Tim Sewell Posted March 2, 2017 Share Posted March 2, 2017 So I'm looking to build a couple of home-made butterfly frames and silks and I'm balking at paying hundreds of pounds for the fabric just because it comes from a grip supplies company. I'm sure it must be available from a standard fabric shop for much less - but I haven't been able to find out exactly what sort/weight of silk (or more likely rayon) I should look for. Does the EOSHD hive mind have any pointers please? Link to comment Share on other sites More sharing options...
Michael Coffee Posted March 2, 2017 Share Posted March 2, 2017 I've heard good things about Ikea shower curtains! Geoff CB 1 Link to comment Share on other sites More sharing options...
hijodeibn Posted March 2, 2017 Share Posted March 2, 2017 Film riot showed a DIY betterfly frame some time ago, probably you can do something similar using the Ikea shower curtains....if you do please share your results later, I am also interested in something similar.... Dan Wake 1 Link to comment Share on other sites More sharing options...
Tim Sewell Posted March 2, 2017 Author Share Posted March 2, 2017 The saga so far has seen me order 3 different fabrics. A white ripstop parachute nylon (suggested by the estimable Phil Rhodes), a classic sailcloth and some 'bridal' tulle. Picked up a length of muslin while I was there! Frame-wise I was pricing stuff up and it works out that just buying a couple of Manfrotto Lastolite 2mx2m frames will be cheaper than trying to build my own. I'll keep the board posted as to my progress. PannySVHS 1 Link to comment Share on other sites More sharing options...
Parker Posted March 2, 2017 Share Posted March 2, 2017 Just gonna leave this here, I saw this video earlier today and it seems relevant: http://www.diyphotography.net/make-ultra-lightweight-giant-scrims-diffusion-gels/ zerocool22 1 Link to comment Share on other sites More sharing options...
Tim Sewell Posted March 7, 2017 Author Share Posted March 7, 2017 A progress report: The Lastolite 2m square frame arrived. Gosh! 2m is actually quite big, isn't it! Anyway - the fabric samples also arrived and to my eye there are 3 types worth pursuing. The bridal tulle will, I think, work very well for diffusing daylight with very little loss of luminance. The ripstop parachute nylon looks like an excellent choice to diffuse a lighting instrument (I have a 2.5k tungsten fixture I picked up on eBay arriving soon) and, lastly, plain old white muslin looks like a good in-between choice (and obviously makes for an excellent bounce as well). So I now just have to find these fabrics in 2m wide rolls and order sufficient to make the panels - I'm thinking iron-on velcro will be the best (and easiest) solution for fixing to the frame. Link to comment Share on other sites More sharing options...
noone Posted March 8, 2017 Share Posted March 8, 2017 Maybe visit charity clothing shops and see if there are any old large bridal gowns being put into rags out the back? Link to comment Share on other sites More sharing options...
Tim Sewell Posted March 9, 2017 Author Share Posted March 9, 2017 8 hours ago, noone said: Maybe visit charity clothing shops and see if there are any old large bridal gowns being put into rags out the back? To be honest, fabric bought from generic suppliers is so cheap it wouldn't make any sense to spend the time (although Hove, where I live, is the charity shop Mecca of Sussex!). Link to comment Share on other sites More sharing options...
tupp Posted March 9, 2017 Share Posted March 9, 2017 If you frequently will be shooting outdoors, you might consider using rags that breathe, as ripstop nylon and sail cloth can turn your "6-by" (2mx2m frame) into a powerful sail/kite. When I used to build frames out of PVC, I would mostly use cheap, white bed sheets as a silk. Also, it might be good to use "grommets and ties" to attach the rags to the frame, as they are secure and easy to use, and they can be readily adapted to fly the rags in other ways, without the frame. kaylee 1 Link to comment Share on other sites More sharing options...
Tim Sewell Posted March 9, 2017 Author Share Posted March 9, 2017 Good points, @tupp - thanks. Link to comment Share on other sites More sharing options...
kaylee Posted March 9, 2017 Share Posted March 9, 2017 1 hour ago, tupp said: a powerful sail/kite ? the first one i made flew away Tim Sewell 1 Link to comment Share on other sites More sharing options...
