Why won't autofocus work w/ a lens listed as "Through Focus"?
Flynn
Thanks. I was just thinking any lens listed as "Through Focus" on Tito's chart, autofocus should work. But then I figured there must be a reason it doesn't work, cause people are always saying you can't use autofocus with an adapter.
I believe it depends on the af system mostly. The A6500 and the canons dual pixel af can do a pretty good job nowdays, so if it worked with the Moller, we should ask our fellow forumers to test out the foucus through lens.
