Simon Shasha Posted January 9, 2017 Share Posted January 9, 2017 I'm not sure if I heard correctly, but it seems as though, according to this interview (below), IBIS in the GH5 is only available when using Panasonic lenses? I thought that perhaps he means only "DUAL IS" is available when using Panasonic lenses, however, the interviewer does not clarify, so I'm unsure...) Luke, if you're out there, could you shed some light on this? Link to comment Share on other sites More sharing options...
mechanicalEYE Posted January 9, 2017 Share Posted January 9, 2017 He means Dual IS, the IBIS has been confirmed to work with non lumix brand lenses. Luke has stated that he's used a Sigma lens on the GH5. webrunner5, jonpais, Emanuel and 2 others 5 Link to comment Share on other sites More sharing options...
Simon Shasha Posted January 10, 2017 Author Share Posted January 10, 2017 I thought as much. Next thing is to find out if a Sigma 18-35mm F1.8 + 0.71x Metabones Speed Booster will vignette on GH5 - given that there's no crop-factor in 4K like GH4. Emanuel 1 Link to comment Share on other sites More sharing options...
Jimmy Posted January 10, 2017 Share Posted January 10, 2017 5 minutes ago, Simon Shasha said: Sigma 18-35mm F1.8 That's some lens... Does anyone know if AF works with these non Lumix lenses (with an electronic mount)? Emanuel 1 Link to comment Share on other sites More sharing options...
noone Posted January 10, 2017 Share Posted January 10, 2017 12 hours ago, Jimmy said: That's some lens... Does anyone know if AF works with these non Lumix lenses (with an electronic mount)? It should if it is a Canon mount lens and you use either a Metabones smart adapter (focal reducer or non focal reducer) or Kipon (non focal reducer only). That is it should at least work for AF for stills. Video will need someone to try the lens with the various adapters. Emanuel 1 Link to comment Share on other sites More sharing options...
