hyalinejim Posted November 6, 2016 Share Posted November 6, 2016 Just copy the contents of your card to your computer as a backup so you can go back to your current setup later. Then delete them and stick on the new stuff. Link to comment Share on other sites More sharing options...
veraguth Posted November 6, 2016 Share Posted November 6, 2016 22 hours ago, hyalinejim said: Here's a comparison at ISO 100, exposed to protect highlights, 2560x1072 (14 bit gives 28 seconds, 10 bit is continuous) in greyscale crop mode. I lifted the shadows a bit to see into the blacks. 14 bit is top left, 10 bit is bottom right. Try 3 pairs of DNGs here: https://drive.google.com/open?id=0B1exEpCRAfgFNUNVZVRYN0ZkSms I think that 10bit will work really well, as long as there's nothing you need to pull out of the noise floor. Remember that the 2K DCI spec for Cinemascope is 2048x858... which is 80% of the above res. This allows for a significant amount of re-composing / stabilising / downscaling for increased resolution. Interestingly, both types of DNG are the same size in bytes - don't know what's going on there. This 10 bit footage looks really bad. Do you think it is worth the hassle compared to a 8 bit log? Link to comment Share on other sites More sharing options...
hyalinejim Posted November 6, 2016 Share Posted November 6, 2016 I don't think it's that bad. Are you referring to the screengrab above, or the DNGs I posted? Nikkor 1 Link to comment Share on other sites More sharing options...
kaylee Posted November 7, 2016 Share Posted November 7, 2016 4 hours ago, hyalinejim said: I don't think it's that bad. Are you referring to the screengrab above, or the DNGs I posted? yeah... looks good to me~! thanks for the dngs @hyalinejim Link to comment Share on other sites More sharing options...
kgv5 Posted November 7, 2016 Share Posted November 7, 2016 I am testing this on 5d3 113. I am really shocked, with the old PC mlvfs (with pismo) 10 and 12 bits works like a breeze I am using resolve 12.5, sometimes only the first frames are corrupted but the rest is perfect. 10 and 12 bits recording is really a huge boost in recording times. The most important and useful modes for me now: 1920x648 (1920x1080 16:9 after desqueeze) 50 fps 12bit - continous - (previously only 2,35:1 was continous) 1920x648 (1920x1080 16:9 after desqueeze) 60 fps 10 bit - 25 sek 1920x1080 37 fps 12 bit - 13 sek 10 bit - continous 2560x1320 25 fps (max vertical resolution available) 1.94:1 aspect - 10 bit - continous 2880x1226 2,35:1 25fps 10bit - over 2 minutes 24 fps 10 bit - continous I checked those recordings in resolve and sometimes there are first and last frames corrupted but no problems during clips. Link to comment Share on other sites More sharing options...
Taranis Posted November 7, 2016 Share Posted November 7, 2016 2 hours ago, kgv5 said: I am testing this on 5d3 113. I am really shocked, with the old PC mlvfs (with pismo) 10 and 12 bits works like a breeze I am using resolve 12.5, sometimes only the first frames are corrupted but the rest is perfect. 10 and 12 bits recording is really a huge boost in recording times. The most important and useful modes for me now: 1920x648 (1920x1080 16:9 after desqueeze) 50 fps 12bit - continous - (previously only 2,35:1 was continous) 1920x648 (1920x1080 16:9 after desqueeze) 60 fps 10 bit - 25 sek 1920x1080 37 fps 12 bit - 13 sek 10 bit - continous 2560x1320 25 fps (max vertical resolution available) 1.94:1 aspect - 10 bit - continous 2880x1226 2,35:1 25fps 10bit - over 2 minutes 24 fps 10 bit - continous I checked those recordings in resolve and sometimes there are first and last frames corrupted but no problems during clips. Can you also do some DR comparison? Link to comment Share on other sites More sharing options...
kgv5 Posted November 7, 2016 Share Posted November 7, 2016 I will do this little bit later, i expect there will be less ability to recover shadows/highligts especially in 10 bits - but as a tool - 10bit is gladly welcome. I am very excited because of usable 50/60 fps in 16:9 aspect. There are also 11 and 13 bits settings, i have to also try them. Dan Wake 1 Link to comment Share on other sites More sharing options...
hyalinejim Posted November 7, 2016 Share Posted November 7, 2016 1 hour ago, Taranis said: Can you also do some DR comparison? On 6/11/2016 at 0:21 AM, hyalinejim said: Try 3 pairs of DNGs here: https://drive.google.com/open?id=0B1exEpCRAfgFNUNVZVRYN0ZkSms One of those pairs is a high DR scene Link to comment Share on other sites More sharing options...
Justin Bacle Posted November 7, 2016 Share Posted November 7, 2016 1 hour ago, kgv5 said: I will do this little bit later, i expect there will be less ability to recover shadows/highligts especially in 10 bits - but as a tool - 10bit is gladly welcome. I am very excited because of usable 50/60 fps in 16:9 aspect. There are also 11 and 13 bits settings, i have to also try them. The 11 & 13 bit settings are not selectable. I'm not sure it is really necessary though Link to comment Share on other sites More sharing options...
veraguth Posted November 7, 2016 Share Posted November 7, 2016 16 hours ago, hyalinejim said: I don't think it's that bad. Are you referring to the screengrab above, or the DNGs I posted? Yes, I was referring to the screengrab above. Link to comment Share on other sites More sharing options...
hyalinejim Posted November 7, 2016 Share Posted November 7, 2016 On 6/11/2016 at 0:21 AM, hyalinejim said: I lifted the shadows a bit to see into the blacks. Link to comment Share on other sites More sharing options...
Taranis Posted November 7, 2016 Share Posted November 7, 2016 2 hours ago, hyalinejim said: One of those pairs is a high DR scene Just checked the DNGs. The difference in the high DR scene is pretty visible. You'll have to choose your options wisely. Link to comment Share on other sites More sharing options...
hyalinejim Posted November 7, 2016 Share Posted November 7, 2016 I'm with you on that one. My take home message is: the advantage of 10bit amounts to a 29% increase in resolution or fps or recording time, or some mix of all three. If you don't need any of the above, stick with 14bit. But if you do, make sure nothing you're interested in lives in the noise floor (which is shown on the RAW histogram as a dithered pattern - stay outta there!). kaylee 1 Link to comment Share on other sites More sharing options...
kgv5 Posted November 7, 2016 Share Posted November 7, 2016 Exactly, 10 and 12 bits are just a great tools, for me ability to shot 14bits and then drop to 12bit to record 50fps continously with 16:9 aspect is just great. I have also tried 65fps and get 12 seconds of 10bit raw 65fps 16:9 - it would be just a great addon in situation when 37% slomo is needed hyalinejim 1 Link to comment Share on other sites More sharing options...
samuel.cabral Posted November 7, 2016 Share Posted November 7, 2016 I'm still waiting for a mirrorless canon that can shoot RAW at 1080p. If the EOSM is really a mirrorless 80d as some people say, it might be the one! My c-mount lenses are waiting for it! Link to comment Share on other sites More sharing options...
Ty Harper Posted November 7, 2016 Share Posted November 7, 2016 Looks like they cracked the 5D Mark IV: http://www.magiclantern.fm/forum/index.php?topic=17695.msg172713#msg172713 Link to comment Share on other sites More sharing options...
Dan Wake Posted November 8, 2016 Share Posted November 8, 2016 13 hours ago, hyalinejim said: I'm with you on that one. My take home message is: the advantage of 10bit amounts to a 29% increase in resolution or fps or recording time, or some mix of all three. If you don't need any of the above, stick with 14bit. But if you do, make sure nothing you're interested in lives in the noise floor (which is shown on the RAW histogram as a dithered pattern - stay outta there!). if possible may I ask you to take a picture of this histogram and draw a circle around the area that express the amount of noise please? I wish to understand better please, it looks very very useful! Link to comment Share on other sites More sharing options...
hyalinejim Posted November 8, 2016 Share Posted November 8, 2016 This is at 3200 ISO. The area within the red box is where the noise lives! Dan Wake 1 Link to comment Share on other sites More sharing options...
Justin Bacle Posted November 8, 2016 Share Posted November 8, 2016 Form the test I managed to do (the 50D and 5d mk2 are not yet fully supported as one every two frames is garbage), I don't see a noticable difference between 12 & 14 bits with a standard grading and a properly exposed shot. 10 bit is too noisy though. hyalinejim and Liam 2 Link to comment Share on other sites More sharing options...
Dan Wake Posted November 8, 2016 Share Posted November 8, 2016 @hyalinejim thanks! Link to comment Share on other sites More sharing options...
