Andy Zou Posted October 25, 2016 Share Posted October 25, 2016 I recall somewhere reading that the distance from the adapter to the entrance pupil affects the quality of the combo. How does one measure the entrance pupil? Is this only visible in a lens' cross-section breakdown? Link to comment Share on other sites More sharing options...
Brian Caldwell Posted October 25, 2016 Share Posted October 25, 2016 11 hours ago, Andy Zou said: I recall somewhere reading that the distance from the adapter to the entrance pupil affects the quality of the combo. How does one measure the entrance pupil? Is this only visible in a lens' cross-section breakdown? Best done on an optical bench with a low-power microscope. But a macro lens will work OK as long as you focus by moving the whole camera. 1) stop lens under test (LUT) all the way down; 2) Focus on the iris diaphragm; 3) move microscope or camera away from the LUT until the front lens surface is in focus - you may have to apply some dust or some Scotch tape in order to see the front surface. The distance that the microscope or camera moves is the entrance pupil distance, e.g., the distance from the front surface of the LUT to the image of the iris diaphragm. Link to comment Share on other sites More sharing options...
Timotheus Posted October 25, 2016 Share Posted October 25, 2016 Noob question I guess, but how exactly can you use this measurement? Cheers, Tim Link to comment Share on other sites More sharing options...
Andy Zou Posted October 25, 2016 Author Share Posted October 25, 2016 4 hours ago, Brian Caldwell said: Best done on an optical bench with a low-power microscope. But a macro lens will work OK as long as you focus by moving the whole camera. 1) stop lens under test (LUT) all the way down; 2) Focus on the iris diaphragm; 3) move microscope or camera away from the LUT until the front lens surface is in focus - you may have to apply some dust or some Scotch tape in order to see the front surface. The distance that the microscope or camera moves is the entrance pupil distance, e.g., the distance from the front surface of the LUT to the image of the iris diaphragm. Huh! Fascinating. So I'd need to get another camera. I assumed that the optics between the front element and the iris would've thrown off this measurement. 1 hour ago, Timotheus said: Noob question I guess, but how exactly can you use this measurement? Cheers, Tim I think I read somewhere here or otherwise that the distance between the rear element of the anamorphic adapter and the entrance pupil is inversely correlated with the quality of the pairing. Link to comment Share on other sites More sharing options...
Timotheus Posted October 25, 2016 Share Posted October 25, 2016 1 hour ago, Andy Zou said: I think I read somewhere here or otherwise that the distance between the rear element of the anamorphic adapter and the entrance pupil is inversely correlated with the quality of the pairing. So pancake lenses rule then? Link to comment Share on other sites More sharing options...
Justin Bacle Posted October 26, 2016 Share Posted October 26, 2016 9 hours ago, Timotheus said: So pancake lenses rule then? The Helios 44 lens sits back and if far away from the rear anamorphic adapter lens. But still gives best results It depends mainly of what is the "quality" you're looking for. But yeah, pancakes are great with anamorphic adapters Timotheus 1 Link to comment Share on other sites More sharing options...
Brian Caldwell Posted October 26, 2016 Share Posted October 26, 2016 22 hours ago, Andy Zou said: Huh! Fascinating. So I'd need to get another camera. I assumed that the optics between the front element and the iris would've thrown off this measurement. I think I read somewhere here or otherwise that the distance between the rear element of the anamorphic adapter and the entrance pupil is inversely correlated with the quality of the pairing. The optics between the front surface and the iris are what determines the location of the entrance pupil. "Quality of the pairing" is only indirectly related to entrance pupil distance, but the amount of vignetting is directly related to it. To minimize vignetting you want the entrance pupil as far forward as possible, and the air gap between an anamorphic adapter and the prime lens to be as small as possible. Link to comment Share on other sites More sharing options...
