enny Posted November 12, 2016 Share Posted November 12, 2016 Hi guys i have set of yashica ml lenses and yashica speedbooster with BMCC i have 24mm lens now i am looking for even wider can you recommend anything in CY mount i have about 1000 to spend Thanks Link to comment Share on other sites More sharing options...
Cinegain Posted November 12, 2016 Share Posted November 12, 2016 The CY Zeiss 21mm is pretty legendary... that means pricey though... I'd say that might be the best sub-24mm option out there. There's the 15, 16 and 18mm of which the 18mm most usable, but also pretty rare to find. Maybe look at the Zeiss ZF/ZE-range as well to open up options... Link to comment Share on other sites More sharing options...
IronFilm Posted November 13, 2016 Share Posted November 13, 2016 If you're shooting APS-C (or smaller) sensor, then you really should go with an APS-C UWA lens (such as the legendary Tokina 11-16mm f2.8, or its 11-20mm update) if you want any chance at getting good bang for your buck. Link to comment Share on other sites More sharing options...
