Rungunshoot Posted July 14, 2013 Share Posted July 14, 2013 I wrote a blog about the D5200, including studio and documentary footage: http://rungunshoot.com/nikon-d5200-studio-and-documentary-footage/ Link to comment Share on other sites More sharing options...
JBraddock Posted July 20, 2013 Share Posted July 20, 2013 Hi Brandon, I really liked it. If not mistaken, you shoot with standard picture profile with all settings dial downed. I was wondering how much sharpening do you apply to the footage. I have a D7100 and I've been trying to learn and create a workflow for myself. Any tips and workflow advice would be appreciated. Link to comment Share on other sites More sharing options...
westlake10 Posted July 22, 2013 Share Posted July 22, 2013 Banding noise and shooting modes. Never thought it's so bad! ----Modified -----Apology to whomever I misled, I made a mistake, when I used the A mode, the ISO was pumped up automatically so the banding was much worse. Tried at ISO 100, still bad in dark areas. 1st Image, A mode. 2nd image, Manual mode, a lot better. Link to comment Share on other sites More sharing options...
Rungunshoot Posted July 23, 2013 Share Posted July 23, 2013 Hi Brandon, I really liked it. If not mistaken, you shoot with standard picture profile with all settings dial downed. I was wondering how much sharpening do you apply to the footage. I have a D7100 and I've been trying to learn and create a workflow for myself. Any tips and workflow advice would be appreciated. Hey JBraddock, I didn't do anything to the footage in post. What you're seeing in the video is the standard profile with nothing altered. It's just a great image right out of the box. Link to comment Share on other sites More sharing options...
Guest c2dd7b52878779b55f43cc8c269267c1 Posted September 18, 2013 Share Posted September 18, 2013 Can anyone tell me about using AIS glass with the D5200? As I understand there isn't any way to monitor exposure in video mode (e.g. no histogram). I don't like the sound of this and I'm surprised Andrew didn't mention it in his review (he was using an old, manual e-series lens). How do you expose accurately in live view using manual glass with the D5200? Link to comment Share on other sites More sharing options...
Rungunshoot Posted October 15, 2013 Share Posted October 15, 2013 Can anyone tell me about using AIS glass with the D5200? As I understand there isn't any way to monitor exposure in video mode (e.g. no histogram). I don't like the sound of this and I'm surprised Andrew didn't mention it in his review (he was using an old, manual e-series lens). How do you expose accurately in live view using manual glass with the D5200? AIS glass works fine but only in manual mode. You cannot use shutter or aperture priority modes with any non-electronically connected lenses. There is no histogram or zerbas. I've always just monitored by eye and learned how to visually tell if the image is correctly exposed. It sounds dicey, but you can get consistent results just by practicing shooting in different conditions and then reviewing your work. Link to comment Share on other sites More sharing options...
RRRoger Posted October 15, 2013 Share Posted October 15, 2013 If you connect an external monitor (to the HDMI port) with focus peaking it can help a lot. You can also use a Ninja II to record Higher quality Video and do the same thing with it's monitor. Link to comment Share on other sites More sharing options...
Guest c2dd7b52878779b55f43cc8c269267c1 Posted October 30, 2013 Share Posted October 30, 2013 I have a D7100 and I've been trying to learn and create a workflow for myself. Any tips and workflow advice would be appreciated. Has anyone decided if the 7100 is inferior to the 5200 for video due to its lack of OLPF? Is there any moire/aliasing in video mode on the 7100? I'm holding off on buying a D5200 because of the immanent 5300, which has no OLPF (+ prob same sensor as 52/7100) but has 60p, better low light and better battery than 5200. I assume fixed pattern noise will still be a problem with the 5300 ... Link to comment Share on other sites More sharing options...
RRRoger Posted October 30, 2013 Share Posted October 30, 2013 I think we are all hoping that Nikon does not cripple the Video in the D5300. I will probably get one myself for the 1080P at 60 fps. Link to comment Share on other sites More sharing options...
mojo43 Posted October 30, 2013 Share Posted October 30, 2013 I thought that I read that the sensor changed...? Link to comment Share on other sites More sharing options...
RRRoger Posted October 30, 2013 Share Posted October 30, 2013 I thought that I read that the sensor changed...? Yes it has a different Sensor without low pass filter. Expeed 4 1080P @ 60fps 3.2" swivel monitor with 1037k dots Link to comment Share on other sites More sharing options...
terozzz Posted July 9, 2014 Share Posted July 9, 2014 Now the Annoying Fixed horizontal pattern noise is GONE!!! The "Video HQ 40mbps Bit-rate" fot Nikon D5200 hack did it.. The noise is now like in D5300. mojo43 1 Link to comment Share on other sites More sharing options...
mojo43 Posted July 9, 2014 Share Posted July 9, 2014 Now the Annoying Fixed horizontal pattern noise is GONE!!! The "Video HQ 40mbps Bit-rate" fot Nikon D5200 hack did it.. The noise is now like in D5300. Do you have any examples that you can post of before and after? I would love to see them if so. I didn't think that a higher bitrate would get rid of banding? Link to comment Share on other sites More sharing options...
Inazuma Posted July 9, 2014 Share Posted July 9, 2014 Now the Annoying Fixed horizontal pattern noise is GONE!!! The "Video HQ 40mbps Bit-rate" fot Nikon D5200 hack did it.. The noise is now like in D5300. Do you have any proof? Because the fixed pattern noise happens at the sensor level (ie. it appears in RAW files too). I doubt a different bitrate could fix that. Link to comment Share on other sites More sharing options...
mojo43 Posted July 9, 2014 Share Posted July 9, 2014 That's what I was thinking. I know that on the GH1 there is no banding difference before or after the hack. What does the bitrate increase help with since the D5200 doesn't have mud. I am not asking to be a jerk, just wondering if there is anything that is better with the bitrate increase? Link to comment Share on other sites More sharing options...
terozzz Posted July 9, 2014 Share Posted July 9, 2014 Here is one frame at Hi0.7 from D5200. Link to comment Share on other sites More sharing options...
mojo43 Posted July 9, 2014 Share Posted July 9, 2014 Thanks for posting. Do you have card failures when the bitrate is high? Link to comment Share on other sites More sharing options...
terozzz Posted July 9, 2014 Share Posted July 9, 2014 Thanks for posting. Do you have card failures when the bitrate is high? No. Works like a dream... And the Fixed horizontal pattern is still there but i can see it only above iso 8000 or if i push contrast like mad man. Fifty 1 Link to comment Share on other sites More sharing options...
mojo43 Posted July 9, 2014 Share Posted July 9, 2014 No. Works like a dream... And the Fixed horizontal pattern is still there but i can see it only above iso 8000 or if i push contrast like mad man. Great! Do you see any other improvements? The D5200 picks up detail already really well. Does it get any better? Link to comment Share on other sites More sharing options...
terozzz Posted July 9, 2014 Share Posted July 9, 2014 Great! Do you see any other improvements? The D5200 picks up detail already really well. Does it get any better? Less banding, i quess.. Needs to do more shooting. More details.. Well that needs side by side shooting and to me its out of question. Link to comment Share on other sites More sharing options...
