JKTReed Posted March 28, 2017 Share Posted March 28, 2017 Well I seem to have gotten the problem with exposure drifting / hunting on my NX1 when shooting in manual. Latest firmware, 1.4.1, ISO100-400, 1/50 at f 2.8 with the Samsung 16-50mm S lens. Auto-brightness on the display switched to off as well. This is only evident when I move the camera from a brightly lit scene to a darker one - it seems to flicker between exposure for a good 10 seconds. Anyone found a solution for this? Should I try to revert to firmware 1.2 where this problem seemed to be eliminated? Any idea where I can find that fw? Hoping for help..! Link to comment Share on other sites More sharing options...
tugela Posted March 28, 2017 Share Posted March 28, 2017 You probably have some auto mode activated that you are not aware of, and it is not fully manual. Mine is on 1.41 and there is no exposure "drifting". Link to comment Share on other sites More sharing options...
Kisaha Posted March 28, 2017 Share Posted March 28, 2017 Do you have the SmartRange (or whatever is called) on or off? Usually I do not do this kind of shooting, but a couple of weeks ago I had my NX500 doing some crazy stuff (as a B cam, I just brought it for backstage stills, but the DP told me to use it) and never seen anything weird (except the huge differences that had to adjust instantly most of my settings!) Link to comment Share on other sites More sharing options...
Parker Posted March 28, 2017 Share Posted March 28, 2017 I see a lot of people mention this "exposure drifting" in NX threads -- but other than auto screen brightness levels changing which confused me once -- I have never experienced this issue. Occasionally on either the NX1 or the NX500 I will get some kind of bug where my actual exposure is much darker than what the settings should provide, but a quick restart always fixes this, and it happens very rarely and has never ruined any footage, just a photo or two. I don't think it's the "smart range" thing that causes this either (Did we ever reach a consensus on what that actually does? A while back in the ideal NX settings thread I remember some user saw an increase in dynamic range with it turned on.) Anyway, if this issue really exists, it must be copy-to-copy, and neither of my cams (thankfully) suffer from it. Link to comment Share on other sites More sharing options...
shanebrutal Posted March 28, 2017 Share Posted March 28, 2017 Which white balance setting are you using? I noticed using the configurable color temperature setting can cause some random color shifts that blink the exposure as well. Also I assume you don't have auto iso on while in manual mode? Link to comment Share on other sites More sharing options...
JKTReed Posted March 29, 2017 Author Share Posted March 29, 2017 Thank you for replying! I'm on Auto WB, ISO in manual (100). However I did some tests yesterday that revealed something interesting: When using aperture priority I get the same flicker/drifting, the aperture shifts between 9 and 10 rapidly when focusing on the other side of the room (both AF and MF), unable to get a lock in a daylight-lit room. It drifts between + -1 stop which causes the flickering. However, by setting ISO to auto the flickering disappears. And the weird thing is that this happens even with the camera in manual with the f value at a constant 4. With Auto ISO off, it seems the aperture will compensate even though it's not supposed to. On another note, in video mode the exposure on the screen changes when i vary between a lit window and a darker couch, even with all settings on manual. SmartRange is turned off. Link to comment Share on other sites More sharing options...
Kisaha Posted March 29, 2017 Share Posted March 29, 2017 Do you have a video to see the phenomenon? Won't AWB change as well in these circumstances? Link to comment Share on other sites More sharing options...
JKTReed Posted March 29, 2017 Author Share Posted March 29, 2017 Yes, here is one example I just uploaded to Vimeo Settings are Manual, UHD, 1/50, f.2, ISO100, AWB, GammaDR w/ sharpness -10, MBL -4. SmartRange and Autobrightness off. You notice that when I pan away from the bright window to the wall, it begins to "hunt" for exposure. If I try the same in Aperture Priority, the f value switches rapidly between stops. If Auto ISO is on, nothing happens. Maybe this camera can't handle ISO100 and a full aperture in UHD? Metering to center-weighted. Link to comment Share on other sites More sharing options...
homestar_kevin Posted March 29, 2017 Share Posted March 29, 2017 Try it with AWB turned off Link to comment Share on other sites More sharing options...
JKTReed Posted March 29, 2017 Author Share Posted March 29, 2017 3 minutes ago, homestar_kevin said: Try it with AWB turned off Sadly no difference. Tried setting it to K, without change. Link to comment Share on other sites More sharing options...
Jesse Anthony Posted March 29, 2017 Share Posted March 29, 2017 Have you tried testing it with a manual/non samsung lens? my friends Nx1 did this before with the small kit 16-50mm non "S" lens. I can't remember if he updated the lens firmware or did something to the lens settings but I think that fixed his issue. Link to comment Share on other sites More sharing options...
Kisaha Posted March 29, 2017 Share Posted March 29, 2017 It is definitely there, sorry but I am not familiar with the issue. I hope you will find out something. Another thing is that you can press "STOP REC" and start again when you have moved to your next shot, as the situation is very bad for filming anyway, there is no way to have a manual useful scene with such huge dynamic differences. Link to comment Share on other sites More sharing options...
Blah Blah Posted March 29, 2017 Share Posted March 29, 2017 Haven't seen that happen, I would try everything in manual including SmartRange. Link to comment Share on other sites More sharing options...
JKTReed Posted March 29, 2017 Author Share Posted March 29, 2017 4 minutes ago, Blah Blah said: Haven't seen that happen, I would try everything in manual including SmartRange. Thanks for your inputs! I wouldn't film like that in ordinary situations - this was pushing it to the limit to recreate the problem. However everything is in manual, including WB. My only way of safeguarding against it is AutoISO. Link to comment Share on other sites More sharing options...
Twist Posted March 29, 2017 Share Posted March 29, 2017 Tried resetting it? Link to comment Share on other sites More sharing options...
JKTReed Posted March 29, 2017 Author Share Posted March 29, 2017 13 minutes ago, Twist said: Tried resetting it? Yes. I know this issue was present with the first firmware but was rectified with 1.2. However since 1.4.1 it's back. Link to comment Share on other sites More sharing options...
Twist Posted March 29, 2017 Share Posted March 29, 2017 11 minutes ago, JKTReed said: Yes. I know this issue was present with the first firmware but was rectified with 1.2. However since 1.4.1 it's back. http://downloadcenter.samsung.com/content/FM/201508/20150821161049567/NX1_FW_v1.40_sec.zip 1.40 here Link to comment Share on other sites More sharing options...
JKTReed Posted March 29, 2017 Author Share Posted March 29, 2017 Just now, Twist said: http://downloadcenter.samsung.com/content/FM/201508/20150821161049567/NX1_FW_v1.40_sec.zip That's perfect - can I just flash it / downgrade it by myself..? Thank you so much! Link to comment Share on other sites More sharing options...
Twist Posted March 29, 2017 Share Posted March 29, 2017 Search Google for nx1 downgrade JKTReed 1 Link to comment Share on other sites More sharing options...
JKTReed Posted March 29, 2017 Author Share Posted March 29, 2017 Well I'll be damned. I just downgraded to 1.40 and behold - the problem is gone! Thanks so much for all your input, everyone. You saved me, here :-) Link to comment Share on other sites More sharing options...
