GH2 and E-M5
peterpix
Hi, You can convert 30p to 24p with cinema tools on FCP 3 suite.
I suggest to convert and then edit with only one workflow on fcp. FCP doesn't like to edit with differents material in anyway or you will get render's lines....In fact, you can mix different footage or frames rates , but you will get probably red render lines...and that's a pain in...
To mix , the best programm is Premiere cs 5 o 5.5. Here you can mix and get preview real time without problems.
Saludos.
