Super Members BTM_Pix Posted March 30, 2017 Super Members Share Posted March 30, 2017 I'm probably very late to this but prompted by a discussion in another thread about editing on a MacBook I thought I'd flag up what I've been using as an additional monitor when editing. As you can see here, I'm using my iPad Mini in FCPX as the Secondary Display using an app called Duet which was developed by some ex-Apple staff. Basically, it allows you to use any (and multiple) iOS devices connected to the USB port to increase the screen real estate of your MacBook (and any OSX machine actually) when running the Duet app on your Mac. OSX just sees them as additional screens so you can arrange and orient them anyway you like just as you would normal additional monitors. And because you aren't dealing with big monitors on stands, you can quickly reconfigure your setup depending on what you're doing. For example, if I'm using Aperture, I'll have the iPad on the left of the screen with all the tools on it and the main MacBook screen just having the image I'm editing. Also, unlike proper external monitors, you can take them with you easily. So if you're away somewhere and you have your iPad (or even your iPhone) then you can setup a dual screen system wherever you are. Or a tri screen system if you can borrow someone else's iPad there! I attach mine using the Ten One Design Mountie which at £20 is a bit harsh for some plastic and rubber but it works well. Other types are available cheaper on Amazon. The Duet app is £14.99 on the app store and the OSX control app is a free download. So, all in all, £34.99 to turn what you might well already have in your bag (or your pocket if its an iPhone) into an additional monitor is decent value. https://tenonedesign.com/mountie.php https://www.duetdisplay.com iamoui, jonpais and Phil A 3 Link to comment Share on other sites More sharing options...
Phil A Posted March 30, 2017 Share Posted March 30, 2017 Duet Display also works under Windows, I've used it in the past. BTM_Pix, Inazuma and Nikkor 3 Link to comment Share on other sites More sharing options...
