Would in body image stabilization properly work with an anamorphic?
Flynn
30 minutes ago, valery akos said:
this problem occurs only with G80/G85... It's Pana's stabilazer that creates the problem....
I think NO.
It's makes no sense.
The G80 stabilizer works superb!
Whatever stabilizer that rotate the sensor behind a fixed anamorphic adapter will make the alignement changing, that result on "whoobling image".
Grimor, thank you very much for your input! Very good to know. The footage looks like warp stabilizer... I was tempted to buy GH5 because of IBIS. But now I will rethink because I'd use it only for video with anamorphics.
The GH4 with Lumix 35-100 F2.8 and Isco 36 seem to work well together. So I think the mesmerizer effect is only with IBIS...
IBIS is a great improvement. But not usefull for anamorphic shooter.
@Rudolf you are right about its like a warp stabilizer or youtube "auto stabilize" weird correction.
If panasonic people can make a mode with only vertical stabilization (like the one in panoramic photo)  would be great for our scopes.
Great idea. Panasonic... Listen to that man! :)
