hyalinejim Posted November 6, 2016 Share Posted November 6, 2016 The XC10's 1080p is quite compressed and has a lot of artifacts. Its 4K downscaled to 1080, however, is lovely and stands up to moderate grading quite well. But of course, the motion ghosting that we've been going on about here a bit lately precludes it as a serious contender for image quality. kidzrevil 1 Link to comment Share on other sites More sharing options...
kidzrevil Posted November 6, 2016 Share Posted November 6, 2016 Its looking like it can't hurt to pick up a 5D for the raw video. Guess I can always use the xc10 for quick 1080p turnover time Can't lie the 5D raw has some of the best IQ I have seen 37 minutes ago, hyalinejim said: The XC10's 1080p is quite compressed and has a lot of artifacts. Its 4K downscaled to 1080, however, is lovely and stands up to moderate grading quite well. But of course, the motion ghosting that we've been going on about here a bit lately precludes it as a serious contender for image quality. Maybe its the diffusion filter I am using but I don't see a lot of artifacts in the 1080 image when using C-LOG and Cinema EOS standard. The in camera sharpening from the other profiles like WDR in 1080 looks terrible though. Praying they tackle the ghosting issues with the xc10 but for now at 1000 iso and lower the 1080p is good enough for the web with a good finishing filter on the lens like a tiffen black satin Link to comment Share on other sites More sharing options...
hyalinejim Posted November 6, 2016 Share Posted November 6, 2016 Good stuff! I guess EOS standard has less DR so easier to compress. AFAIR you can dial down sharpness to zero in WideDR. Link to comment Share on other sites More sharing options...
bigfried Posted November 9, 2016 Share Posted November 9, 2016 RX100 IV - 1080 at 100mbsp - flat profiles, stabilized. mercer and Orangenz 2 Link to comment Share on other sites More sharing options...
Flaaandeeers Posted November 10, 2016 Share Posted November 10, 2016 On 11/9/2016 at 8:37 AM, bigfried said: RX100 IV - 1080 at 100mbsp - flat profiles, stabilized. Interesting mention. On my D750 I currently have a set of Ai-S primes from 20 to 105mm and a nifty AF-D 50 1.8, and I was thinking of getting a stabilized all-round zoom mostly for run n' gun doc, travel shit and casual stills but for a price similar to the Tamron 24-70, Sigma 24-105 or Nikon 24-120 here I can get the RX100 IV that could be used for that kind of stuff and also compliment the D750 as a B camera with nice Full HD HFR. Would that make sense? Link to comment Share on other sites More sharing options...
Kisaha Posted November 10, 2016 Share Posted November 10, 2016 Ofcourse it could, everything is possible. Generaly speaking, it is not very convinient to mix and match so different sensors. Even with same sensors and cameras the image is quite different, imagine completely different sized sensors. Just my 2 cents. Link to comment Share on other sites More sharing options...
Django Posted November 11, 2016 Share Posted November 11, 2016 On 3 Nov 2016 at 6:31 PM, Oliver Daniel said: I've found that because of the focus on 4k, manufacturers are putting out poor 1080p modes - which are actually worse than what they were before 4k hit the market. The A7SII for example, has a worse 1080p mode than the original. ..really how so exactly? both use same sensor and XAVC-S? in my experience the A7SII 1080p is pretty awesome IQ wise when exposed right. As for 5D3 Raw vs C100, I've recently shot with both on multi-cam project. The C100 is actually sharper (as it's a downscaled 4K sensor) so in many shots we favoured it, especially for small punch-in edits.. 5D3 Raw has this filmic quality though.. makes other cams feel "video-ish" so sharpness isn't necessarily everything. But when you compare the file sizes and workflow, it's quite amazing what the C100 provides via it's 24mbps codec! (even though i am going to add an atomos as i hate AVCHD container format). Link to comment Share on other sites More sharing options...
Oliver Daniel Posted November 11, 2016 Share Posted November 11, 2016 2 hours ago, Django said: ..really how so exactly? both use same sensor and XAVC-S? in my experience the A7SII 1080p is pretty awesome IQ wise when exposed right. As for 5D3 Raw vs C100, I've recently shot with both on multi-cam project. The C100 is actually sharper (as it's a downscaled 4K sensor) so in many shots we favoured it, especially for small punch-in edits.. 5D3 Raw has this filmic quality though.. makes other cams feel "video-ish" so sharpness isn't necessarily everything. But when you compare the file sizes and workflow, it's quite amazing what the C100 provides via it's 24mbps codec! (even though i am going to add an atomos as i hate AVCHD container format). The A7SII 1080p is fine, I've used it often for 50/60fps. It's not as good as the original A7S 1080p, but the difference isn't much. Also the A7S 1080p is full frame, whereas the Mark II is S35. This only applies to cameras that ALSO have a normal 4k setting, not the cameras that have 1080p at the highest resolution. The only special case is the FS5, which has a "better than the 4k" 1080p mode. Internal of course. Link to comment Share on other sites More sharing options...
Django Posted November 11, 2016 Share Posted November 11, 2016 16 minutes ago, Oliver Daniel said: The A7SII 1080p is fine, I've used it often for 50/60fps. It's not as good as the original A7S 1080p, but the difference isn't much. Also the A7S 1080p is full frame, whereas the Mark II is S35. I'm sorry but this information is incorrect. The A7SII is absolutely full frame in 1080p. It's also imo superior to mark 1 in S-Log as it allows much lower base ISO. I think you might be confusing with A7RII which has a non full-readout S35 mode in 1080p. Link to comment Share on other sites More sharing options...
Oliver Daniel Posted November 11, 2016 Share Posted November 11, 2016 12 minutes ago, Django said: I'm sorry but this information is incorrect. The A7SII is absolutely full frame in 1080p. It's also imo superior to mark 1 in S-Log as it allows much lower base ISO. I think you might be confusing with A7RII which has a non full-readout S35 mode in 1080p. Ah, maybe I'm getting confused. 50/60fps is in s35 only, whereas 120fps is 2.2x. What camera has better 1080p than another could be debated non-stop, it doesn't really matter that much. Link to comment Share on other sites More sharing options...
Kurtisso Posted November 13, 2016 Share Posted November 13, 2016 Digital Boooollleexxx at about aps-c/s35 size with bmpcc speedbooster in glorious global shutter, kodak color, dng beaaauttyyyy. Pair it with a BMMCC for some 60fps raw funs. I'll take that over garb 4k for 4k's sake. 1080p aint dead. Liam 1 Link to comment Share on other sites More sharing options...
jgharding Posted November 13, 2016 Share Posted November 13, 2016 It all depends on your business. In the last 6 years of pro video work I've never once delivered at 4k. For most work 1080p is still around. Kisaha 1 Link to comment Share on other sites More sharing options...
kidzrevil Posted November 13, 2016 Share Posted November 13, 2016 8 minutes ago, jgharding said: It all depends on your business. In the last 6 years of pro video work I've never once delivered at 4k. For most work 1080p is still around. me neither and I doubt I ever will get a request for it. Link to comment Share on other sites More sharing options...
