Liam Posted September 12, 2016 Share Posted September 12, 2016 11 hours ago, Asmundma said: Did you test against a standard Canon picture profiles? As shown here, the highlights are burned and the value of the c-log is questionable. Still to see if we can squeeze more dynamic range out of it. Actually, you may lose color information. i.e. if you want vivid colors. Makes sense as a concern. I thought the dynamic range was identical to prolost flat on my t3i. But clog was better for colors when grading, and it's definitely looking better for LUTs too. Regardless, the cine picture profiles and LUTs are easily worth $10.. Souto 1 Link to comment Share on other sites More sharing options...
mercer Posted September 12, 2016 Share Posted September 12, 2016 Some 50D Raw with Cine LUT 3. Without... With Cine LUT 3... iamoui 1 Link to comment Share on other sites More sharing options...
Jed I. Clampett Posted September 13, 2016 Share Posted September 13, 2016 I am screwed, Andrew posted that you can upload the files via usb with the Canon software, which I do not have, since my cd got corrupted and virtually impossible to get from Canon again, have tried several times. Link to comment Share on other sites More sharing options...
mercer Posted September 13, 2016 Share Posted September 13, 2016 20 minutes ago, Jed I. Clampett said: I am screwed, Andrew posted that you can upload the files via usb with the Canon software, which I do not have, since my cd got corrupted and virtually impossible to get from Canon again, have tried several times. https://www.usa.canon.com/internet/portal/us/home/support/self-help-center/eos-utility/ Link to comment Share on other sites More sharing options...
dvcrn Posted September 13, 2016 Share Posted September 13, 2016 Is competition allowed? James Miller just released his take on a C-Log profile here https://sellfy.com/p/ul1t/ Thoughts? Link to comment Share on other sites More sharing options...
FRD Posted September 13, 2016 Share Posted September 13, 2016 20 hours ago, alvinlu said: screen grab of something I shot today at my friend's bbq. I didn't check for exposure nor white balance prior so color correction was more of a pain since I had to use some reference of what I remembered seeing that day. Then added a m31 lut from vision-color. Gear Used; Canon 60D Sigma 18-35 F/1.8 SLR Magic Variable ND MKII 82mm I purchased it last week and I'm very happy! I love the resutl in skin tones!! @Andrew Reid Thank you very much!! @alvinlu This is your same screen grab with my color corrections Link to comment Share on other sites More sharing options...
Kaspars Balamovskis Posted September 13, 2016 Share Posted September 13, 2016 ML zebras is not working with clog. (5d3) Link to comment Share on other sites More sharing options...
gdims Posted September 13, 2016 Share Posted September 13, 2016 As I posted before, make sure you change the threshold of ML Zebras to 92-93% and it will work just fine. C-LOG clips the highlights above the brightness level of 235 of 255. Link to comment Share on other sites More sharing options...
Sa5m Posted September 13, 2016 Share Posted September 13, 2016 Here are my initial tests with C-LOG on my Canon 600D (without Magic Lantern). All shots taken with Yashica 50mm f/1.7 and graded in Sony Vegas Movie Studio 13 (no LUTS used) https://youtu.be/YcoAQyd4rfM Link to comment Share on other sites More sharing options...
tomsemiterrific Posted September 14, 2016 Share Posted September 14, 2016 Just posted this today. Footage a bit rough--but no grading here, just minor exposure adjustments to make corrections the best I know how. Rough shooting because of harsh sunlight going in and out with frequency. But I wanted to see how good the colors and footage would be out of the camera. mercer and Souto 2 Link to comment Share on other sites More sharing options...
Dustin Tolman Posted September 15, 2016 Share Posted September 15, 2016 I finally go to take this beast out into the wild. I'm most amazed with the autofocus capabilities, coupled with the EOSHD.com C-LOG picture profile. I ran the cam on my DJI Ronin-m with a 50mm at F1.2... Just for this, I may consider adding the mkIV to my bag. If the DR was just a little bit better, I'd be completely sold. Cam Settings - 1080/60p - EOS HD CLOG Picture Profile - 125 Shutter - F1.2 - Tiffen Variable ND Filter - DJI Ronin-M - Graded with FCPX Color Finale + EOS HD Cine Lut iamoui, tomsemiterrific and Souto 3 Link to comment Share on other sites More sharing options...
Asmundma Posted September 15, 2016 Share Posted September 15, 2016 Did a revisit on my grading of the clips easier in this tread. I did not clip the highlights and was wondering if the colour information still was in the clips. By not using any LUT only grading, but now used the vector based grading in Colour Finale (the last clips), I was able to recover more then in versjon 1. I not sure at all if we get any more dynamic range using the clog picture style vs the standard - too me it looks the same. So when using clog or similar may only help if you want to adjust to another camera - as it may be easier to get the same look, or if one want a special look it may pay off to use the logs. (as you reduce the sharpening and saturation.) Souto 1 Link to comment Share on other sites More sharing options...
mercer Posted September 16, 2016 Share Posted September 16, 2016 If you have a Japanese model eos-m (I suppose it's Grey Market) can you load these picture profiles using an English version of EOS Utility? Link to comment Share on other sites More sharing options...
tweak Posted September 16, 2016 Share Posted September 16, 2016 1 hour ago, mercer said: If you have a Japanese model eos-m (I suppose it's Grey Market) can you load these picture profiles using an English version of EOS Utility? I think so. mercer 1 Link to comment Share on other sites More sharing options...
mercer Posted September 16, 2016 Share Posted September 16, 2016 47 minutes ago, tweak said: I think so. Thanks, I hope so. I want to do some tests before I decide on my next camera purchase. I love the XC10, but I really need a larger sensor camera for close ups. After seeing footage shot with the 80D and seeing the high bitrate video specs, I was hoping the M5 would share the video specs of the 80D, since it shares the same sensor. But with Canon being Canon, that isn't the case. So it looks like I may be going with the 80D, but I want to do some tests with a cheaper cam to see if I can get the two cameras looking similar with Andrew's profile before I buy the 80D. Link to comment Share on other sites More sharing options...
tweak Posted September 16, 2016 Share Posted September 16, 2016 My 7D did pretty well, I will test my eosm when in a month or so. mercer 1 Link to comment Share on other sites More sharing options...
Kromofone Posted September 17, 2016 Share Posted September 17, 2016 Hey! I recently shot a fashion event with a 7D mkII and a 60D and used your C-log pack! Here is a quick comparison of c-log ungraded and then graded with CINE 2 LUT (with a bit of tweaking). More screengrabs to come when I finish grading & editing. I'll also post a link when the vid will go public. For now not finished yet. tomsemiterrific and alvinlu 2 Link to comment Share on other sites More sharing options...
voyagervideo Posted September 18, 2016 Share Posted September 18, 2016 I gotta say, I'm not sure if it's the Log emulation or Andrew's LUTs (probably the latter) but it really looks like the net effect here is converting Canon color to something that looks more Sony-ish: low-contrast & desaturated (because you can't make the 8-bit flat colors 'pop', and odd brick-color skintones (def the lut). austinchimp 1 Link to comment Share on other sites More sharing options...
Asmundma Posted September 18, 2016 Share Posted September 18, 2016 3 hours ago, voyagervideo said: I gotta say, I'm not sure if it's the Log emulation or Andrew's LUTs (probably the latter) but it really looks like the net effect here is converting Canon color to something that looks more Sony-ish: low-contrast & desaturated (because you can't make the 8-bit flat colors 'pop', and odd brick-color skintones (def the lut). You probably right. If you want to preserve Canon color stay with the regular picture styles. I have now tested for a week on the 1dx2 and must say I really like what I get out of the 1dx2 (no reason to destroy with a "clog" profile that does not improve the dynamic range), better then my A7x2 at the cost of 5 times files size. Only 10% to save by converting to ProRes so that not a good idea. Link to comment Share on other sites More sharing options...
mercer Posted September 18, 2016 Share Posted September 18, 2016 35 minutes ago, Asmundma said: You probably right. If you want to preserve Canon color stay with the regular picture styles. I have now tested for a week on the 1dx2 and must say I really like what I get out of the 1dx2 (no reason to destroy with a "clog" profile that does not improve the dynamic range), better then my A7x2 at the cost of 5 times files size. Only 10% to save by converting to ProRes so that not a good idea. 10% is a lot plus ProRes is a great intermediate codec. If you're using a Mac with EditReady, there are so many other benefits to transcoding the footage to ProRes before you bring it into your NLE. Also, I haven't used Andrew's C-Log yet, but we must remember the Canon's are still limited for their grading. I believe you will get some more shadow and highlight info, but you still want to get your exposure and WB pretty spot on in camera. And you definitely do not want to ETTR with them... if anything you may get better results underexposing a hair and bringing it up in post. Link to comment Share on other sites More sharing options...
