Stefan Antonescu Posted May 1, 2017 Share Posted May 1, 2017 New Pilotfly H2-45 Gimbal. Up to 4.9 lb (2.2 kg). Probably $999 like the H2.https://pilotfly.de/epages/777c6180-f31f-4700-a505-78d08d790bfc.mobile/en_GB/?ObjectPath=/Shops/777c6180-f31f-4700-a505-78d08d790bfc/Products/000012&Locale=en_GB Unboxing :https://m.youtube.com/watch?v=Ubl0hYcuPo4 IMO, this is huge if you don't use an external monitor ! Should be available next month. Adept 1 Link to comment Share on other sites More sharing options...
Davey Posted May 1, 2017 Share Posted May 1, 2017 Amazing that nobody thought of that before - or the next obvious thing staring us in the faces that none of us can see. Link to comment Share on other sites More sharing options...
Cinegain Posted May 1, 2017 Share Posted May 1, 2017 Well, 3-axis is pretty self explanatory for the straight forward designs we've seen. Don't know if this is harder to balance, tougher on the motors and battery life... if losing a couple of degrees from the straight axis makes it less stable? Maybe it helps with the walk-bounce? But it's sure nice to have a clear view of the screen for camera without a vari-angle screen or stabilizer with configurable set-up that can swing the arm the other way around for the left side to be clear. Interesting for sure. Hopefully they'll have some kind of trade-in/upgrade programm for H2 users. Link to comment Share on other sites More sharing options...
Don Kotlos Posted May 1, 2017 Share Posted May 1, 2017 Since I mostly need gimbal for low angle shots I am more interested in a setup like this: I feel it will be much more comfortable than holding the provided vertical grip upside down and I am sure it can be done with the battery base. Anyone has experience with a setup like this? Adept 1 Link to comment Share on other sites More sharing options...
Yanher Lin Posted May 1, 2017 Share Posted May 1, 2017 Check this.http://pic.twitter.com/pb5x0JpeQU Don Kotlos and benymypony 2 Link to comment Share on other sites More sharing options...
Stefan Antonescu Posted May 1, 2017 Author Share Posted May 1, 2017 On 5/1/2017 at 3:09 PM, Cinegain said: Well, 3-axis is pretty self explanatory for the straight forward designs we've seen. Don't know if this is harder to balance, tougher on the motors and battery life... if losing a couple of degrees from the straight axis makes it less stable? Maybe it helps with the walk-bounce? But it's sure nice to have a clear view of the screen for camera without a vari-angle screen or stabilizer with configurable set-up that can swing the arm the other way around for the left side to be clear. Interesting for sure. Hopefully they'll have some kind of trade-in/upgrade programm for H2 users. Expand Battery life is 26 hours. Even if it's only half in real life, I think it's plenty for most users. Link to comment Share on other sites More sharing options...
ntblowz Posted May 1, 2017 Share Posted May 1, 2017 Good timing, thinking of ditching osmo x5 and get a gimbal for proper camera instead, this solves my no 1 annoyance with gimbal, cant see @$#%$# screen! With osmo you get big monitor aka phone but with slight lag. Link to comment Share on other sites More sharing options...
Fritz Pierre Posted May 1, 2017 Share Posted May 1, 2017 On 5/1/2017 at 3:09 PM, Cinegain said: Well, 3-axis is pretty self explanatory for the straight forward designs we've seen. Don't know if this is harder to balance, tougher on the motors and battery life... if losing a couple of degrees from the straight axis makes it less stable? Maybe it helps with the walk-bounce? But it's sure nice to have a clear view of the screen for camera without a vari-angle screen or stabilizer with configurable set-up that can swing the arm the other way around for the left side to be clear. Interesting for sure. Hopefully they'll have some kind of trade-in/upgrade programm for H2 users. Expand I doubt that it makes any difference as the center of gravity is still directly over the handle...from a physics standpoint the 45 degree or whatever the angle is that the mount migrates out, is cancelled out by the same angle and height of the return...the gimbal should notice no difference....in fact balancing should be easier as there's nothing behind the camera to prevent you from moving it backwards or forward to compensate for larger lenses... Link to comment Share on other sites More sharing options...
ntblowz Posted May 1, 2017 Share Posted May 1, 2017 On 5/1/2017 at 8:24 PM, Fritz Pierre said: I doubt that it makes any difference as the center of gravity is still directly over the handle...from a physics standpoint the 45 degree or whatever the angle is that the mount migrates out, is cancelled out by the same angle and height of the return...the gimbal should notice no difference....in fact balancing should be easier as there's nothing behind the camera to prevent you from moving it backwards or forward to compensate for larger lenses... Expand That actually a good point! seems like you can move camera back further than before, maybe mounting anamorphic lens on it is possible with this design Link to comment Share on other sites More sharing options...
Fritz Pierre Posted May 1, 2017 Share Posted May 1, 2017 On 5/1/2017 at 8:46 PM, ntblowz said: That actually a good point! seems like you can move camera back further than before, maybe mounting anamorphic lens on it is possible with this design Expand Exactly!...this is a huge factor in this gimbal...may require a longer than standard QR plate, but providing you're within the weight limit you could now get more lens on there and of course anamorphic would be the holy grail... Link to comment Share on other sites More sharing options...
aldolega Posted May 8, 2017 Share Posted May 8, 2017 Gregormannschaft 1 Link to comment Share on other sites More sharing options...
Kisaha Posted May 8, 2017 Share Posted May 8, 2017 Very good production video, amazing city (this, must, be). The most important issue with stabilizers is the balancing procedure, if it is equally good (hopefully better) than the Crane, then they have a winner, if it's not, then, don't! Link to comment Share on other sites More sharing options...
Ki Rin Posted May 8, 2017 Share Posted May 8, 2017 Seems like a very good gimbal. But also about 40% more expensive than the crane... I hope to see some reviews soon. Link to comment Share on other sites More sharing options...
Gregormannschaft Posted May 8, 2017 Share Posted May 8, 2017 Looks great, they're showing off the gimbal in the right way with that video and I love that you can see the screen. I'd need to see how easy it is to setup before buying. Link to comment Share on other sites More sharing options...
Davey Posted May 8, 2017 Share Posted May 8, 2017 On 5/1/2017 at 4:31 PM, Stefan Antonescu said: Battery life is 26 hours. Even if it's only half in real life, I think it's plenty for most users. Expand The battery life on my Beholder DS1 is 9000 hours switched off. I am impressed that the batteries have yet to leak and finish the pile of crap off for good. Wasn't there a myriad of problems with the original Pilot that did not come to light until after the initial showboating videos? BTM_Pix 1 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted May 8, 2017 Super Members Share Posted May 8, 2017 It looks brilliant. But they all do when other people are using them. When I get my hands on one it looks like I was shooting while walking over a path of upturned Lego and 3 pin mains plugs. Does anyone know if Pilotfly's place in Augsburg is an actual retail premises where you can go and try one and get help setting it up? Kisaha 1 Link to comment Share on other sites More sharing options...
Rinad Amir Posted May 8, 2017 Share Posted May 8, 2017 I need this ! Link to comment Share on other sites More sharing options...
Turboguard Posted May 8, 2017 Share Posted May 8, 2017 Will this be able to hold my bmpcc+sb+Sigma 18-35? I want a pistol gimbal so badly. Bmpcc 355g + SB 160g + Sigma 811g = 1.33Kg. The H2-45 can handle 2.2Kg so this actually work right?! Please make this one be good!! Also what is the verdict on the Nebula series? They have a new 5100 series coming out... Link to comment Share on other sites More sharing options...
wolf33d Posted May 8, 2017 Share Posted May 8, 2017 I had the Pilotfly and the Crane. Crane is actually much smoother. The city video is done by rollerblading this is why it is so smooth. I am not paying more than Crane for less smoothness. No way... good idea for the 45 angle though Link to comment Share on other sites More sharing options...
jcs Posted May 8, 2017 Share Posted May 8, 2017 On 5/8/2017 at 1:08 AM, Kisaha said: Very good production video, amazing city (this, must, be). The most important issue with stabilizers is the balancing procedure, if it is equally good (hopefully better) than the Crane, then they have a winner, if it's not, then, don't! Expand Was wondering what city, then saw the bridge at 1:16: https://youtu.be/VGgZRrfXUBA?t=1m16s (Sydney Australia, did the bridge climb a few years ago- highly recommended!). Kisaha 1 Link to comment Share on other sites More sharing options...
