JustinJohnson Posted May 15, 2017 Share Posted May 15, 2017 8 hours ago, tihon84 said: In vlog 10bit you cant change a luminance settings, so all mxf files more contrasted Yes that is correct. I don't use V-Log yet so for my test I used Natural, Cine-D, and Cine-V in both 8-bit and 10-bit. Link to comment Share on other sites More sharing options...
SuperSet Posted May 18, 2017 Share Posted May 18, 2017 So did the new Adobe update today fix the issue? Link to comment Share on other sites More sharing options...
JustinJohnson Posted May 18, 2017 Share Posted May 18, 2017 No it did not. Still waiting. 12 hours ago, SuperSet said: So did the new Adobe update today fix the issue? Orangenz 1 Link to comment Share on other sites More sharing options...
tihon84 Posted June 4, 2017 Share Posted June 4, 2017 Up. Any progress? Are we still waiting? As for me, it takes 24 hours to render 10 minutes 4k 10 bit video with light grade. After Effects Link to comment Share on other sites More sharing options...
Orangenz Posted June 5, 2017 Author Share Posted June 5, 2017 4 hours ago, tihon84 said: Up. Any progress? Are we still waiting? As for me, it takes 24 hours to render 10 minutes 4k 10 bit video with light grade. After Effects You've got something broken there that aint the codec mate. Link to comment Share on other sites More sharing options...
Orangenz Posted June 7, 2017 Author Share Posted June 7, 2017 My up to date (hopefully?) instructions here https://www.dropbox.com/s/nt2uqr5pp9xi1st/GH5 10 bit fix.pdf?dl=0 Link to comment Share on other sites More sharing options...
SuperSet Posted June 13, 2017 Share Posted June 13, 2017 Our long national nightmare is over. Adobe has released the Premiere update for the GH5. Orangenz 1 Link to comment Share on other sites More sharing options...
Orangenz Posted June 14, 2017 Author Share Posted June 14, 2017 12 hours ago, SuperSet said: Our long national nightmare is over. Adobe has released the Premiere update for the GH5. And which nation are you dreaming in? :D jonpais 1 Link to comment Share on other sites More sharing options...
Orangenz Posted June 14, 2017 Author Share Posted June 14, 2017 Also a windows update sitting there. All seems to work. Still doesn't like me loading up 6 osiris luts one after the other. Link to comment Share on other sites More sharing options...
ntblowz Posted June 14, 2017 Share Posted June 14, 2017 https://blogs.adobe.com/creativecloud/premiere-pro-11-1-2-available-today-ciritical-update-highly-recommended/ New update today Can fully read GH5 10bit file now Link to comment Share on other sites More sharing options...
Grimor Posted June 14, 2017 Share Posted June 14, 2017 After updating Premiere on June 13th with the 11.1.2 update GH5 10 bit 4K files now play properly in Premiere, however, there is an issue when changing the playback resolution. If the playback resolution is set to anything other than full then the playback does a weird scaling thing once it has been initiated. For instance: if playback is set to 1/2 or 1/4 resolution as soon as you press play the viewer which is set to fit will change to playing only the left-hand corner of the 4K image at 100% size in the viewer. So you just see this one section of the video which is no longer playing as though fit to the viewers size. Then once you stop it from playing it reverts back to being fit into the viewer. People reporting the same on Mac and Windows Link to comment Share on other sites More sharing options...
Brother Posted June 14, 2017 Share Posted June 14, 2017 7 hours ago, Grimor said: After updating Premiere on June 13th with the 11.1.2 update GH5 10 bit 4K files now play properly in Premiere, however, there is an issue when changing the playback resolution. If the playback resolution is set to anything other than full then the playback does a weird scaling thing once it has been initiated. For instance: if playback is set to 1/2 or 1/4 resolution as soon as you press play the viewer which is set to fit will change to playing only the left-hand corner of the 4K image at 100% size in the viewer. So you just see this one section of the video which is no longer playing as though fit to the viewers size. Then once you stop it from playing it reverts back to being fit into the viewer. People reporting the same on Mac and Windows "The only thing you have to turn on is the "High Quality Playback" setting. Once that is on you can select different playback resolutions like 1/8 and it will reduce the quality and it won't zoom in." Found this in a Facebook group but haven't tried it yet. Grimor 1 Link to comment Share on other sites More sharing options...
Grimor Posted June 14, 2017 Share Posted June 14, 2017 21 minutes ago, Brother said: "The only thing you have to turn on is the "High Quality Playback" setting. Once that is on you can select different playback resolutions like 1/8 and it will reduce the quality and it won't zoom in." Found this in a Facebook group but haven't tried it yet. But, is this a workaround or the way it has to be? High Quality Playback demands a lot of PC system Link to comment Share on other sites More sharing options...
Orangenz Posted June 14, 2017 Author Share Posted June 14, 2017 Premiere still not quite there on ingesting the 6k photo files. Night vision! Link to comment Share on other sites More sharing options...
Dude_ger Posted June 14, 2017 Share Posted June 14, 2017 You re on mac or pc? I have the same problem on pc, only with the h265 files... Link to comment Share on other sites More sharing options...
Orangenz Posted June 14, 2017 Author Share Posted June 14, 2017 1 minute ago, Dude_ger said: You re on mac or pc? I have the same problem on pc, only with the h265 files... Yes that's the 6kphoto h265 video file. win10 Link to comment Share on other sites More sharing options...
Dude_ger Posted June 15, 2017 Share Posted June 15, 2017 I m on win7 Link to comment Share on other sites More sharing options...
