DBounce Posted August 28, 2016 Share Posted August 28, 2016 Here's some stuff I shot using the Canon 1DX MkII and the Sony A7ii as B-cam. I'm certain there are a million mistakes, and warp stabilizer is not the best. But then again, I'm no pro so you might have better luck with it. Overall I love the 1DX MkII... though it's not perfect. Interested to hear some feedback. Also used the Letus Helix Jr . This is the first stuff that I have shot so I'm open to constructive advice. Link to comment Share on other sites More sharing options...
Geoff CB Posted August 28, 2016 Share Posted August 28, 2016 Good audio but pull that camera back man. More like the shot a 2:28, the point of the video is to show the positions, and the close framing makes this hard to follow. Also add a second fill light. Link to comment Share on other sites More sharing options...
DBounce Posted August 28, 2016 Author Share Posted August 28, 2016 1 hour ago, Geoff CB said: Good audio but pull that camera back man. More like the shot a 2:28, the point of the video is to show the positions, and the close framing makes this hard to follow. Also add a second fill light. Good advice. I think you're right about wider shots. Second fill light? For the introduction? Link to comment Share on other sites More sharing options...
Fredrik Lyhne Posted August 28, 2016 Share Posted August 28, 2016 I agree with what Geoff said. Otherwise it looks good I think. If you're gonna make more videos like this I would check out CodyApp for inspiration. Like this one for example: https://www.codyapp.com/plans/true-strength-evolution?ref=soh_fp_all_4 I actually made a few yoga videos too and will be making more in a couple of months. It's nice to see how others are doing it so thanks for sharing! My videos are a bit simpler and with music instead, but maybe it's helpful to see something different? Have a look if you want: Juxx989 1 Link to comment Share on other sites More sharing options...
DBounce Posted August 28, 2016 Author Share Posted August 28, 2016 1 hour ago, Fredrik Lyhne said: I agree with what Geoff said. Otherwise it looks good I think. If you're gonna make more videos like this I would check out CodyApp for inspiration. Like this one for example: https://www.codyapp.com/plans/true-strength-evolution?ref=soh_fp_all_4 I actually made a few yoga videos too and will be making more in a couple of months. It's nice to see how others are doing it so thanks for sharing! My videos are a bit simpler and with music instead, but maybe it's helpful to see something different? Have a look if you want: Nice work!. Good angle and nice colors. Simple, but easy to follow. My problem is I like dynamic footage, so tend to shoot and edit that way. I think I'll start by filming the entire sequence stationary and then inter-cut the more dynamic shoots. BTW: Did you use two cameras? I used the Sony A7ii as a B-cam, and I won't lie, it was a b!tch to match colors. That problem has been plaguing me. Link to comment Share on other sites More sharing options...
Fredrik Lyhne Posted August 28, 2016 Share Posted August 28, 2016 42 minutes ago, DBounce said: Nice work!. Good angle and nice colors. Simple, but easy to follow. My problem is I like dynamic footage, so tend to shoot and edit that way. I think I'll start by filming the entire sequence stationary and then inter-cut the more dynamic shoots. BTW: Did you use two cameras? I used the Sony A7ii as a B-cam, and I won't lie, it was a b!tch to match colors. That problem has been plaguing me. Thanks! I did use two camera on this one, but I will only use one the next time and take two takes if we want more angles. That is obviously easier with out vocals... As you said, it's a pain to match different cameras and lenses and that's also why I will only use one camera the next time. The wide angle is a GH4 in 4K with 12-35mm X set to 12mm, and the close-up is the GH3 with 25mm Pana Leica. I liked the colors from the close-up angle the most so I tried to match the wide angle to that one and it worked out pretty good I think. I think you did a good job matching them btw and the stabilization looks nice too. I doubt your audience would notice. My video was shot with natural light but I do have 3 Fotodiox 1x1 LED's similar to LS. I think they work ok as fill lights in bright scenes, but in dark scenes like yours they need diffusers to soften and spread the light for more even distribution. I use a cheap 110 cm 5-1 reflector like this (the bigger the better) https://www.amazon.com/Neewer-43-inch-Collapsible-Multi-Disc-Reflector/dp/B002ZIMEMW In my experience it's really difficult to light scenes like yours, especially with just one light source. I'm no expert by any means, just sharing my experience. Link to comment Share on other sites More sharing options...
DBounce Posted August 28, 2016 Author Share Posted August 28, 2016 21 minutes ago, Fredrik Lyhne said: Thanks! I did use two camera on this one, but I will only use one the next time and take two takes if we want more angles. That is obviously easier with out vocals... As you said, it's a pain to match different cameras and lenses and that's also why I will only use one camera the next time. The wide angle is a GH4 in 4K with 12-35mm X set to 12mm, and the close-up is the GH3 with 25mm Pana Leica. I liked the colors from the close-up angle the most so I tried to match the wide angle to that one and it worked out pretty good I think. I think you did a good job matching them btw and the stabilization looks nice too. I doubt your audience would notice. My video was shot with natural light but I do have 3 Fotodiox 1x1 LED's similar to LS. I think they work ok as fill lights in bright scenes, but in dark scenes like yours they need diffusers to soften and spread the light for more even distribution. I use a cheap 110 cm 5-1 reflector like this (the bigger the better) https://www.amazon.com/Neewer-43-inch-Collapsible-Multi-Disc-Reflector/dp/B002ZIMEMW In my experience it's really difficult to light scenes like yours, especially with just one light source. I'm no expert by any means, just sharing my experience. GH4 looks pretty good in these shot. I think your angle sells it. Funny you mentioned the diffusers.... right after reviewing the raw footage we had the same thought. Below is a frame grab from the second episode that I am currently editing. The lighting is completely different as is the setting. I might move the subject a little closer to the wall next time around to get some back-lighting, or use a reflector to bounce some light from behind. I think the softer light is more complementary. And don't worry about not being an expert.... I'm here to learn also, and I value all constructive input. Fredrik Lyhne 1 Link to comment Share on other sites More sharing options...
Fredrik Lyhne Posted August 28, 2016 Share Posted August 28, 2016 Looks much better! Post the video in this thread when it's finished? Link to comment Share on other sites More sharing options...
DBounce Posted August 28, 2016 Author Share Posted August 28, 2016 Sure thing! That Sony is killing me though. I had planned to replace it with the 5DMkIV, but Canon went all "Canon" on it with that crazy crop. Not sure what to replace it with now. Maybe pickup a 1DC for cheap and use it as a b-cam? Or just shoot everything with one camera? Link to comment Share on other sites More sharing options...
mercer Posted August 29, 2016 Share Posted August 29, 2016 It looks good. My only suggestion is finding a different mic solution... Not because of audio quality, it sounds good, but because the wireless transmitter and lav wires running through her clothes makes her body look strange... Not flattering for yoga videos. Maybe try one of those necklace wireless microphones that they use on reality shows. http://neckmics.com/Neckmics/Home.html Link to comment Share on other sites More sharing options...
Fredrik Lyhne Posted August 29, 2016 Share Posted August 29, 2016 13 hours ago, DBounce said: Sure thing! That Sony is killing me though. I had planned to replace it with the 5DMkIV, but Canon went all "Canon" on it with that crazy crop. Not sure what to replace it with now. Maybe pickup a 1DC for cheap and use it as a b-cam? Or just shoot everything with one camera? Easy, wait a few months and get two GH5 Panasonic really stepped ut their color game with the GX85. But off course you won't get that Canon AF, but then again, neither does your Sony... Too bad Canon don't have a nice B-cam option for the 1DXii. 3 hours ago, mercer said: It looks good. My only suggestion is finding a different mic solution... Not because of audio quality, it sounds good, but because the wireless transmitter and lav wires running through her clothes makes her body look strange... Not flattering for yoga videos. Maybe try one of those necklace wireless microphones that they use on reality shows. http://neckmics.com/Neckmics/Home.html Doesn't that mic require an on-body wireless transmitter? Another option for audio that I've seen on lot's of yoga videos is to record the vocals later. Just let her do the practice and add vocals in post. Like this for example: Link to comment Share on other sites More sharing options...
mercer Posted August 29, 2016 Share Posted August 29, 2016 2 hours ago, Fredrik Lyhne said: Easy, wait a few months and get two GH5 Panasonic really stepped ut their color game with the GX85. But off course you won't get that Canon AF, but then again, neither does your Sony... Too bad Canon don't have a nice B-cam option for the 1DXii. Doesn't that mic require an on-body wireless transmitter? Another option for audio that I've seen on lot's of yoga videos is to record the vocals later. Just let her do the practice and add vocals in post. Like this for example: That's the mic they use on Naked and Afraid and I haven't noticed any wires or transmitters. Fredrik Lyhne 1 Link to comment Share on other sites More sharing options...
DBounce Posted August 29, 2016 Author Share Posted August 29, 2016 7 hours ago, mercer said: It looks good. My only suggestion is finding a different mic solution... Not because of audio quality, it sounds good, but because the wireless transmitter and lav wires running through her clothes makes her body look strange... Not flattering for yoga videos. Maybe try one of those necklace wireless microphones that they use on reality shows. http://neckmics.com/Neckmics/Home.html I've never seen this microphone. Interesting. 4 hours ago, Fredrik Lyhne said: Easy, wait a few months and get two GH5 Panasonic really stepped ut their color game with the GX85. But off course you won't get that Canon AF, but then again, neither does your Sony... Too bad Canon don't have a nice B-cam option for the 1DXii. Doesn't that mic require an on-body wireless transmitter? Another option for audio that I've seen on lot's of yoga videos is to record the vocals later. Just let her do the practice and add vocals in post. Like this for example: It's funny you mentioned the mic, we switched in the second video to voice over... the movement was causing noise. We also added the Sennheiser MKE2 AVX, for the talking scenes, which seems much cleaner than the Sony UWP-D11. Perhaps the biggest improvement we saw in audio was getting new noise cancelling headphones for monitor. Now I only hear what the microphone picks up. Anything that is polluting the input is immediately obvious. It's made a huge difference. As for the GH5, I'll have to see what it brings. I know many have high hopes for that camera. But then again many had high hopes for the 5DMKIV also. There are no official specs yet, so only time will tell. I would love for it to be amazing. Flying the 1DXMII is murderous on the back. Link to comment Share on other sites More sharing options...
Fredrik Lyhne Posted September 1, 2016 Share Posted September 1, 2016 Cool! Will be interesting to see the new video and hear your opinion on how the shoot was compared to the other one. Link to comment Share on other sites More sharing options...
Fredrik Lyhne Posted January 3, 2017 Share Posted January 3, 2017 I shot another yoga video with and this time with a lavalier. The language might be a little strange to some but it works pretty good I think. I had to shoot with the GH3 as I sold my GH4 when I got the GX85. Didn't think we had to wait this long for the GH5... Juxx989 1 Link to comment Share on other sites More sharing options...
