Grimor Posted November 15, 2016 Share Posted November 15, 2016 Today, when i was shooting some tests with G80 and Kowa 2x, handheld , i can see sometimes the image whobling and misaligned due the sensors movements. It's only an advice that i haven't read it before. Justin Bacle and Cinegain 2 Link to comment Share on other sites More sharing options...
Grimor Posted November 16, 2016 Author Share Posted November 16, 2016 "Vertical stabilization only" mode will be the only usefull thing. Link to comment Share on other sites More sharing options...
Vladimir Posted November 17, 2016 Share Posted November 17, 2016 once i had shooting with a7sii, didnt had time to test it so i just set it 'manually' to focal_length_of_taking_lens divided by 2. Did u do the same? Otherwise IBIS to strong for horizontal plane (in my humble understanding of how it works). In my case there was some shots with whobling but not much and i think u get the same amount without any ana. Grimor and Justin Bacle 2 Link to comment Share on other sites More sharing options...
Grimor Posted November 17, 2016 Author Share Posted November 17, 2016 I get "strong whobling" with the G80 (first firmware) and i think i was lossing my anamorphic atachment, but not. it was rock solid. Then i realize that new Ibis was the reason why my footage was like under drugs. Vertical axis of the lens is fixed and sensor axis are moving all the time (if handheld) so everytine change the aligment. I think is more evident with modern IBIS and 2x anamorphic ratios. I dont really know what focal length set manually. The same as lens? The Full frame equivalent? or divided x2? Link to comment Share on other sites More sharing options...
