Matthew Robert Mahaffey Posted March 19, 2017 Share Posted March 19, 2017 Is this good?? I'm deciding if I want a lens turbo ii or this. https://www.amazon.com/VILTROX-EF-E-Auto-focus-Adapter-Metabones/dp/B015OJ3R9M/ref=s9_simh_gw_g421_i1_r?_encoding=UTF8&fpl=fresh&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=&pf_rd_r=1HFW30NAGNWK3QF517ZK&pf_rd_t=36701&pf_rd_p=1cded295-23b4-40b1-8da6-7c1c9eb81d33&pf_rd_i=desktop Its a smart adapter and from the very minimal things on youtube it looks good to me. I only want the smart features so I can adjust aperture and have IS with my canon lenses. Link to comment Share on other sites More sharing options...
webrunner5 Posted March 19, 2017 Share Posted March 19, 2017 Well it's not that they don't work, it is that they work with compromises. They don't work with all lenses, the quality of the glass in the unit is not as high of standard as Metabones, on and on. If you can live with those well sure it is a cheap out. I admit Metabones is, in this day and age, probably ripping us off total cost wise. But I have never seen a cheaper one as good as a Metabones, and I doubt we ever will. Bottom line, output will not look as good. And since most people are using a video camera that does not have a top output to start with, well you get my point. But we can't have the best of everything, so we Have to cut corners, and maybe you are right, this is one way to do that. Decisions, decisions. Oh, and when I see a Amazon rating of 3.6, yeah 3.6! I MIGHT want to look elsewhere. They might know what I expect, Not So Good. Link to comment Share on other sites More sharing options...
Justin Bacle Posted March 20, 2017 Share Posted March 20, 2017 I think the lens turbo 2 (from Mitakon) is a better optical quality, but of course, you loose the electronic connections. There are some used metabones if you want the electrical connection but don't have the budget for a new one Link to comment Share on other sites More sharing options...
Deadcode Posted March 20, 2017 Share Posted March 20, 2017 I 'm using this Viltrox speedbooster with A6300 and with Canon 24-105 F4 IS USM, 50 1.4, 70-200 F4, 17-40 F4 The good: Image stabilisation works perfectly, aperture change from the body works perfectly, FOV is almost fullframe, i have infinity focus even with the 50 1.4. Fairly usable AF with 24-105, 70-200 and 17-40 in photo mode. The bad: dark extreme corners in photo mode (in video mode it's cropped out due to 16:9 sensor crop). AF cant lock with 50 1.4. Very rarely the adapter cant recognise the lens (on/off solves it). In video mode none of the lenses above can lock focus, just hunting. For the price the adapter is awesome, works really well with canon lenses (if you used to film in manual) and working IS! If you want to take pictures you can use AF with some of the lenses with a little corner shading. In conclusion i recommend this adapter, and i really like it. Link to comment Share on other sites More sharing options...
Matthew Robert Mahaffey Posted March 25, 2017 Author Share Posted March 25, 2017 On 3/20/2017 at 5:33 AM, Deadcode said: I 'm using this Viltrox speedbooster with A6300 and with Canon 24-105 F4 IS USM, 50 1.4, 70-200 F4, 17-40 F4 The good: Image stabilisation works perfectly, aperture change from the body works perfectly, FOV is almost fullframe, i have infinity focus even with the 50 1.4. Fairly usable AF with 24-105, 70-200 and 17-40 in photo mode. The bad: dark extreme corners in photo mode (in video mode it's cropped out due to 16:9 sensor crop). AF cant lock with 50 1.4. Very rarely the adapter cant recognise the lens (on/off solves it). In video mode none of the lenses above can lock focus, just hunting. For the price the adapter is awesome, works really well with canon lenses (if you used to film in manual) and working IS! If you want to take pictures you can use AF with some of the lenses with a little corner shading. In conclusion i recommend this adapter, and i really like it. How much does it degrade the video quality if at all? are highlights blown? Shadows worse? Sharpness degraded? Link to comment Share on other sites More sharing options...
Deadcode Posted March 26, 2017 Share Posted March 26, 2017 I think it does not degrade video quailty with consumer level gear. With every booster the sharpness is better with booster compared to normal adapter with the same lens. I dont understand what you mean with highlights/shadows, it's inappropiate question, this is not a 10$ plastic adaptert. You can see a comparison here where i tested the 5D2 + 50mm F1.4@1.4 vs A6300 + boosted 50 F1.4@1.0 webrunner5 1 Link to comment Share on other sites More sharing options...
noone Posted March 26, 2017 Share Posted March 26, 2017 On 19/03/2017 at 11:24 AM, Matthew Robert Mahaffey said: Is this good?? I'm deciding if I want a lens turbo ii or this. https://www.amazon.com/VILTROX-EF-E-Auto-focus-Adapter-Metabones/dp/B015OJ3R9M/ref=s9_simh_gw_g421_i1_r?_encoding=UTF8&fpl=fresh&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=&pf_rd_r=1HFW30NAGNWK3QF517ZK&pf_rd_t=36701&pf_rd_p=1cded295-23b4-40b1-8da6-7c1c9eb81d33&pf_rd_i=desktop Its a smart adapter and from the very minimal things on youtube it looks good to me. I only want the smart features so I can adjust aperture and have IS with my canon lenses. You still want the focal reduction? If not and it is ONLY the smart adapter functions, there are a gazillion different smart adapters for EF to E mount that don't have glass at all and so just use the lens as is and IS works great. AF is going to be slow with most cameras and effectively AFS only with just about all. Some combinations will not work for AF and some third party lenses might have problems as well with some combinations (from my experience with an A7 and A7s and four different adapters from cheap to a MB). Some EF to E smart adapters are less than $100. I have a Lens Turbo for EF to M4/3 and while it has its uses with some Canon lenses for the most part it is for third party lenses with mechanical aperture and focus. Link to comment Share on other sites More sharing options...
lmackreath Posted November 14, 2017 Share Posted November 14, 2017 Anyone try this adapter on a gh5? Link to comment Share on other sites More sharing options...
ntblowz Posted November 14, 2017 Share Posted November 14, 2017 This only works for Sony Alpha and not FS cameras, I tried and doesn't work, only metabones works on FS5/FS7 Link to comment Share on other sites More sharing options...
lmackreath Posted November 15, 2017 Share Posted November 15, 2017 12 hours ago, ntblowz said: This only works for Sony Alpha and not FS cameras, I tried and doesn't work, only metabones works on FS5/FS7 do not know what you mean? I am talking about the panasonic gh5 Link to comment Share on other sites More sharing options...
Timotheus Posted November 15, 2017 Share Posted November 15, 2017 21 hours ago, lmackreath said: Anyone try this adapter on a gh5? I just bought the EF-MFT version without focal reducer to use my Sigma 18-35 on my G7...will try and report back when I get it. The speedbooster version is coming soon, from what I understand. Compare versions here and here. Link to comment Share on other sites More sharing options...
tgcallaway Posted December 26, 2017 Share Posted December 26, 2017 On 11/14/2017 at 5:06 AM, lmackreath said: Anyone try this adapter on a gh5? IronFilm and Cinegain 1 1 Link to comment Share on other sites More sharing options...
