More sharing options...
Inazuma Posted August 10, 2016 Share Posted August 10, 2016 I have noticed this too. Quite bizarre. One interesting thing to note is that Fujifilm's cameras have a dynamic range setting, which when raised to maximum requires an ISO 800 exposure setting. When I had a Fuji I used to always use this maximum setting and I think I very rarely saw blown out highlights. The a6300's SLOG2 and 3 also require an ISO 800 and also handle highlights very well (at least in JPG/movies), not sure how exactly this affects raw. Link to comment Share on other sites More sharing options...
DPC Posted August 10, 2016 Share Posted August 10, 2016 Devon - settings affecting the actual quality of processed raw files or simply being reflected in the way the raw files look in camera? On my A7R II and RX10 II, PP settings are carried over from video to stills (which is a pain). You should, however, be able to subsequently process your raw still files to whatever look you want although when you first open them in your processing application they will, to a greater or lesser extent, reflect the camera's settings (as far as the software can interpret these). Link to comment Share on other sites More sharing options...
Dam Posted August 24, 2021 Share Posted August 24, 2021 Hi, since I have a big problem with my A6500, which is 'stuck' with Picture Profile (if I set PP Off the camera doesn't accept that setting and it is stuck with a modify PP8), how should I modify a picture profile to make it as the camera is set with PP Off (Gamma = still...?!?!)? Since I did not receive any effective solution by the Sony Support it is the only way to use my camera in manual mode dont' be affected (or partially) by what is a clear unfixed firmware bug. Thanks for your support. Best. Link to comment Share on other sites More sharing options...
