Dan Wake Posted August 28, 2016 Share Posted August 28, 2016 I wish to know if does exist a camera that allow all those fetures please 1) 100% no moire and aliasing (that cyan and magenta false colors, wall bricks goes crazy) and (glitter effect arounf the fur of the animals, the telephone cables). 2) no vertical stripes. (example below) 3) acceptable low light ISO. 5) affordable price. 6) raw video thx! Link to comment Share on other sites More sharing options...
Sinjun Balabanoff Posted August 28, 2016 Share Posted August 28, 2016 5d Mk. III Magic Lantern Dan Wake 1 Link to comment Share on other sites More sharing options...
Dan Wake Posted August 28, 2016 Author Share Posted August 28, 2016 1 hour ago, Sinjun Balabanoff said: 5d Mk. III Magic Lantern Thanks Sinjun, I have a canon 7D with ML and I wish to try something different. Could you suggest me an alternative please? thx! Link to comment Share on other sites More sharing options...
dhessel Posted August 28, 2016 Share Posted August 28, 2016 Sony FS5, not sure what you consider affordable. Dan Wake 1 Link to comment Share on other sites More sharing options...
dhessel Posted August 29, 2016 Share Posted August 29, 2016 Anything cheaper and you will have to give up something on your list. Dan Wake 1 Link to comment Share on other sites More sharing options...
TheRenaissanceMan Posted August 29, 2016 Share Posted August 29, 2016 Kinemini? Dan Wake 1 Link to comment Share on other sites More sharing options...
IronFilm Posted August 29, 2016 Share Posted August 29, 2016 1 hour ago, Dan Wake said: Thanks Sinjun, I have a canon 7D with ML and I wish to try something different. Could you suggest me an alternative please? thx! 7D with ML raw is shit. 5Dmk3 with ML raw is great. I'd also suggest BMMCC or secondhand BMPCC. Or maybe even BMCC MFT if you don't care about the weight. FS5 / KineMINI / Terra / UM4.6K / FS700 / etc are all good as well if your budget stretches up that high. Dan Wake 1 Link to comment Share on other sites More sharing options...
Dan Wake Posted August 29, 2016 Author Share Posted August 29, 2016 2 minutes ago, IronFilm said: 7D with ML raw is shit. 5Dmk3 with ML raw is great. I'd also suggest BMMCC or secondhand BMPCC. Or maybe even BMCC MFT if you don't care about the weight. FS5 / KineMINI / Terra / UM4.6K / FS700 / etc are all good as well if your budget stretches up that high. what about 7D + vaf filter? I'm thinking about it and I'm searching a used one. I also opened a topic in the "gear for sale" section. thx! Link to comment Share on other sites More sharing options...
IronFilm Posted August 29, 2016 Share Posted August 29, 2016 2 hours ago, Dan Wake said: what about 7D + vaf filter? I'm thinking about it and I'm searching a used one. I also opened a topic in the "gear for sale" section. thx! The big big BIG problem is the 7D uses SD cards. And Canon pinches pennies by putting in the cheapest shittest SD controllers into their cameras. So ML raw is crippled. Unless... you use CF cards. Such as the 5Dmk3 uses. Link to comment Share on other sites More sharing options...
mkabi Posted August 29, 2016 Share Posted August 29, 2016 17 minutes ago, IronFilm said: The big big BIG problem is the 7D uses SD cards. And Canon pinches pennies by putting in the cheapest shittest SD controllers into their cameras. So ML raw is crippled. Unless... you use CF cards. Such as the 5Dmk3 uses. Correction, 7D uses CF cards. And... From what I know about ML on 7D... With 5X zoom... It can do 2.5K Link to comment Share on other sites More sharing options...
IronFilm Posted August 29, 2016 Share Posted August 29, 2016 Ah my bad, it does have CF. Dug a little bit more into it, 7D isn't quite as bad as I might have thought with ML raw, still quite bad though. Certainly couldn't do 2.5K raw continuous. You'll need a much lower resolution. And 5x crop is a hell of a crop to have to deal with! And you can run into other issues too so you need to double check stuff. Not a camera I'd want to use in a production environment. 5Dmk3 ML raw or BMMCC is still streets ahead of it. Link to comment Share on other sites More sharing options...
Dan Wake Posted September 10, 2016 Author Share Posted September 10, 2016 a friend of mine say that he wants to buy Ursa mini. I wish to ask you if it suffer from moire, aliasing, and vertical sripes/banding please. I know it does not record raw video for now but he is ok for prores. thx Link to comment Share on other sites More sharing options...
dhessel Posted September 11, 2016 Share Posted September 11, 2016 which version 4k or 4.6k? Both record raw video btw. Both suffer from fpn especially the 4k. You have to light well and cannot go over 400 ISO with fpn on the 4k, 4.6k is better and can be used at 800 ISO and maybe 1600 ISO but fpn might start to show. The 4.6k is suffering from magenta cast issues and neither has a olpf so moire and aliasing could be an issue. Note these comments are anecdotal since I have personally used neither. Dan Wake 1 Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted September 11, 2016 Super Members Share Posted September 11, 2016 5 hours ago, dhessel said: which version 4k or 4.6k? Both record raw video btw. Both suffer from fpn especially the 4k. You have to light well and cannot go over 400 ISO with fpn on the 4k, 4.6k is better and can be used at 800 ISO and maybe 1600 ISO but fpn might start to show. The 4.6k is suffering from magenta cast issues and neither has a olpf so moire and aliasing could be an issue. Note these comments are anecdotal since I have personally used neither. The bmpc4k is pretty much moire free so I imagine the ursa mini 4k is as well. Link to comment Share on other sites More sharing options...
Lintelfilm Posted September 11, 2016 Share Posted September 11, 2016 Why do you want RAW? There are many cameras now that offer better native, non RAW image quality than the 7D ML RAW. And are much easier to use. Link to comment Share on other sites More sharing options...
Dan Wake Posted September 13, 2016 Author Share Posted September 13, 2016 On 11/9/2016 at 2:58 AM, dhessel said: which version 4k or 4.6k? Both record raw video btw. Both suffer from fpn especially the 4k. You have to light well and cannot go over 400 ISO with fpn on the 4k, 4.6k is better and can be used at 800 ISO and maybe 1600 ISO but fpn might start to show. The 4.6k is suffering from magenta cast issues and neither has a olpf so moire and aliasing could be an issue. Note these comments are anecdotal since I have personally used neither. it's the 4,6k. may you tell me more about the magenta cast issue please? isn't something that can be fixed with a firmware update on camera? is it a serious problem? for the same price does exist a better aletranive to ursa 4,6k? thx Link to comment Share on other sites More sharing options...
tweak Posted September 13, 2016 Share Posted September 13, 2016 On 29 August 2016 at 7:12 AM, IronFilm said: Ah my bad, it does have CF. Dug a little bit more into it, 7D isn't quite as bad as I might have thought with ML raw, still quite bad though. Certainly couldn't do 2.5K raw continuous. You'll need a much lower resolution. And 5x crop is a hell of a crop to have to deal with! And you can run into other issues too so you need to double check stuff. Not a camera I'd want to use in a production environment. 5Dmk3 ML raw or BMMCC is still streets ahead of it. So basically what you should have said is you have no idea. Why give advice if you don't really know? You can shoot full sensor at just under 1080p and upscale nicely. For the price 7D is a very capable Raw camera and can be intercut with 5d3 raw quite well on shoots (You couldn't tell the difference in an edit, I've seen people do it many times before). BMMCC is certainly a better camera to rely on than both 7D and 5D3 and has far less lag time between pushing the record button and the camera recording etc. It's these small nuances that can make ML harder to shoot with on a paid gig, but if you can deal with it and shoot around those MLRaw is very capable still. On 11 September 2016 at 10:30 AM, Lintelfilm said: There are many cameras now that offer better native, non RAW image quality than the 7D ML RAW. And are much easier to use. Like what? Rattle some names off if you know of some around the same price. Link to comment Share on other sites More sharing options...
dhessel Posted September 13, 2016 Share Posted September 13, 2016 26 minutes ago, Dan Wake said: it's the 4,6k. may you tell me more about the magenta cast issue please? isn't something that can be fixed with a firmware update on camera? is it a serious problem? for the same price does exist a better aletranive to ursa 4,6k? thx they are trying to fix it via a firmware update. It is non uniform affecting the right side and corners more than the center. The magenta varies by lens, focal length and f stop so it is not easy to grade out. I would expect this will make it difficult to fix via firmware but I cant say. It can be minimal or quite severe and I have heard of people having to rma 3 cameras before getting an acceptable one so in my opinion it is a big issue. There are not many alternatives though. Sony fs5 or fs7 maybe? Or perhaps an older red camera, these are all assuming you are wanting a raw shooting camera. Dan Wake 1 Link to comment Share on other sites More sharing options...
Dan Wake Posted September 13, 2016 Author Share Posted September 13, 2016 1 hour ago, dhessel said: they are trying to fix it via a firmware update. It is non uniform affecting the right side and corners more than the center. The magenta varies by lens, focal length and f stop so it is not easy to grade out. I would expect this will make it difficult to fix via firmware but I cant say. It can be minimal or quite severe and I have heard of people having to rma 3 cameras before getting an acceptable one so in my opinion it is a big issue. There are not many alternatives though. Sony fs5 or fs7 maybe? Or perhaps an older red camera, these are all assuming you are wanting a raw shooting camera. this video say magenta it's gone/non issue. may I ask you if you agree after watching it please? Link to comment Share on other sites More sharing options...
dhessel Posted September 13, 2016 Share Posted September 13, 2016 depends on the camera, it varies. The magenta cast is nothing easily graded away the magenta corners is a different issue. I think the magenta is a problem and BM has acknowledged it is and a working on a fix. Link to comment Share on other sites More sharing options...
