IKSLIM Posted March 8, 2017 Share Posted March 8, 2017 Drew Veeneman, Marco Tecno, lucabutera and 2 others 5 Link to comment Share on other sites More sharing options...
Kisaha Posted March 8, 2017 Share Posted March 8, 2017 Very original presentation, very good job! Do you use any kind of lighting in the interviews? What settings are you using? I like the quality very much, it is a very clean look. I was also considering this USB device (10:02) for video editing use! Seems nice. Link to comment Share on other sites More sharing options...
Drew Veeneman Posted March 9, 2017 Share Posted March 9, 2017 Nice. 120 fps is perfect for this. Link to comment Share on other sites More sharing options...
IKSLIM Posted March 13, 2017 Author Share Posted March 13, 2017 On 3/8/2017 at 9:24 PM, Kisaha said: Do you use any kind of lighting in the interviews? What settings are you using? I like the quality very much, it is a very clean look. Settings are almost by default, the only DR profile is active, WB auto, sharp, contrast, etc.. by default. NX1 is a real pleasure to work with picture-wise. the light is inexpensive Amoran led. Kisaha and keessie65 2 Link to comment Share on other sites More sharing options...
SMGJohn Posted March 15, 2017 Share Posted March 15, 2017 I suggest to get the most out of the NX1 is to put negative 10 on sharpness, lower contrasts a little by negative 2 and increase Colour saturation by 2 and then use any of the picture profiles cause they are gorgeous even the normal one outputs sexy colours, just decrease the green by 0.95 or 0.90 whatever you feel is best, do it for all the picture profiles as all the NX cameras are green biased. Nice work otherwise, I guess I should not voice my opinions too loud because I have not even edited together all those footages I have shot over the year I guess I must get to it. sandro 1 Link to comment Share on other sites More sharing options...
IKSLIM Posted March 25, 2017 Author Share Posted March 25, 2017 Comrades! How to edit original post (topic starter)? I've updated referenced video clip, and about to correct the link. Simply can not see a button "edit the post". I appreciate your comment New version is there: Link to comment Share on other sites More sharing options...
IKSLIM Posted March 26, 2017 Author Share Posted March 26, 2017 Looks like "Edit" button is active for some time, but later does not. Am i correct? Is there an option to edit the post? Link to comment Share on other sites More sharing options...
