geppoitaly Posted August 28, 2016 Share Posted August 28, 2016 HI, but if i put a speedboster 0,64x to a gh2 "gilf" i have a a full frame for still and video ? if i rember Andrew says the crop fator to 1.86 then 1.86 * 0.64 = 1,1(9) etc.... i've done and NONE repeat NONE collision with internal filter ! NOOOOONE with mechanical shutter! ciao. Link to comment Share on other sites More sharing options...
Justin Bacle Posted August 29, 2016 Share Posted August 29, 2016 I'm pretty sure, the widest you can get on a m4/3 sensor is 2 * 0.64 = 1.28 (m4/3 sensor is 2x Crop minimum) But if the Speedbooster XL covers a bit more, would the JVC LS300 get closer to full frame ? (1.5*0.64 = 0.96) Very very very unlikely :o Link to comment Share on other sites More sharing options...
MattH Posted August 29, 2016 Share Posted August 29, 2016 Depends on how you calculate it. As you are aware, the GH2 has a multi aspect sensor. So it maintains a diagonal crop factor of 2 at every aspect ratio. So speaking in terms of stills, no, with the speedbooster XL you will get 1.28 crop factor at every aspect ratio in comparison to 3:2 ratio full frame (135 format). If, however, you are comparing with respect to a 16:9 crop of full frame then yes the video mode of the GH2 has a 1.91 crop factor, and thus with the speedbooster XL the crop factor will be 1.225 Whether this makes the GH2 more appealing if you don't already have one is another issue altogether. Link to comment Share on other sites More sharing options...
IronFilm Posted August 29, 2016 Share Posted August 29, 2016 But a GH5 with a multi aspect ratio sensor and a crop ratio of x1.2 would be interesting indeed! Link to comment Share on other sites More sharing options...
geppoitaly Posted August 30, 2016 Author Share Posted August 30, 2016 thank you for reply but this is the experiment. sigma 10-20 shoting photo 4:3 with same speedboster (x0,71), add lenshood, on gh2 vignetting (lens hod in photo) in gh4 no lens hood, then differen cropo factor right? and with 0,64 more lenshood, forcing my x0,58 bmpcc hacked adapter without block on camera socket more lens hood. Link to comment Share on other sites More sharing options...
johnnymossville Posted August 30, 2016 Share Posted August 30, 2016 I've been wondering the same thing. I keep my GH2 around for it's 1.86 crop and it's superb image quality. I haven't seen anyone try the wide speed booster on it. Link to comment Share on other sites More sharing options...
geppoitaly Posted August 31, 2016 Author Share Posted August 31, 2016 try works. safe until 0.64x Link to comment Share on other sites More sharing options...
