Ursa mini 4.6k - Yamaha Grizzly ATV in slomo
kgv5
Hi, couple days ago just for fun i shot this awesome yamaha grizzly ATV, ursa mini 4.6K in raw 3:1, 4.6k 50/60fps and 2k 120fps. I used canon 16-35 f2.8 L II and canon 70-200 f2.8 II IS lenses. I recorded everything to ssd drive via cfast to sata breakout cable. 70-200 shots are handheld, for 16-35 i used glidecam devin graham signature series. Graded in resolve 12.5, edited in premiere CC.
:) Most of the video was shot with 2k sensor crop (for 120fps) and 70-200 lens - so happily i could be far enough not to be covered by tons of snow shooting up when he drifts :) But there was some snow and moisture on the ursa (during glidecam 60fps 4.6k wide shots) and some freezing temperatures - the camera did very well despite of that :) (and it wasnt covered at all).
  On 2/23/2017 at 7:20 PM, Riadnasla said:
Really cool! If you're using 200mm, are you on a tripod at that point, or just really good optical stabilization?
Expand
Thanks, no tripod, all handheld. IS of canon 70-200 is really great.
  On 2/23/2017 at 9:14 PM, Ehetyz said:
I see a lot of magenta areas in the wider shots. Are those in-camera?
Expand
Maybe because for the wide shots i used cokin resin grad filter which is not very high quality and doesnt block IR, today i recieved formatt-hitech firecrest grad so i hope it will be better.
