jonpais Posted April 13, 2017 Share Posted April 13, 2017 Some tips for G85 users, but pretty certain they're applicable to the GH5 as well: expose to the right and reduce in camera sharpening for the widest dynamic range and least noise; use Cinelike D if you don't have V-Log L; do not use your in-camera microphone. I also test the tap to focus and find that it works quite well after all. Video may not have finished processing, I just uploaded it. Link to comment Share on other sites More sharing options...
Stab Posted April 13, 2017 Share Posted April 13, 2017 Looks great Jonpais! I just did some more editing tests on my laptop. I'm surprised that even my laptop handles the 4k 50p/8-bit footage fine! It has a mere i7 4700HQ and an Nvidia 760m (which gets a lot of work to do when applying effects but that's to be expected), but i can just work directly on the files and having smooth playback in both the source monitor and the preview monitor. I'm positively surprised because lots of people 'scared me' with their recommendation to transcode the footage first before editing because otherwise our computers will not handle the footage. Now, I have only one question. Does it get more taxing on the computer if the timeline gets longer? In other words, is a 10 minute film more stressful on the CPU and GPU than a 2 minute clip? Because I have just tested a timeline of 2 minutes. So far, looks like I will not have to transcode anything. How about you guys? jonpais 1 Link to comment Share on other sites More sharing options...
Ken Ross Posted April 13, 2017 Share Posted April 13, 2017 On 4/13/2017 at 11:05 AM, jonpais said: My looks are becoming a running joke in the forums. Expand Actually you're the only one brave enough to post your own image!! Orangenz 1 Link to comment Share on other sites More sharing options...
Fritz Pierre Posted April 13, 2017 Share Posted April 13, 2017 On 4/13/2017 at 11:05 AM, jonpais said: My looks are becoming a running joke in the forums. Expand Come on now Jonpais...you don't think the beautiful Vietnamese models in your clips agree to work with you only based on your sunny personality, do you? jonpais 1 Link to comment Share on other sites More sharing options...
Fritz Pierre Posted April 13, 2017 Share Posted April 13, 2017 On 4/13/2017 at 10:46 AM, Orangenz said: Well when I read it I thought that it was just doing exactly what I am doing. And by the sounds, what you are doing. Most shots are mostly dark, say under a roof shade, but with a bit of sky that is really bright showing in the background. So as most of the image is quite a bit darker than that bit of sky by the time you have brought it down enough to not clip the sky (no zebras) the scene definitely is underexposed a stop or so. So in post you just bring the shadows up. That's the situation I think about. Expose for the zebras seems to result in underexposing more often than not. The point is, this is ok. Or more ok than one would have thought in the case of these new machines. Does that help? Expand This makes a lot of sense...I think one will have to pick your battles with how you expose...for narrative, a light meter will always the preferred choice, but for what Jon does, in the case of the dark scene except for a sliver of sky, I would imagine the default would become to let the highlight blow out...so much is dependent using this exposure method on the actual scene. Orangenz and jonpais 2 Link to comment Share on other sites More sharing options...
Orangenz Posted April 13, 2017 Author Share Posted April 13, 2017 On 4/13/2017 at 3:28 PM, Stab said: Looks great Jonpais! I just did some more editing tests on my laptop. I'm surprised that even my laptop handles the 4k 50p/8-bit footage fine! It has a mere i7 4700HQ and an Nvidia 760m (which gets a lot of work to do when applying effects but that's to be expected), but i can just work directly on the files and having smooth playback in both the source monitor and the preview monitor. I'm positively surprised because lots of people 'scared me' with their recommendation to transcode the footage first before editing because otherwise our computers will not handle the footage. Now, I have only one question. Does it get more taxing on the computer if the timeline gets longer? In other words, is a 10 minute film more stressful on the CPU and GPU than a 2 minute clip? Because I have just tested a timeline of 2 minutes. So far, looks like I will not have to transcode anything. How about you guys? Expand Only more taxing with more concurrent (stacked) video tracks and effects. Duration doesn't affect it. Premiere on PC here and don't have to transcode. gtx780 On 4/13/2017 at 11:44 AM, jonpais said: Some tips for G85 users, but pretty certain they're applicable to the GH5 as well: expose to the right and reduce in camera sharpening for the widest dynamic range and least noise; use Cinelike D if you don't have V-Log L; do not use your in-camera microphone. I also test the tap to focus and find that it works quite well after all. Video may not have finished processing, I just uploaded it. Expand By tap to focus do you mean afc and then tap the screen? Does that stop it from hunting at that point? Link to comment Share on other sites More sharing options...
jonpais Posted April 14, 2017 Share Posted April 14, 2017 On 4/13/2017 at 11:44 PM, Orangenz said: Only more taxing with more concurrent (stacked) video tracks and effects. Duration doesn't affect it. Premiere on PC here and don't have to transcode. gtx780 By tap to focus do you mean afc and then tap the screen? Does that stop it from hunting at that point? Expand I have the camera set to manual, but there's still an AF icon on the LCD. It turns out to be AF-S. I only use it when I'm in front of the camera, when I'm behind I use the AF lock button. To ensure single point focus, go into the motion picture menu, AFS/AFF and select AFS. Link to comment Share on other sites More sharing options...
Orangenz Posted April 14, 2017 Author Share Posted April 14, 2017 On 4/14/2017 at 12:05 AM, jonpais said: I have the camera set to manual, but there's still an AF icon on the LCD. It turns out to be AF-S. I only use it when I'm in front of the camera, when I'm behind I use the AF lock button. To ensure single point focus, go into the motion picture menu, AFS/AFF and select AFS. Expand I just drag and drop the 1_area box on the screen. It focusses when you release it. In afc you don't have to drag and drop, just tap the screen and press set. Will have to try this out as it sure looks smooth to me. jonpais 1 Link to comment Share on other sites More sharing options...
scotchtape Posted April 14, 2017 Share Posted April 14, 2017 I just updated my speedbooster (T model, mark IV) and played with Sigma 12-35mm F1. and GH5. Some observations: IBIS isn't that great with it but better than nothing. AF works AF-C doesn't really work well. It actually does ok if the subject approaches the camera, but if you are increasing the distance it hunts like crazy and then doesn't focus. Focus racking in camera does NOT work with this combo. I was kind of disappointed in this one Link to comment Share on other sites More sharing options...
jonpais Posted April 14, 2017 Share Posted April 14, 2017 On 4/14/2017 at 12:58 AM, scotchtape said: I just updated my speedbooster (T model, mark IV) and played with Sigma 12-35mm F1. and GH5. Some observations: IBIS isn't that great with it but better than nothing. AF works AF-C doesn't really work well. It actually does ok if the subject approaches the camera, but if you are increasing the distance it hunts like crazy and then doesn't focus. Focus racking in camera does NOT work with this combo. I was kind of disappointed in this one Expand Does focus racking work with your other non- Panasonic lenses? Link to comment Share on other sites More sharing options...
scotchtape Posted April 14, 2017 Share Posted April 14, 2017 I don't know but I assume it's not supported. At least it works on panny stuff. Link to comment Share on other sites More sharing options...
tomsemiterrific Posted April 14, 2017 Share Posted April 14, 2017 On 4/11/2017 at 12:22 AM, jonpais said: Before, Paul Leeming recommended setting zebras at 100% for the GH4 with Vlog; now he's suggesting 80% for Vlog with the GH5, 100% for CineLike D. Expand So, Jon, how to you expose V-log? And do you expose Cinelike D the same way you'd expose Natural or Standard? Link to comment Share on other sites More sharing options...
jonpais Posted April 14, 2017 Share Posted April 14, 2017 On 4/14/2017 at 5:13 AM, tomsemiterrific said: So, Jon, how to you expose V-log? And do you expose Cinelike D the same way you'd expose Natural or Standard? Expand I'm not sure. I should add that I only realized this morning that the clip I uploaded last night is way too dark, I may edit it again and re upload in the near future. Link to comment Share on other sites More sharing options...
funkyou86 Posted April 14, 2017 Share Posted April 14, 2017 I really did not dig in to the AF system of the camera, now I got Vario 12-35mm lens for a limited time, but I can not get the AF working in variable frame rate mode. Any tips on that? Link to comment Share on other sites More sharing options...
Emanuel Posted April 14, 2017 Share Posted April 14, 2017 On 4/14/2017 at 7:35 AM, funkyou86 said: I really did not dig in to the AF system of the camera, now I got Vario 12-35mm lens for a limited time, but I can not get the AF working in variable frame rate mode. Any tips on that? Expand Seems, it is not available in that mode. In any case, try to see the tap-to-focus feature (AFC mode). Link to comment Share on other sites More sharing options...
funkyou86 Posted April 14, 2017 Share Posted April 14, 2017 On 4/14/2017 at 7:38 AM, Emanuel said: Seems, it is not available in that mode. In any case, try to see the tap-to-focus feature (AFC mode). Expand Thanks, will check the manual for that. Link to comment Share on other sites More sharing options...
Emanuel Posted April 14, 2017 Share Posted April 14, 2017 @funkyou86, I am wondering on tap-to-focus accuracy able to be free of any hunting as due, if you're willing to add your findings under different circumstances might be pretty useful: http://www.dvxuser.com/V6/showthread.php?353740-GH5-AF-request-for-a-test-(for-checking-accuracy-speed-smoothness-and-hunting) https://www.youtube.com/watch?v=Dpec03JocuE&lc=z125ixbpivbtsvptw23jjznhrmu2zfggb04.1492095482744934 http://www.eoshd.com/comments/topic/24076-gh5-focus-excellence/?do=findComment&comment=190866 No GH5 here, yet. Link to comment Share on other sites More sharing options...
funkyou86 Posted April 14, 2017 Share Posted April 14, 2017 On 4/14/2017 at 7:55 AM, Emanuel said: @funkyou86, I am wondering on tap-to-focus accuracy able to be free of any hunting as due, if you're willing to add your findings under different circumstances might be pretty useful: http://www.dvxuser.com/V6/showthread.php?353740-GH5-AF-request-for-a-test-(for-checking-accuracy-speed-smoothness-and-hunting) https://www.youtube.com/watch?v=Dpec03JocuE&lc=z125ixbpivbtsvptw23jjznhrmu2zfggb04.1492095482744934 http://www.eoshd.com/comments/topic/24076-gh5-focus-excellence/?do=findComment&comment=190866 No GH5 here, yet. Expand Thanks for the links. I am still unable to set any kind of AF in VFR mode, also can not set the "tap to focus" feature. This whole AF sh.t is not very user friendly :D manual focus still works the best :D I planned to invest in to some MFT lenses, but if VFR can not do the trick, then I see no reason for it Link to comment Share on other sites More sharing options...
Emanuel Posted April 14, 2017 Share Posted April 14, 2017 On 4/14/2017 at 8:27 AM, funkyou86 said: Thanks for the links. I am still unable to set any kind of AF in VFR mode, also can not set the "tap to focus" feature. This whole AF sh.t is not very user friendly :D manual focus still works the best :D I planned to invest in to some MFT lenses, but if VFR can not do the trick, then I see no reason for it Expand I always bet on hybrid stuff... cameras, modes (AF, that is, but based on touchscreen focus for sure and MF too, oh yeah, no machine will decide where focus is better than me ; ) But, you still have marvelous 4K/60p, count on it! :-) Link to comment Share on other sites More sharing options...
Emanuel Posted April 14, 2017 Share Posted April 14, 2017 On 4/12/2017 at 10:52 PM, Fritz Pierre said: So 18 mm vignettes on the XL speed booster and Sigma 18-35 @ 18 mm and not on the Ultra speed booster, but it really makes no difference as the XL gives you a wider FOV anyway, so it seems on the XL you would simply zoom on the Sigma until you match the FOV you would get using the Ultra speed booster... Expand Exactly. XL is all the way to go once beyond an extra 1/3 stop, you get more or less the same focal length at least, if not even wider -- 16 against 19 (FF equivalent): (18mm * 0,64 = 11,52 * 1,28 = 14,7456** with vignetting, but) 20mm * 0,64 = 12,8 * 1,28 = 16,384** without vignetting (according to some reports) 25mm * 0,64 = 16 * 1,28 = 20,48** without vignetting On Ultra without vignetting: 18mm * 0,72 = 12,96 * 1,48 = 19,1808** On the other end, you can lose zoom range with: 35mm * 0,64 = 22,4 * 1,28 = 28,672** against: 35mm * 0,72 = 25,2 * 1,48 = 37,296** Nothing a pretty affordable 50mm f/1.4 (1 stop faster then) won't solve: 50mm * 0,64 = 32 * 1,28 = 40,96** ** FF 35mm format equivalent :-) Link to comment Share on other sites More sharing options...
