Timotheus Posted August 19, 2016 Share Posted August 19, 2016 Hi all, interested in hearing about mounting solutions for Iscorama 54 and/or Isco 16:9 Video Attachment. How do you keep it safe and (super)stable on 15mm rods? What type of support or lens collars do you use? I have one specific wish, as I would like to have the Isco secured to the rails without having to physically attach it to the taking lens. In this way I can remove the camera by it's cage handle for some lighter-weight shooting without the rail system. I already read through this older topic, but am looking for a more sturdy setup. Keen to hear your solutions, thanks! Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted August 19, 2016 Share Posted August 19, 2016 2 hours ago, Timotheus said: Hi all, interested in hearing about mounting solutions for Iscorama 54 and/or Isco 16:9 Video Attachment. How do you keep it safe and (super)stable on 15mm rods? What type of support or lens collars do you use? I have one specific wish, as I would like to have the Isco secured to the rails without having to physically attach it to the taking lens. In this way I can remove the camera by it's cage handle for some lighter-weight shooting without the rail system. I already read through this older topic, but am looking for a more sturdy setup. Keen to hear your solutions, thanks! Redstan has an adaptor which you attach to the back of the Iscorama54 & you can then mount it on rails. However, someone who bought one told me that it doesn't attach to the taking lens properly - so might not be a problem for you. http://www.redstan.com/index.php?route=product/product&path=33&product_id=63 Personally, I use a Zacuto lens mount that has a system to clamp it securely down, but I would never leave it like that without attaching it to a taking lens. The 54 weighs 1kg & you'll need something robust to keep it secure on rails - I just think that it's too heavy (& expensive) to have it free standing on its own. Safety first? Timotheus 1 Link to comment Share on other sites More sharing options...
Timotheus Posted August 19, 2016 Author Share Posted August 19, 2016 Thanks Bioskop for the tip on the redstan clamp. I would indeed prefer it that the Isco would have two secured support points. The redstan on the back, combined with a support on the front might do the trick. The circumference of the front is huge though, so it might be hard to find a solution that secures the lens all around. Perhaps some tie-wrap will come in handy ;-) Initially I was thinking of using the Lanparte lens support to go around some 77mm rings stacked on the back filter thread. This combined with a support up front. But the rubber might not be quite as up to the task as redstan's clamp... Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted August 20, 2016 Share Posted August 20, 2016 23 hours ago, Timotheus said: Thanks Bioskop for the tip on the redstan clamp. I would indeed prefer it that the Isco would have two secured support points. The redstan on the back, combined with a support on the front might do the trick. The circumference of the front is huge though, so it might be hard to find a solution that secures the lens all around. Perhaps some tie-wrap will come in handy ;-) Initially I was thinking of using the Lanparte lens support to go around some 77mm rings stacked on the back filter thread. This combined with a support up front. But the rubber might not be quite as up to the task as redstan's clamp... I use this, a lot more expensive than what I paid for it! (buying used Zacuto stuff, still means it has a lifetime guarantee): http://store.zacuto.com/lightweight-locking-lens-support/ I place it just after the 54's button that you use to align the lens, as there is space. The elastic on the Lanporte doesn't inspire too much confidence, but a quick google search found this - it looks like it is more secure & should fit the 54: https://cvp.com/index.php?t=product/vocas_0360-0500-01 Link to comment Share on other sites More sharing options...
Timotheus Posted August 21, 2016 Author Share Posted August 21, 2016 Holy crap 340 bucks for that Zacuto support! Thanks again for the tips, I'll keep an eye out for used gear as well ;-) Link to comment Share on other sites More sharing options...
