Emanuel Posted April 10, 2017 Share Posted April 10, 2017 5 minutes ago, Orangenz said: 4992x3744. I don't think I'm going to test the overheating thing. And it doesn't say a warning will pop up, it just says on the pre-burst screen that it will stop preburst recording and default to burst mode. It says nothing on the start/stop mode. 4992 tops wide, no matter the ratio? Just curious on the extra potential use of it as far as extension of a possible shot concerns. Link to comment Share on other sites More sharing options...
Orangenz Posted April 10, 2017 Author Share Posted April 10, 2017 13 minutes ago, Emanuel said: 4992 tops wide, no matter the ratio? Just curious on the extra potential use of it as far as extension of a possible shot concerns. Oh, the other one is 5184x3456 4992 x 3744 in 4:3 5184 x 3456 in 3:2 Incidentally, 4k and c4k at 24fps have the same lateral field of view. C4k does not get a wider fov like it does on the GH4. 4096 x 2160 in C4K 3840 x 2160 in UHD Link to comment Share on other sites More sharing options...
Emanuel Posted April 10, 2017 Share Posted April 10, 2017 12 minutes ago, Orangenz said: Oh, the other one is 5184x3456 4992 x 3744 in 4:3 5184 x 3456 in 3:2 5184 x 1.33 (anamorphic adapter) = 6894,72 (2:1) actually 7K 5184 x 1.5 (anamorphic adapter) = 7776 (2.25:1) 4992 x 2 (anamorphic adapter or lens) = 9984 (2.66:1) that is 8970,58 (2.39:1) actually 9K Pretty interesting if you want a grab printed from a large format printer... BTW, is there any sort of AF going along the 6K photo mode? (I guess they've named it like that because of its usage on anamorphic video) Link to comment Share on other sites More sharing options...
webrunner5 Posted April 10, 2017 Share Posted April 10, 2017 12 minutes ago, Emanuel said: BTW, is there any sort of AF going along the 6K photo mode? Down at the last paragraph under "First Impressions". Seems like it does AF. http://www.photoreview.com.au/reviews/advanced-compact-cameras/interchangeable-lens/first-look-panasonic-lumix-dc-gh5 Emanuel 1 Link to comment Share on other sites More sharing options...
Orangenz Posted April 10, 2017 Author Share Posted April 10, 2017 22 minutes ago, Emanuel said: BTW, is there any sort of AF going along the 6K photo mode? (I guess they've named it like that because of its usage on anamorphic video) Ermm, I think AFF would be off and the point focus (edit: but just when using pre-burst). Rest works. Was using AFC for it before. It is a photo mode after all. Emanuel 1 Link to comment Share on other sites More sharing options...
Emanuel Posted April 10, 2017 Share Posted April 10, 2017 1 minute ago, Orangenz said: Ermm, I think AFF would be off and the point focus. Rest works. Was using AFC for it before. It is a photo mode after all. Touch to focus on the screen? Link to comment Share on other sites More sharing options...
Orangenz Posted April 10, 2017 Author Share Posted April 10, 2017 3 minutes ago, Emanuel said: Touch to focus on the screen? If you're not using the pre-burst 6k mode then every focus mode works. Link to comment Share on other sites More sharing options...
Emanuel Posted April 10, 2017 Share Posted April 10, 2017 3 minutes ago, Orangenz said: If you're not using the pre-burst 6k mode then every focus mode works. 6K Photo mode seems rather interesting for video acquisition. The only information I am wondering about on the subject matter is how long 6K Photo mode (in both resolutions 4992 x 3744 in 4:3; 5184 x 3456 in 3:2) takes and how many seconds or minutes... Link to comment Share on other sites More sharing options...
Orangenz Posted April 10, 2017 Author Share Posted April 10, 2017 Just now, Emanuel said: 6K Photo mode seems rather interesting for video acquisition. The only information I am wondering about on the subject matter is how long does 6K Photo mode (in both resolutions 4992 x 3744 in 4:3; 5184 x 3456 in 3:2) take and how many seconds or minutes... The manual suggests over 3 hours non-stop. Have you tested the file? Doesn't play natively in Premiere without recoding. Emanuel 1 Link to comment Share on other sites More sharing options...
Emanuel Posted April 10, 2017 Share Posted April 10, 2017 7 minutes ago, Orangenz said: The manual suggests over 3 hours non-stop. Have you tested the file? Doesn't play natively in Premiere without recoding. I didn't, I am not at home, I am with limited internet from here : ) 3 hours? WOW. And doesn't it overheat before to reach that? Some other helpful information I guess easy to confirm: 6K Photo mode works with electronic shutter, right? So, no wearing trouble later in the camera using 6K Photo mode, I guess. No shutter worn out in a few takes, I believe. And what about silent mode and that video I posted up there before? Have you checked any hassle out of it? Link to comment Share on other sites More sharing options...
Orangenz Posted April 10, 2017 Author Share Posted April 10, 2017 2 minutes ago, Emanuel said: I didn't, I am not at home, I am with limited internet from here : ) 3 hours? WOW. And doesn't it overheat before to reach that? Some other helpful information I guess easy to confirm: 6K Photo mode works with electronic shutter, right? So, no wearing trouble later in the camera using 6K Photo mode, I guess. And what about silent mode and that video I posted up there before? Have you checked any hassle out of it? I don't think overheating will be the limiting factor in recording. Yea electronic shutter with that fancy rolling shutter correction if you want to pull a photo. You mean the strobing from fluros? That's with any camera. I have not played around with the flicker decrease function yet. But I did find a fluro in my house that is horrrendous. Link to comment Share on other sites More sharing options...
Emanuel Posted April 10, 2017 Share Posted April 10, 2017 27 minutes ago, Orangenz said: I don't think overheating will be the limiting factor in recording. Yea electronic shutter with that fancy rolling shutter correction if you want to pull a photo. You mean the strobing from fluros? That's with any camera. I have not played around with the flicker decrease function yet. But I did find a fluro in my house that is horrrendous. Well, I bet we can minimize the issue with the right shutter speed anyway. Nice news on the overheating. That said, no idea why they don't call it a 5K video camera, after all... This camera puzzles me each day more; I think she is completely underrated... I find it even worse because it is by Panasonic marketing reps almost all them included, they should be the first ones to announce it to the world and this AF buzz episode only confirms my impression... Reason enough for them to clean the house, they do too little for this product... Joseph is a photographer, not a Panasonic rep; old dvxuser is also gone today with Jarred on RED; it is a shame I know all this information coming from another user on EOSHD (Andrew's brand agnostic corner or not!) Link to comment Share on other sites More sharing options...
tomsemiterrific Posted April 10, 2017 Share Posted April 10, 2017 On 4/5/2017 at 4:49 PM, zmarty said: Thanks, that's unfortunate. I will just have to adjust Actually, you can play back footage by pushing up (12:00) on the wheel that surrounds the menu button. Pushing up on the new toggle thingamajig does the same thing. I shoot with a viewfinder so the screen is completely enclosed, and I always review footage while never removing the viewfinder. In playback mode you can also use the shutter wheel to shift from on information screen to another concerning clips. So, I have a question about the in-camera V-log view assist. Using it makes footage look normal. But how to I get the better exposure for V-log. By going how the view assist looks? Or do I keep referring to the wave form? Enquiring minds want to know. Link to comment Share on other sites More sharing options...
Orangenz Posted April 10, 2017 Author Share Posted April 10, 2017 3 hours ago, tomsemiterrific said: Actually, you can play back footage by pushing up (12:00) on the wheel that surrounds the menu button. Pushing up on the new toggle thingamajig does the same thing. Answered twice already! :O 3 hours ago, tomsemiterrific said: So, I have a question about the in-camera V-log view assist. Using it makes footage look normal. But how to I get the better exposure for V-log. By going how the view assist looks? Or do I keep referring to the wave form? Enquiring minds want to know. Todays effort was according to the histogram and https://vimeo.com/212536737 there's clipped highlights there and although you'd actually expect them to be it's still kind of annoying. I had better results I think the other day when exposing for the sky and boosting the shadow slider. At 400 iso I didn't get any noise from doing that at all. So I'm thinking half to one stop under but watch what the zebras are doing (which I didn't today). Link to comment Share on other sites More sharing options...
Orangenz Posted April 10, 2017 Author Share Posted April 10, 2017 On 07/04/2017 at 5:31 AM, PixelPossum said: I just got the camera. I saw that it came up with the focal length question and adjusted it accordingly. I was was a bit confused if I needed to do anything else because in GH4 you had to changed to "Shoot without lens" in the setting thanks josse Me too, I was just a couple of days ahead Not sure why they put that option on the GH4 anyway. Maybe to stop the sensor being charged with no lens attached? Seemed unnecessary really. Link to comment Share on other sites More sharing options...
Emanuel Posted April 10, 2017 Share Posted April 10, 2017 Link to comment Share on other sites More sharing options...
tomsemiterrific Posted April 10, 2017 Share Posted April 10, 2017 4 hours ago, Orangenz said: Answered twice already! :O Todays effort was according to the histogram and https://vimeo.com/212536737 there's clipped highlights there and although you'd actually expect them to be it's still kind of annoying. I had better results I think the other day when exposing for the sky and boosting the shadow slider. At 400 iso I didn't get any noise from doing that at all. So I'm thinking half to one stop under but watch what the zebras are doing (which I didn't today). I shot with the waveform yesterday--without the view assist, and highlights were pretty well controlled. But I note over all I tend to over expose standard rec. 709 by just a bit. Exposing for the sky sounds like the way to go. Maybe in this case the histogram will work better than the waveform. What is your zebra setting? Still confused about the relationship between the View Assist LUT the actual exposure results in the V-log. I'm willing to experiment, but I'd like a good starting point. Link to comment Share on other sites More sharing options...
Grumz Posted April 10, 2017 Share Posted April 10, 2017 Has anyone had success using the Metabones Speedbooster XL with the GH5? I have a Speedbooster with the latest firmware, but when I use Canon zoom lenses (24-105L, 100-400L) the GH5 locks up the moment I try to zoom in on something. It does work when the lens is on the widest setting. Wondering if there is something within the GH5 settings that I haven't set correctly or if Metabones needs to release a new firmware update. Metabones website says the Speedbooster XL supports the GH5. Link to comment Share on other sites More sharing options...
Dude_ger Posted April 10, 2017 Share Posted April 10, 2017 Zebras in vlog: 80% will clip, unlike 100% in rec709 jonpais 1 Link to comment Share on other sites More sharing options...
jonpais Posted April 11, 2017 Share Posted April 11, 2017 1 hour ago, Dude_ger said: Zebras in vlog: 80% will clip, unlike 100% in rec709 Before, Paul Leeming recommended setting zebras at 100% for the GH4 with Vlog; now he's suggesting 80% for Vlog with the GH5, 100% for CineLike D. Link to comment Share on other sites More sharing options...
