Diffusing Aputure Amaran hr672 lights? Umbrella? Octobox?
dvcrn
Hi guys!
I own 2 Amaran hr672 lights (one wide, one spot) and love them! But even with the gels, I found them a little too harsh.
I am looking for a cheap way to diffuse the lights to make them usable indoors. I saw the Aputure EX-box kit but didn't read good things about it, plus the size of the box seems like it won't really do much.
I checked a bit and thought I could maybe shine them through a cheap umbrella, or use some sort of octobox but I have no experience with either option.
I am using the HR672's in the HR672s (spot with 25 degree beam angle) and the HR672w (wide with 75 degree beam angle). If you have any tips for a beginner, please share!
Is anyone using HR672's here? If yes, how do you diffuse the lights?
50 minutes ago, dvcrn said:
Hi guys!
I am looking for a good softbox that I can put on top of them to diffuse the light a little. I saw the Aputure EX-box kit but didn't read good things about it, plus the size of the box seems like it won't really do much.
Look up the D-Fuse softbox solution. I believe they make an aputure-specific softbox
edit: https://www.bhphotovideo.com/c/product/1258826-REG/d_fuse_df_amaran_d_fuse_collapsable_softbox_for.html
The D-Fuse softboxes are great.  I own a 672s and the D-Fuse.  It will help, but it won't be a truly wraparound kind of softness since the size of the softbox is really not that big.  If your subject can handle the light getting in real close, then it will be better.
In general, I don't find the power of the 672s to be enough for a key in a lot of situations once you diffuse/soften it.  It makes for a fantastic hair light, great for background, and in some situations a good key.
I am thinking that I need an LS1s or something similar to be able to soften enough (need to light up enough surface area of a larger source...softbox, diffusion panel/scrim, etc) and still have enough punch to deal with a variety of situations, backgrounds, practicals, and/or distance needed from subject to avoid making them feel uncomfortable and still get foreground/background ratios to sit right.
But yes, the D-Fuse are great, and crazy inexpensive.  Portability and speed to set up is also really great.
I did some more research yesterday and saw that the HR672 included mount comes with a drilled hole for umbrellas! How did I never see this?
Now I'm wondering if a umbrella for some indoor lighting setup (with limited space) might actually be a viable option. I did my homework on umbrella differences but quickly found myself in shoot-through vs silver reflective vs white reflective battles and am more confused now than I was in the beginning. Most resources available focus on photography where the shoot-through umbrella for example is very very close to the source which is most of the time not possible on videos.
Reflective silver umbrellas seem to make sense. A good amount of light is reflected because of the surface, and more directional than shoot-through.
Anyone here experienced with umbrellas for videos? Would love to hear your thoughts!
