P13 Posted May 1, 2013 Share Posted May 1, 2013 I've been using the SLR Magic 25mm for what will have been several hours of live recordings now over a number of weeks, I used to use the Cosina Voigtlander 25mm before with a focus gear. I’m finding the SLR Magic to be a delight, having the in-built lens gear means no slipping as I’d have occasionally with the Voigtlander and the sharpness really appeals to me. Anyway here’s a couple of examples of the 25mm in use: http://vimeo.com/62111836 This I did on Saturday with the 12mm also in use side of the stage. http://vimeo.com/65099742 Link to comment Share on other sites More sharing options...
voyagervideo Posted May 2, 2013 Share Posted May 2, 2013 Have to say, I recieved the 25mm last week and it's great. No issues with aperture ring (so far!). One tip: they want to charge you $50-$80 for the step up ring, the built-in lens hood has a 55mm thread, get a $5 step up ring for that to attach filters. Wouldn't put a clamp-on matte box on it, but it works fine for round filters. Link to comment Share on other sites More sharing options...
andrgl Posted May 3, 2013 Share Posted May 3, 2013 Have to say, I recieved the 25mm last week and it's great. No issues with aperture ring (so far!). One tip: they want to charge you $50-$80 for the step up ring, the built-in lens hood has a 55mm thread, get a $5 step up ring for that to attach filters. Wouldn't put a clamp-on matte box on it, but it works fine for round filters. Awesome! Thank you for saving me money. Link to comment Share on other sites More sharing options...
P13 Posted May 3, 2013 Share Posted May 3, 2013 Have to say, I recieved the 25mm last week and it's great. No issues with aperture ring (so far!). One tip: they want to charge you $50-$80 for the step up ring, the built-in lens hood has a 55mm thread, get a $5 step up ring for that to attach filters. Wouldn't put a clamp-on matte box on it, but it works fine for round filters. It's not that simple, a normal step up alone will block the focus movement so you can't focus to infinity. It's discussed here (there is an alternative solution using a coupler first): http://www.personal-view.com/talks/discussion/5908/25mm-f0.95-slrmagic-topic/p6 Link to comment Share on other sites More sharing options...
voyagervideo Posted May 4, 2013 Share Posted May 4, 2013 It's not that simple, a normal step up alone will block the focus movement so you can't focus to infinity. It's discussed here (there is an alternative solution using a coupler first): http://www.personal-view.com/talks/discussion/5908/25mm-f0.95-slrmagic-topic/p6 That is if you are using the 49mm filter thread, the lens hood itself has a filter thread as well and it's 55mm. If you can deal with the fact that it rotates then it's a much cheaper solution to attach filters to the lens hood (my 55mm to 77mm cost $5). Of course this can be a little tricky with gradual ND filters, but as long as you keep the lens hood extended, there will be no problem with focusing to infinity. And ofcourse I wouldn't put a clamp-on matte box on the lens hood. Link to comment Share on other sites More sharing options...
andrgl Posted May 4, 2013 Share Posted May 4, 2013 Thanks for the discussion P13 and voyagervideo. I figured getting the step up would be best in the long run, resale value, put my order in a few hours ago. $50 for a piece of threaded metal. Ahaha. :( Link to comment Share on other sites More sharing options...
P13 Posted May 4, 2013 Share Posted May 4, 2013 That is if you are using the 49mm filter thread, the lens hood itself has a filter thread as well and it's 55mm. If you can deal with the fact that it rotates then it's a much cheaper solution to attach filters to the lens hood (my 55mm to 77mm cost $5). Of course this can be a little tricky with gradual ND filters, but as long as you keep the lens hood extended, there will be no problem with focusing to infinity. And ofcourse I wouldn't put a clamp-on matte box on the lens hood. I'm not 100% sure that's the best solution but I see what you're saying. Link to comment Share on other sites More sharing options...
voyagervideo Posted May 4, 2013 Share Posted May 4, 2013 I'm not 100% sure that's the best solution but I see what you're saying. The best solution is to buy the $50 ($80 if you buy it separately) proprietary lens hood, but a $5 55-77mm step up makes the same difference for all intents and purposes, you just have to be mindful of the fact that the lens hood is not fixed in place. Link to comment Share on other sites More sharing options...
