geppoitaly Posted August 31, 2016 Share Posted August 31, 2016 hi what the proportion for 4:3? 1.33x1.33x1.33 ? and why if i put 2.40:1 proportion the footage seems too high? are the adapters not 1.33x ? slr magic and ag la 7200 and why if i cross the adapters the image is perfect and as frontal speedbooster not like wide adapters? p.s. i can autofocus on camera with this adapters. Link to comment Share on other sites More sharing options...
Brian Caldwell Posted August 31, 2016 Share Posted August 31, 2016 4 hours ago, geppoitaly said: hi what the proportion for 4:3? 1.33x1.33x1.33 ? and why if i put 2.40:1 proportion the footage seems too high? are the adapters not 1.33x ? slr magic and ag la 7200 and why if i cross the adapters the image is perfect and as frontal speedbooster not like wide adapters? p.s. i can autofocus on camera with this adapters. Stacking two 1.33x anamorphic adapters will result in a 1.77x anamorphic adapter. This is close to the ideal squeeze of 1.79x that you would want to convert 4:3 to 2.39:1 . A Speed Booster will shorten the focal length. geppoitaly 1 Link to comment Share on other sites More sharing options...
geppoitaly Posted August 31, 2016 Author Share Posted August 31, 2016 thank you mr caldwell, then the formula is right... 1.33x1.33x1.33 why i must compress more vertical image after 2,40:1 in potplayer (not real 1.33x adapter ratios ?) ? and yes i know/have your speed booster (shorten....) but why if i cross and not stack (+) two anamorphic adapter the image is perfectly 4:3 but is more crisp than a wide angle adapter? why no one make dual anamorphic adapter with single focus? if i stack slr magic with isco anamorphot the image is more sharp and i don't lose autofocus ! why ? thank you in advance Link to comment Share on other sites More sharing options...
