texcam Posted February 13, 2012 Share Posted February 13, 2012 I want to create a DIY adjustable ND filter by stacking a Marumi DHG Super Circular Polarizer and a linear polarizer on an 58-77 adapter. Will this cause vignetting on this lense? Anyone tried this? Link to comment Share on other sites More sharing options...
Francisco Rios Posted February 14, 2012 Share Posted February 14, 2012 Hi Texcam, I have the 12 mm slr magic. I use a 58-72 mm adapter for a Variable ND. It's ok, but I can't stack any other plus filter because it "vignentts". It works only with one filter on it on a 72mm adapter. If you want to stack your DIY variable ND, at least you will need a 77 mm adapter. Hope it helps. Cheers... Link to comment Share on other sites More sharing options...
