Grégory LEROY Posted April 29, 2017 Share Posted April 29, 2017 Hello, I don't find any video comparing GH5 1080p 120fps, 180fps to Sony cameras. Do you have some link? I don't understand why nobody cover this topic on youtube. Thank you. Link to comment Share on other sites More sharing options...
funkyou86 Posted April 29, 2017 Share Posted April 29, 2017 Filmriot just posted this yesterday: No real comparison between the GH5 and A7S, but Ryan states that even he has an A7SII, he's considering to buy a GH5. Link to comment Share on other sites More sharing options...
Orangenz Posted April 30, 2017 Share Posted April 30, 2017 https://youtu.be/dXTN3-9bv64?t=2m41s Interesting from 2:41, lots of nice slowmo shots Link to comment Share on other sites More sharing options...
Grégory LEROY Posted May 14, 2017 Author Share Posted May 14, 2017 Thank you guys, if you have any comparison vs sony a6500, don't hesitate to post, I read a lot of opposite informations. Link to comment Share on other sites More sharing options...
64mulford Posted May 14, 2017 Share Posted May 14, 2017 I have both cameras and much prefer the GH5 for slow motion, even up to 180fps. I think the GH5 quality is slightly better AND it doesn't crop in 2x like the A7sii which is a big deal. Link to comment Share on other sites More sharing options...
Eduardo Granadsztejn Posted May 15, 2017 Share Posted May 15, 2017 14 hours ago, 64mulford said: I have both cameras and much prefer the GH5 for slow motion, even up to 180fps. I think the GH5 quality is slightly better AND it doesn't crop in 2x like the A7sii which is a big deal. the gh5 sensor is already 2x crop, what are you telling me? Link to comment Share on other sites More sharing options...
ntblowz Posted May 15, 2017 Share Posted May 15, 2017 4 hours ago, Eduardo Granadsztejn said: the gh5 sensor is already 2x crop, what are you telling me? It's annoy to switch from normal to slowmo because now you found you have to stay back since composition changed Eduardo Granadsztejn and Kisaha 2 Link to comment Share on other sites More sharing options...
64mulford Posted May 15, 2017 Share Posted May 15, 2017 Not a 2x crop with a speedbooster! And yes, that fact that your 50mm suddenly becomes a 100mm when you select slow mo on the A7sii is a huge inconvenience in a run and gun shoot. Eduardo Granadsztejn 1 Link to comment Share on other sites More sharing options...
tihon84 Posted May 15, 2017 Share Posted May 15, 2017 A7s2 120fps fhd is soft. Rx10ii 120fps looks better and more sharp. Today did test of 120 and 180 fps on gh5 and it looks great, i think Fritz Pierre 1 Link to comment Share on other sites More sharing options...
Fritz Pierre Posted May 15, 2017 Share Posted May 15, 2017 3 hours ago, tihon84 said: A7s2 120fps fhd is soft. Rx10ii 120fps looks better and more sharp. Today did test of 120 and 180 fps on gh5 and it looks great, i think Amazingly detailed!...is this in 8bit or 10 bit internal? Link to comment Share on other sites More sharing options...
Rinad Amir Posted May 15, 2017 Share Posted May 15, 2017 19 minutes ago, Fritz Pierre said: Amazingly detailed!...is this in 8bit or 10 bit internal? 8bit Link to comment Share on other sites More sharing options...
tihon84 Posted May 16, 2017 Share Posted May 16, 2017 9 hours ago, Fritz Pierre said: Amazingly detailed!...is this in 8bit or 10 bit internal? Yep, 8 bit fhd 180fps Vlog all settings -5 i have to apply plugins and effects in AE for a second part of video what i did: Upscale fhd using AE effect in distort section using detailed upscale ( i did the same upscale in the first ungraded clips) i set details to 100% Than i denoise this clip a little using Neat Video. So i get more accurate colors and less artefacts Than i apply: 1- unsharp mask with 80, 0,8 settings 2- colorista II pop effect set to 25 render all this to 2.5k wmv 10mbps cbr 2 pass so i get clean and shap image in 2,5k Link to comment Share on other sites More sharing options...
tonysss Posted May 16, 2017 Share Posted May 16, 2017 GH5 360fps :-) The project is 25p and the shots GH5 are 180fps/50p slowed to 50% Link to comment Share on other sites More sharing options...
Dude_ger Posted May 16, 2017 Share Posted May 16, 2017 On 15.5.2017 at 5:16 AM, Eduardo Granadsztejn said: the gh5 sensor is already 2x crop, what are you telling me? There is a HUGE difference. The 2x of the Gh5 crops the image circle of the lens, while the 2x on the Sony crops the sensor. I had terrible noise using the slomo of the a7s2, (but also have terrible noise using slomo on the GH5 above 400 ISO) And having a consistant crop (more or less with speedbooster) allows faster working. Link to comment Share on other sites More sharing options...
Dimitris Stasinos Posted May 16, 2017 Share Posted May 16, 2017 1 hour ago, tonysss said: GH5 360fps :-) The project is 25p and the shots GH5 are 180fps/50p slowed to 50% I don't get this...If you recorded this at 180 fps, how can the final clip end up being 14,4 times slower (360 fps) than realtime without using generated frames from twixtor or something? Am i missing something? Link to comment Share on other sites More sharing options...
tonysss Posted May 16, 2017 Share Posted May 16, 2017 2 minutes ago, Dimitris Stasinos said: I don't get this...If you recorded this at 180 fps, how can the final clip end up being 14,4 times slower (360 fps) than realtime without using generated frames from twixtor or something? Am i missing something? GH5 saves slow-motion shots to 1080/50p, and my project is 1080/25p, so 50p slow motion shots slow down to 50% and no twixtor is needed Link to comment Share on other sites More sharing options...
Dimitris Stasinos Posted May 16, 2017 Share Posted May 16, 2017 12 minutes ago, tonysss said: GH5 saves slow-motion shots to 1080/50p, and my project is 1080/25p, so 50p slow motion shots slow down to 50% and no twixtor is needed Can't GH5 conform at 25fps from 180fps HFR ? What's the gain of conforming to 50 fps in camera and then stretching in a 25 fps timeline? The final footage is still shot at 180 fps, you can't produce 360 fps clips from 180 fps footage without generating frames. Correct me if i am wrong. Link to comment Share on other sites More sharing options...
tonysss Posted May 16, 2017 Share Posted May 16, 2017 7 minutes ago, Dimitris Stasinos said: Can't GH5 conform at 25fps from 180fps HFR ? What's the gain of conforming to 50 fps in camera and then stretching in a 25 fps timeline? The final footage is still shot at 180 fps, you can't produce 360 fps clips from 180 fps footage without generating frames. Correct me if i am wrong. Yes it's pseudo 360fps :-) it's 14x slowed Link to comment Share on other sites More sharing options...
Grégory LEROY Posted June 23, 2017 Author Share Posted June 23, 2017 On 15/05/2017 at 8:58 PM, tihon84 said: A7s2 120fps fhd is soft. Rx10ii 120fps looks better and more sharp. Today did test of 120 and 180 fps on gh5 and it looks great, i think how can we watch you video? thank you Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 23, 2017 Administrators Share Posted June 23, 2017 On 16/05/2017 at 1:13 PM, Dimitris Stasinos said: I don't get this...If you recorded this at 180 fps, how can the final clip end up being 14,4 times slower (360 fps) than realtime without using generated frames from twixtor or something? Am i missing something? 180fps is 180fps. To title it 360fps is nonsense Dimitris Stasinos and Orangenz 2 Link to comment Share on other sites More sharing options...
