norliss Posted October 20, 2016 Share Posted October 20, 2016 Interesting vid from Dave Dugdale and Matt Scott. I have a feeling Matt's comments and conclusions will wind up a few people here Cas1 and Davey 2 Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted October 20, 2016 Super Members Share Posted October 20, 2016 2 hours ago, norliss said: Interesting vid from Dave Dugdale and Matt Scott. I have a feeling Matt's comments and conclusions will wind up a few people here Could you summarize? Started watching but almost 30min... Justin Bacle 1 Link to comment Share on other sites More sharing options...
Cas1 Posted October 20, 2016 Share Posted October 20, 2016 Matt is checking out the banding in the highlights, but I noticed the lack of detail is much more severe in the shadows, due to compression. It is interesting to see how much compression and bit depth does to an image. Link to comment Share on other sites More sharing options...
no_connection Posted October 20, 2016 Share Posted October 20, 2016 The problem isn't as much 8bit vs 10bit I think but the effort put into compressing the data. Good compression takes a crapload of processing power to do, while bad just breeze through at realtime speed. If you have not, play around with Handbrake and change only the slider for compression efficiency vs encoding speed. It's under optimise video. Even at unlimited bitrade you will notice degradation in quality unless you add some effort to the compression work. Also proper dither made for the compression setting meaning you make the entire chain optimized makes a good difference. Justin Bacle 1 Link to comment Share on other sites More sharing options...
jgharding Posted October 20, 2016 Share Posted October 20, 2016 I enjoyed the guys delivery and attitude! As nice as the piece and idea is, the title's a bit misleading in a way. It isn't a comparison of 8-bit and 10-bit abstractly, it's just a comparison of two Sonys. Take some 10-bit ProRes out of an Arri Amira for example, I've run that up against 16-bit Red Raw from an MX sensor and the Arri is better and grades far more nicely in real-world situation (IE not purposefully smashing it to get banding). Or indeed 8-bit AVCHD from a C100 vs 8-bit anything else! The C100 has an amazing compression pipeline. But dip-depth is just one piece of the puzzle. There's bitrate and chroma subsampling too. Plus the sensor, AD conversion, gain stages, colour response and profiles, gamuts.... blah blah... I like that he talks about not transcoding 8-bit stuff. I've been saying it a lot, people waste masses of hard disk, thinking that transcoding 8-bit stuff to huge files is worth it. For my two cents, I also I grade things non stop as part of my living, and I hate most Slog and Sony cam colour with a passion. I wish I didn't though, as the cameras are cheap and high-spec. SR, maxmizer and Emanuel 3 Link to comment Share on other sites More sharing options...
Bill Sepaniak Posted October 20, 2016 Share Posted October 20, 2016 You might want to read the comments /critiques to Doug's latest video, and Doug's responses over at LiftGammaGain: http://liftgammagain.com/forum/index.php?threads/8bit-vs-10bit-camera-re-test.7263/page-3#post-73875 Link to comment Share on other sites More sharing options...
Hanriverprod Posted October 20, 2016 Share Posted October 20, 2016 It's between sony and blackmagic Link to comment Share on other sites More sharing options...
Ehetyz Posted October 20, 2016 Share Posted October 20, 2016 I watched until the blackmagic part and then stopped out of fear of getting brain cancer. "Hey let's compare 12-bit 1080p to 8-bit 4K, they look the same, therefore 8bit and raw are the same. Don't mind the resolution. Resolve has similar knobs for both, they're the same! Let's shoot this test with optimal light so as not to strain any of the codecs, yay!" andrgl, Geoff CB and MattH 3 Link to comment Share on other sites More sharing options...
