mirekti Posted September 2, 2018 Share Posted September 2, 2018 Are these LUTs specific to GH5 or they can be used on GH5S too? I’ve read GH5S changed its color sceince compared to GH5, but not sure what that implies. Link to comment Share on other sites More sharing options...
jonpais Posted September 2, 2018 Share Posted September 2, 2018 38 minutes ago, mirekti said: Are these LUTs specific to GH5 or they can be used on GH5S too? I’ve read GH5S changed its color sceince compared to GH5, but not sure what that implies. They’re compatible with the GH5s too. Link to comment Share on other sites More sharing options...
jonpais Posted September 4, 2018 Share Posted September 4, 2018 This is probably going to be the final beta v801, with the new LUTs being sent out shortly. Skin tones less orange/magenta. Remember, you’ve got to ETTR and set saturation in camera to -5 with the new version. Sample Link to comment Share on other sites More sharing options...
mirekti Posted September 4, 2018 Share Posted September 4, 2018 8 hours ago, jonpais said: This is probably going to be the final beta v801, with the new LUTs being sent out shortly. Skin tones less orange/magenta. Remember, you’ve got to ETTR and set saturation in camera to -5 with the new version. Sample This looks rather good. One quick question as I am not so familiar with HLG. Once you ETTR, take you footage in HLR and apply this LUT one can start with grading or HLG is not so much suited for this and it is better to use V-Log-L? Also, as HLG doesn't work with VBR, I have read that Cine-D is the way to go when let's say 120fps is in use. Will there be or is there a matching LUT for Cine-D as well? Thanks and cheers. Link to comment Share on other sites More sharing options...
jonpais Posted September 5, 2018 Share Posted September 5, 2018 @mirekti Grading the footage is no problem. A matching LUT for Cine D is included. Link to comment Share on other sites More sharing options...
Dan Sherman Posted September 8, 2018 Share Posted September 8, 2018 On 9/4/2018 at 6:54 AM, jonpais said: This is probably going to be the final beta v801, with the new LUTs being sent out shortly. Skin tones less orange/magenta. Remember, you’ve got to ETTR and set saturation in camera to -5 with the new version. Sample Did you have any issue with green cast with 801? I'm playing with some test footage I shot today to compare 502 vs 801. literally everything was set identically (and I mean everything) other than changing saturation to -5. 801 is darker, but when ever I try and brighten it up, i get a green cast! Link to comment Share on other sites More sharing options...
mirekti Posted September 9, 2018 Share Posted September 9, 2018 I have one question related to external recording to Atomos. In GH HDMI is set to 4k 50/60p, internal recording is set to 4k 23.98. What is the fps rate Atomos is recording? When I import to Davinci it shows 23.98 fps, but not sure if I checked anything and Davinci auto converts or Atomos is really recording in 23.98 fps even though the output is GH settings is set to 50/60p. Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted September 12, 2018 Super Members Share Posted September 12, 2018 I wonder what it will be. C2K, fingers crossed. https://www.43rumors.com/ft4-g9-gh5-gh5s-firmware-update-to-be-announced-at-photokina/ Link to comment Share on other sites More sharing options...
Dan Sherman Posted September 12, 2018 Share Posted September 12, 2018 22 minutes ago, Mattias Burling said: I wonder what it will be. C2K, fingers crossed. https://www.43rumors.com/ft4-g9-gh5-gh5s-firmware-update-to-be-announced-at-photokina/ I'm hoping the GH5 gets the G9's hi resolution mode. matthere 1 Link to comment Share on other sites More sharing options...
anonim Posted September 12, 2018 Share Posted September 12, 2018 Wouldn't it be missed ideal timing opportunity - regarding new BMP4K and more manufacturer's external 10bit solution - if Panasonic technically could, but refuse to implement ProRes Raw codec in both GH5 versions? Link to comment Share on other sites More sharing options...
Dan Sherman Posted September 12, 2018 Share Posted September 12, 2018 34 minutes ago, anonim said: Wouldn't it be missed ideal timing opportunity - regarding new BMP4K and more manufacturer's external 10bit solution - if Panasonic technically could, but refuse to implement ProRes Raw codec in both GH5 versions? Panasonic wouldn't implement ProRes raw, they would implement raw (not the same thing) out over hdmi. If they can/will is most likely a technical discussion not a sales/marketing one. Link to comment Share on other sites More sharing options...
mercer Posted September 12, 2018 Share Posted September 12, 2018 6 hours ago, Mattias Burling said: I wonder what it will be. C2K, fingers crossed. https://www.43rumors.com/ft4-g9-gh5-gh5s-firmware-update-to-be-announced-at-photokina/ I’d love to see 10bit and all-i in the G9... even just in 1080p. But yeah C2K in the GH5 seems like a no brainer. Mattias Burling 1 Link to comment Share on other sites More sharing options...
seanzzxx Posted September 16, 2018 Share Posted September 16, 2018 What's C2K? Link to comment Share on other sites More sharing options...
jonpais Posted September 16, 2018 Share Posted September 16, 2018 DCI 2048 X 1080. Link to comment Share on other sites More sharing options...
seanzzxx Posted September 16, 2018 Share Posted September 16, 2018 Ah, CINEMA 2k, gotcha- thanks! jonpais 1 Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted September 16, 2018 Super Members Share Posted September 16, 2018 According to this test the GH5 looks like it has worse dynamic range than the GH4 in Cine D. It makes sense given the larger pixels. Does anyone know of any other tests on the subject or have the cameras and feel like uploading some files? I've been shooting all weekend with the G85 to determine if I should get the G9, the X-H1 or something else. I could go G9 but getting even lower than the already quite terrible DR isn't very exciting. (I have considered the GH5 wich is way cheaper than the other two, but I need a top LCD. Otherwise I would have just stuck to the G85.) Link to comment Share on other sites More sharing options...
anonim Posted September 16, 2018 Share Posted September 16, 2018 I'm not sure if these works may be useful as tests, but for the case you missed to view them, here they are Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted September 16, 2018 Share Posted September 16, 2018 3 hours ago, Mattias Burling said: According to this test the GH5 looks like it has worse dynamic range than the GH4 in Cine D. It makes sense given the larger pixels. Does anyone know of any other tests on the subject or have the cameras and feel like uploading some files? I've been shooting all weekend with the G85 to determine if I should get the G9, the X-H1 or something else. I could go G9 but getting even lower than the already quite terrible DR isn't very exciting. (I have considered the GH5 wich is way cheaper than the other two, but I need a top LCD. Otherwise I would have just stuck to the G85.) Brother the dude in that test was using extended ISO. This decreases dynamic range. They are the same in CineD otherwise. Vlog and HLG you get at least a stop more. The XH1 has pretty solid dynamic range in Flog and Eterna. Mattias Burling 1 Link to comment Share on other sites More sharing options...
Dan Sherman Posted September 17, 2018 Share Posted September 17, 2018 9 hours ago, Mattias Burling said: According to this test the GH5 looks like it has worse dynamic range than the GH4 in Cine D. It makes sense given the larger pixels. Does anyone know of any other tests on the subject or have the cameras and feel like uploading some files? I've been shooting all weekend with the G85 to determine if I should get the G9, the X-H1 or something else. I could go G9 but getting even lower than the already quite terrible DR isn't very exciting. (I have considered the GH5 wich is way cheaper than the other two, but I need a top LCD. Otherwise I would have just stuck to the G85.) I would not trust some random YouTuber. Dxo has the gh5 at 13 stops! https://www.dxomark.com/panasonic-lumix-dc-gh5-sensor-review-best-performer-in-the-lineup/ Link to comment Share on other sites More sharing options...
webrunner5 Posted September 17, 2018 Share Posted September 17, 2018 51 minutes ago, Dan Sherman said: I would not trust some random YouTuber. Dxo has the gh5 at 13 stops! https://www.dxomark.com/panasonic-lumix-dc-gh5-sensor-review-best-performer-in-the-lineup/ Yeah but that DR is for Photos. For video it is usually 1 stop less, maybe more. Photo mode usually has a higher bit rate. Link to comment Share on other sites More sharing options...
