zerocool22 Posted June 14, 2019 Share Posted June 14, 2019 On 6/14/2019 at 5:31 AM, kye said: What differences are you seeing? I'm not arguing that there aren't any, because there are, but they're a lot less than the price differential would suggest. Expand DR and detail/sharpness mostly as resolution should be the same. Link to comment Share on other sites More sharing options...
kye Posted June 14, 2019 Share Posted June 14, 2019 On 6/14/2019 at 8:11 AM, zerocool22 said: DR and detail/sharpness mostly as resolution should be the same. Expand Resolution likely isn't the same. RAW at a given bit-depth has a constant bitrate and one of the plus points on the 5D is the fast card slot, so it can do higher resolutions than the lesser models. Have you used ML? Link to comment Share on other sites More sharing options...
zerocool22 Posted June 14, 2019 Share Posted June 14, 2019 On 6/14/2019 at 3:59 PM, kye said: Resolution likely isn't the same. RAW at a given bit-depth has a constant bitrate and one of the plus points on the 5D is the fast card slot, so it can do higher resolutions than the lesser models. Have you used ML? Expand Yes on the 5D III. Liked it a lot, only downside was the low DR as it is quite a dated camera vs the options we have now DR wise. kye 1 Link to comment Share on other sites More sharing options...
mercer Posted June 14, 2019 Share Posted June 14, 2019 On 6/14/2019 at 6:54 PM, zerocool22 said: Yes on the 5D III. Liked it a lot, only downside was the low DR as it is quite a dated camera vs the options we have now DR wise. Expand Don’t be too modest, you shot one of the best 5D3 ML Raw videos out there. zerocool22 1 Link to comment Share on other sites More sharing options...
kye Posted June 15, 2019 Share Posted June 15, 2019 On 6/14/2019 at 6:54 PM, zerocool22 said: Yes on the 5D III. Liked it a lot, only downside was the low DR as it is quite a dated camera vs the options we have now DR wise. Expand Yeah, the DR on Canon isn't the greatest unfortunately. Link to comment Share on other sites More sharing options...
