Evan Posted December 22, 2016 Share Posted December 22, 2016 Hey guys -hope you are all well!! so iv purchased a great pack from Andrew regards the LUT log for my NX1...was just wondering if anyone would be kind enough to suggest s handful of LUT's to try? Also, what are the best in camera settings for applying you LUT's...please excuse my lack of understanding and experiance....thank you...humbly! Link to comment Share on other sites More sharing options...
SuperSet Posted December 22, 2016 Share Posted December 22, 2016 There's another NX1 thread with links to ARourke's free LUTs that you should try as well as recommended picture settings. I really love the 1DX one that he did. I've also had great luck with the IWLTBAP ones. benymypony 1 Link to comment Share on other sites More sharing options...
Evan Posted December 22, 2016 Author Share Posted December 22, 2016 4 minutes ago, SuperSet said: There's another NX1 thread with links to ARourke's free LUTs that you should try as well as recommended picture settings. I really love the 1DX one that he did. I've also had great luck with the IWLTBAP ones. Thank you very much!! Link to comment Share on other sites More sharing options...
ricardo_sousa11 Posted December 22, 2016 Share Posted December 22, 2016 Hi! I wouldnt say its the best luts, but have a look at these, they were designed specifically for the NX1, and they are 25% off right now!https://sellfy.com/p/HNAk/-XMAS/ Kisaha and Evan 2 Link to comment Share on other sites More sharing options...
NX1user Posted December 22, 2016 Share Posted December 22, 2016 I've had good luck with: https://luts.iwltbap.com I just finished this doc and it's all NX1 with LUTS from the above. omega1978, Evan and benymypony 3 Link to comment Share on other sites More sharing options...
Parker Posted December 22, 2016 Share Posted December 22, 2016 I like and use all of the above mentioned LUTs with the NX1 and NX500 and would heartily recommend them as well. I'll throw a few more in the ring that I enjoy also: I really like Neumann film's rec.709 cinema lut, it's subtle but really nice, and I frequently use the tried-and-true Osiris M31 LUT with the NX1 with lovely results, as well as James Miler's DeLuts, particularly Sunderland, and various of his black and white ones. I also like how filmconvert plays with NX footage. I haven't really put the new Samsung profiles they released through the paces yet (haven't heard the greatest things about them, unfortunately) but in the past I've had luck using Red Gamma profiles. Best of luck! In my opinion the color these cameras produce is very malleable, and you can really reproduce an astonishingly wide variety of looks without too much trouble. Evan 1 Link to comment Share on other sites More sharing options...
Evan Posted December 23, 2016 Author Share Posted December 23, 2016 14 hours ago, NX1user said: I've had good luck with: https://luts.iwltbap.com I just finished this doc and it's all NX1 with LUTS from the above. WOW - WHAT ARE YOUR IN CAMERA SETTINGS AND PICTURE PROFILE? Link to comment Share on other sites More sharing options...
NX1user Posted December 23, 2016 Share Posted December 23, 2016 9 hours ago, Evan said: WOW - WHAT ARE YOUR IN CAMERA SETTINGS AND PICTURE PROFILE? Thanks! Kinoseed bitrate hack (180mbs), using Andrew's Gamma DR profile. Lenses: Samsung 16-50 S, Rokinon 12mm and 85mm, plus some lensbaby. I used a couple LUTS (8690 and 8181) by luts.iwltbap.com and FilmConvert in post. Filmed in 4K converted to ProRes for editing in Premiere. Yes, I know Premiere supports H.265, but I've had nothing but problems with H.265 files since the last update. Exported to 1080. Evan 1 Link to comment Share on other sites More sharing options...
Marco Tecno Posted December 23, 2016 Share Posted December 23, 2016 If I understand. You capture with eoshd settings, then apply gamma lut, then some other lut? Link to comment Share on other sites More sharing options...
Kisaha Posted December 24, 2016 Share Posted December 24, 2016 @NX1user what H265 problems? I have the memory leak issue, but everything else works fine, so I am reluctunt to upgrade to the newer version. If I am not be able to use H265 natively, then I will skip the latest version. Link to comment Share on other sites More sharing options...
NX1user Posted December 24, 2016 Share Posted December 24, 2016 23 hours ago, Marco Tecno said: If I understand. You capture with eoshd settings, then apply gamma lut, then some other lut? I seem to have better results NOT applying Amdrew's gamma LUT. 5 hours ago, Kisaha said: @NX1user what H265 problems? I have the memory leak issue, but everything else works fine, so I am reluctunt to upgrade to the newer version. If I am not be able to use H265 natively, then I will skip the latest version. Premiere is laggy now with the bitrate-hacked footage. It was fine with it a few months ago. Because of the lag, I now render the workspace to preview edits, like pans or zooms added in post. Well, now when I render the workspace, the program window gives me the "media pending" message forever. If I actually export the file it's fine. If I delete the render preview files (or whatever they are called) I get picture back in the program monitor, but the lag also returns. None of this happens if I convert the 4K files to ProRes first. I'm assuming this is a Premiere problem. It wouldn't surprise me if it's an Apple problem that is somehow screwing up thing in Premiere. I reinstalled Premiere and even bought more memory for my computer. No change. It's frustrating because a few months ago, on the same machine, exactly the same footage would play back just fine in Premiere. I have a late 2014 imac 5K maxed out memory, processor and video card. Link to comment Share on other sites More sharing options...
Kisaha Posted December 24, 2016 Share Posted December 24, 2016 Sorry to hear that, it is definitely software related (Apple related too), as my pc is much older, but with good specs (except the gpu which is jusy mediocre with today standards). I haven't process anything more than 120mbps though, I guess the 180 could make a huge difference in processing power needed, does it make a huge difference in grading and total image quality though? Evan 1 Link to comment Share on other sites More sharing options...
NX1user Posted December 25, 2016 Share Posted December 25, 2016 17 hours ago, Kisaha said: Sorry to hear that, it is definitely software related (Apple related too), as my pc is much older, but with good specs (except the gpu which is jusy mediocre with today standards). I haven't process anything more than 120mbps though, I guess the 180 could make a huge difference in processing power needed, does it make a huge difference in grading and total image quality though? Yes, for grading and getting rid of compression noise in fine patterns and shadows, 180 is worth it. I never noticed any difference above 180 and that seems to be what others have said too. Evan 1 Link to comment Share on other sites More sharing options...
ricardo_sousa11 Posted December 27, 2016 Share Posted December 27, 2016 Sharing a small clip that I shot in Aug. on a trip to the US with a fellow NX1 user, that is also a user here on the forum, Mr. Adam Bradley :D Parker, Kisaha and shanebrutal 3 Link to comment Share on other sites More sharing options...
Becca Posted May 25, 2017 Share Posted May 25, 2017 What are Andrews in camera gamma dr settings? Master black levels, saturation, contrast, sharpness, hue? @NX1user Link to comment Share on other sites More sharing options...
