How to remove Chromatic Abberation in video
rs3d
With stills this is easy in Lightroom, but which software supports removal of Chromatic Abberation in video?
In 4K this is quite visible, especially with manual lenses that are not recognized by the internal camera body correction...
By chromatic aberration do you mean real chromatic aberration or light scattering on the beyer filter? Both are commonly referred to as CA, even though only one is.
The only cure of light scattering on the sensor is to use a larger sensor with a relatively low pixel density.
If you import a .dng sequence into ACR, you can use the chromatic aberration correction sliders to suppress and often eliminate CA from footage. Works great with .dng files from converted Magic lantern raw or MLV files...might also work with other footage that has been converted into a .dng image sequence (but I have never tried to see how effective or not that would be).
