Mat Mayer Posted December 1, 2016 Share Posted December 1, 2016 I love my G7 and intended to buy a GH5, but looking at a comparisson of the G7 with the A6300 today, there was a major difference in sharpness. Might of been focusing but more likely the fact that the A6300 shoots 6K and downscales to 4K. So do you think a M43 sensor is big enough to provide that extra sharpness and be comparable with an APSC sensor? Has the system peaked or will the GH5 possibly make a big difference? The NX1 is reasonably priced used on eBay. Wondering whether to pull the trigger and make the switch now. I don't need filmic and lots of lenses, I need sharp accurate 4K video. The Sony's over heating means they cannot be considered for me as it is to use outdoors, often in hottest sunlight. I really don't have the funds for the 4K Canon beasts otherwise I would go that route. Has anyone used both the G7 and NX1 and noticed a big difference in sharpness? I recall reading lots of praise about how good and sharp the NX1 is on here. I am in no rush so could wait for the GH5, its just tempting to get started with a new system if going to do it anyway. Thanks. Marco Tecno 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 1, 2016 Administrators Share Posted December 1, 2016 Well since the E-M1 II already oversamples from 5K and is very very close indeed to the A6300's 4K the answer is yes. GH5 will have a flood of high detail. I long since stopped caring about the sharpness of 4K though. More sharpness is the last thing we need. 10bit, dynamic range, colour, less aliasing, less moire, less rolling shutter are all more important when it comes to 4K, which already has too much detail according to most of the cinema audience reaction to it being projected. jonpais, Mat Mayer, hyalinejim and 4 others 7 Link to comment Share on other sites More sharing options...
Mat Mayer Posted December 1, 2016 Author Share Posted December 1, 2016 Thanks Andy, I was just about to click Buy on an NX1 kit on eBay and extra lens. I love Panasonic and they have a future, so I am not jumping ship Link to comment Share on other sites More sharing options...
Vesku Posted December 1, 2016 Share Posted December 1, 2016 I think GH5 will have quite similar sharpness than Sony A6500. 4k 60P, less RS and 10bit will give even much more value. Mat Mayer 1 Link to comment Share on other sites More sharing options...
tugela Posted December 1, 2016 Share Posted December 1, 2016 Based on what we see from non-oversampled sensors, resolution still has a way to go for many manufacturers. In modern cameras oversampling in a debeyered sensor is pretty much a must to maximise the information the camera is capable of gathering. Saying "it doesn't matter" is dumb IMO. The problem with smaller sensors is not resolution so much, but rather light scattering on the sensor surface, which results in "unfortunate" effects such as purple fringing with certain lighting conditions. You can usually see right away when footage has been shot with a small sensor because of highlights blooming when the light comes in from particular directions. So, in general to maximise the quality of your footage you really want a bigger sensor. Personally I would not choose anything smaller than an APS-C sensor for footage that I considered important. Link to comment Share on other sites More sharing options...
dbp Posted December 1, 2016 Share Posted December 1, 2016 I used to care alot about resolved detail with 1080p cameras because so many of them were barely 720p mush. With 4K, I care way way less and would rather have the other image elements be in place. Dunno what the GH4 actually resolves, but I'm sure it's not a perfect 4K. It's definitely plenty, detail wise, for me. Liam and kidzrevil 2 Link to comment Share on other sites More sharing options...
aldolega Posted December 1, 2016 Share Posted December 1, 2016 I think it all depends on what your desired end product is. If you want to deliver in 4K, at the maximum resolution a 4K file is possibly capable of, you will need an oversampled sensor to get there because of the resolution loss from debayering. So at the minimum, an NX1 or A6300/6500... or more realistically, a FS7, C300II, Red, etc, when you consider how many compromises the NX1 or A6300/6500 have (rolling shutter, overheating, limited DR, slomo is FHD at best, etc). So, still not "affordable" to most people looking to own the camera... even the vast majority of pro shooters, which are not yet (and may never be) at the point of realistically affording a $8-10K camera. For all those shooters, and of course most enthusiasts and hobbyists, I think aiming to deliver a maxed-out 1080p file is more realistic, which is mostly achievable with the current affordable 4K cams. Even if my GH4 is only resolving maybe 3K because of debayering, that's still plenty to deliver maxed-out 1080p, even with a little bit of cropping or stabilizing. Mat Mayer 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 2, 2016 Administrators Share Posted December 2, 2016 2 hours ago, aldolega said: I think it all depends on what your desired end product is. If you want to deliver in 4K, at the maximum resolution a 4K file is possibly capable of, you will need an oversampled sensor to get there because of the resolution loss from debayering. To compensate from the resolution loss from debayering you would need to oversample from 8K to 4K perfectly like the F65. Anyone got a spare $300,000? Link to comment Share on other sites More sharing options...
TheRenaissanceMan Posted December 2, 2016 Share Posted December 2, 2016 Only $60K for the new RED Helium. Link to comment Share on other sites More sharing options...
tugela Posted December 2, 2016 Share Posted December 2, 2016 21 hours ago, Andrew Reid said: To compensate from the resolution loss from debayering you would need to oversample from 8K to 4K perfectly like the F65. Anyone got a spare $300,000? 6K will get you pretty close. No oversampling will be perfect, but there will be diminishing returns after a certain point. 50% in both dimensions should be sufficient to get pretty close (I would guess something like 95%) Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 3, 2016 Administrators Share Posted December 3, 2016 To prevent the loss from debayering you really need a sensor... with no debayering. A Foveon design sensor. Link to comment Share on other sites More sharing options...
Michael Ma Posted December 4, 2016 Share Posted December 4, 2016 M43 at ISO 200 in optimum lighting is still very noisy if you look at the raw files at 100% crop. A lot of micro details are lost due to noise removal. Lots of room for improvement. Link to comment Share on other sites More sharing options...
