webrunner5 Posted January 8, 2017 Share Posted January 8, 2017 Colors and detail both look great, well actually too great in a sense. It defiantly looks like a big improvement. I can always make a highly detail shoot look like 8m film, but sure can't do that the other way around! mercer 1 Link to comment Share on other sites More sharing options...
Geoff CB Posted January 8, 2017 Share Posted January 8, 2017 17 hours ago, OliKMIA said: Here is mine. Usual Caveat, I'm not a Pro Colorist. I tried to do something balanced being light on the curve and contrast because I don't like the usual crushed black look. In terms of mood I decided to keep it on the cool side that fit the humid/snowy Seattle scene. Constructive critics and tips are welcome. If I did something wrong, please tell me how to fix it. Thanks Is the shot near the end supposed to be blue? Because if it is, you need calibrate your monitor, it's leaning toward magenta in most of your shots here. So of course I decided to take my own crack at the footage, goal to see how interesting I could make the footage if it was just given to me. Selective sharpening, retiming, and reframing are used. Did not enjoy that low shot so I didn't bother with it. 10-Bit - Very impressed with great range and edit flexibility. 8-Bit - Disappointed, clear banding on skin tones. OliKMIA, a_reynolds and sudopera 3 Link to comment Share on other sites More sharing options...
OliKMIA Posted January 8, 2017 Share Posted January 8, 2017 1 minute ago, Geoff CB said: Is the shot near the end supposed to be blue? Because if it is, you need calibrate your monitor, it's leaning toward magenta in most of your shots here. Thanks for your feedback, as I said I wanted to get a cool mood but I checked on another monitor and I also noticed the Magenta cast. My new monitor needs to be calibrated, I ordered a screen calibration tool (ColorMunki). Should solve this problem. Link to comment Share on other sites More sharing options...
bunk Posted January 8, 2017 Share Posted January 8, 2017 Some more waterfall and snow (boring). Wish someone who is able to open the 10 bit footage was kind enough to share a frame or two, so others who can't open the footage can give it a shot as well. Below one and the same CC + slight adjustment of the blue channel Link to comment Share on other sites More sharing options...
Geoff CB Posted January 8, 2017 Share Posted January 8, 2017 5 minutes ago, bunk said: Some more waterfall and snow (boring). Wish someone who is able to open the 10 bit footage was kind enough to share a frame or two, so others who can't open the footage can give it a shot as well. Drop the footage in media encoder and convert them to Cineform or DNxHR mercer 1 Link to comment Share on other sites More sharing options...
mercer Posted January 8, 2017 Share Posted January 8, 2017 Yeah I had to transcode and downscale to 1080p Prores. It was a quick conversion with EditReady. webrunner5 1 Link to comment Share on other sites More sharing options...
Axel Posted January 8, 2017 Share Posted January 8, 2017 2 hours ago, JazzBox said: Do you know where I can legally find El Capitan? Thank you and excuse me for bothering you! Found it easily on german appstore. You have to read this and scroll down, then you will be relocated to your local appstore. JazzBox 1 Link to comment Share on other sites More sharing options...
anti12 Posted January 8, 2017 Share Posted January 8, 2017 Strong grades reveal sharpening halos in @Neumanns footage. Link to comment Share on other sites More sharing options...
JazzBox Posted January 8, 2017 Share Posted January 8, 2017 1 hour ago, Axel said: Found it easily on german appstore. You have to read this and scroll down, then you will be relocated to your local appstore. Thank you! Link to comment Share on other sites More sharing options...
bunk Posted January 9, 2017 Share Posted January 9, 2017 3 hours ago, Geoff CB said: Drop the footage in media encoder and convert them to Cineform or DNxHR 3 hours ago, mercer said: Yeah I had to transcode and downscale to 1080p Prores. It was a quick conversion with EditReady. Now that was a great tip. It actually works ....and no need to downscale. Same CC as above slightly adjusted levels. Same... same CC + slightly over the top color grade. Same color grade node applied to seattle... I'm really impressed by the internal 10 bit Vlog. It can only mean that Cine D will be great. What stands out the most for me is the beautifull grain, almost BM-like. Gone are the days of fluffy grain clouds dancing all over the place ...at least if this is an indication. mercer 1 Link to comment Share on other sites More sharing options...
Neumann Films Posted January 9, 2017 Author Share Posted January 9, 2017 I think the key thing to take away from this is...stay away from skin tones in 60/180fps and it is a very useful tool. If you NEED skin tones...try and light the face evenly to remove shadows/gradients. Hell, a reflector would even work well. You basically want to stay away from needing to do TOO much on the face. I would honestly just opt out of shooting in V-Log if I were going to do a bunch of 60p stuff. Shoot in Standard and get it right in camera...don't touch the grade except for maybe denoising/adding film grain. V-Log requires grade, enough grade that you basically have to incinerate the 8bit image to get 90% of what you would with just a standard profile. In the end, once you have enough time with the camera...you will know what works and what doesn't. Got some 180fps content ready to upload. We just tried to capture as many different scenarios as possible. Interiors with good lighting and ISO at 400, exteriors with no lighting at 400, interiors with only practical lights at ISO 800 and ISO 1600. I think it will show when/where/how to use 180fps and what you can do to avoid the pitfalls of 8bit. Much of what all of you have seen with 60 but multiplied. Link to comment Share on other sites More sharing options...
aldolega Posted January 9, 2017 Share Posted January 9, 2017 So it would basically be the same rule it seems most have adopted for the GH4- stick to normal gammas with 8-bit (in-camera), and use 10-bit for V-Log (i.e. add a recorder). Just with the GH5, going to 10-bit is only a matter of switching a couple settings, instead of dragging out the recorder, and the SSD's, and the HDMI cable, and the rigging... Sounds like I will just be setting one of the custom modes on the dial to 4K60p with Cinelike D at Leeming LUT settings, and another to 4K30 with V-Log and the preview LUT. Should be pretty simple to switch between them. As someone who shoots a lot of motion, the only things I'm worried about are the possibility of ghosting from temporal NR, and the haloing that @anti12 just posted is worrisome too. It seems like with every GH release the engineers do their best to deliver the most nail-bitingly-sharpened-and-processed image they can, and we all spend the first month or two with the camera just trying to dial that out of the picture. It would be really nice if, right off the bat, we could have the option to not just turn down, but turn off the extra processing and NR, instead of waiting/hoping for a firmware update that lets us do so. Neumann Films 1 Link to comment Share on other sites More sharing options...
Neumann Films Posted January 9, 2017 Author Share Posted January 9, 2017 58 minutes ago, aldolega said: So it would basically be the same rule it seems most have adopted for the GH4- stick to normal gammas with 8-bit (in-camera), and use 10-bit for V-Log (i.e. add a recorder). Just with the GH5, going to 10-bit is only a matter of switching a couple settings, instead of dragging out the recorder, and the SSD's, and the HDMI cable, and the rigging... Sounds like I will just be setting one of the custom modes on the dial to 4K60p with Cinelike D at Leeming LUT settings, and another to 4K30 with V-Log and the preview LUT. Should be pretty simple to switch between them. As someone who shoots a lot of motion, the only things I'm worried about are the possibility of ghosting from temporal NR, and the haloing that @anti12 just posted is worrisome too. It seems like with every GH release the engineers do their best to deliver the most nail-bitingly-sharpened-and-processed image they can, and we all spend the first month or two with the camera just trying to dial that out of the picture. It would be really nice if, right off the bat, we could have the option to not just turn down, but turn off the extra processing and NR, instead of waiting/hoping for a firmware update that lets us do so. Exactly! I think that would be a wise course of action. Panasonic just gave us a firmware update and now Sharpness/Noise Reduction are available as options for V-LogL. In the footage we uploaded (that people have been grading), the settings were at defaults of 0 and 0. So turning those down to -5 each should produce better results as far as that is concerned. Link to comment Share on other sites More sharing options...
aldolega Posted January 9, 2017 Share Posted January 9, 2017 Good to hear, Luke. Were Sharpness and NR adjustable on the normal gammas when you shot the piece? Or were they locked at 0 too? I recall one of the Panasonic reps saying, in one of the dozen interviews I've watched, that the new image processing/sharpening cannot be totally turned off, just down. If that's true I really hope that on the production cam, turning down to -5 on both will get rid of the haloing and temporal artifacts. Link to comment Share on other sites More sharing options...
Matt Holder Posted January 9, 2017 Share Posted January 9, 2017 Shallow depth of field was a winner with 96fps on the GH4 - it seems like the lack of required sharp detail encoding allowed the sub optimal bit rate to be good enough - plus its softness was good for skin / faces. I used this all the time for handheld dollies / close up product detail shots at 12mm / f2.8 Panny is 25-35 or 25/ F .095 and never got called out for image softness by any of my clients. Philip Bloom had a great shot in slomo of a young girls face close up with the GH4 / 25 voigtlander combo that he used in his CNN series. Its one of my favourite shots of his ever. I suspect the same approach will work wonders with the 180 fps mode. Neumann Films 1 Link to comment Share on other sites More sharing options...
Neumann Films Posted January 9, 2017 Author Share Posted January 9, 2017 48 minutes ago, Matt Holder said: Shallow depth of field was a winner with 96fps on the GH4 - it seems like the lack of required sharp detail encoding allowed the sub optimal bit rate to be good enough - plus its softness was good for skin / faces. I used this all the time for handheld dollies / close up product detail shots at 12mm / f2.8 Panny is 25-35 or 25/ F .095 and never got called out for image softness by any of my clients. Philip Bloom had a great shot in slomo of a young girls face close up with the GH4 / 25 voigtlander combo that he used in his CNN series. Its one of my favourite shots of his ever. I suspect the same approach will work wonders with the 180 fps mode. Yup, in 180 shots so far best results are with Sigma Art 24 set to f 1.4. Below shot with way more grading than the codec can handle obviously, but held up just as well as 4K/60 IMO. Link to comment Share on other sites More sharing options...
bunk Posted January 9, 2017 Share Posted January 9, 2017 @ Luke neumann. Could you do us a favor and shoot some cineD 30fps (all settings at zero, if possible NR -5) in 10 bit. Your face or your wifes face, nothing fancy something really simple like a snapshot. thanks! Link to comment Share on other sites More sharing options...
Ronnie Amighetti Posted January 9, 2017 Share Posted January 9, 2017 Had to test the files out, couldn't resist. Well, without transcoding my iMac 5K almost dies with just one single clip. FCPX 10.2.3 I throw a VLog to REC709 LUT and played with it a bit. FilmConvert plays funny with colors. Guess we'll have to wait for a proper GH5 profile. a_reynolds 1 Link to comment Share on other sites More sharing options...
Ronnie Amighetti Posted January 9, 2017 Share Posted January 9, 2017 BTW, FCPX has no problem with all 5 clips, MPEG Streamclip couldn't recognize them, Davinci only works with the 60p clips. Link to comment Share on other sites More sharing options...
JazzBox Posted January 9, 2017 Share Posted January 9, 2017 3 hours ago, Ronnie Amighetti said: BTW, FCPX has no problem with all 5 clips, MPEG Streamclip couldn't recognize them, Davinci only works with the 60p clips. Nick Driftwood suggested me to buy "Movist" to preview the clips, since I am not able to download El Capitan from italian AppStore. I'll give it a try. Link to comment Share on other sites More sharing options...
