Lucian Posted April 10, 2013 Share Posted April 10, 2013 Hi All, I'm after some wisdom on putting together a good set of lenses for narrative filmmaking using on the GH2 they must play nice with the KOWA B&H which I beleive can only go down to 50mm. So far I have: a Helios 44-2 thinking about a minolta MD 35mm 2.8 what else you suggest to give me a good range to shoot an entire short? Thank you! Link to comment Share on other sites More sharing options...
Bioskop.Inc Posted April 10, 2013 Share Posted April 10, 2013 The 50mm lens limit is for an APS-C sensor, i think you'll find that M43 is more like 35/40mm min with the Kowa. Russian lenses are a good match as they have simple lens recipes & are cheap (quality/condition varies though). Tair 11a - 135 f2.8 (not really necessary if you're using M43 - it'll be too telephoto) Jupiter 9 - 85mm f2 Helios 44-2 - 58mm f2 (get the pre-set aperture one) Mir 1B - 37mm f2.8 If not Super Takumars work v.well, but are small & can get overwhelmed by the Kowa. Also remember the 1.5/2m min focus distance, but if you have a good spread of lenses it won't matter too much - a weak diopter would be handy, but are quite rare at the moment (look for the Tokina +0.5 or if you've got the cash the +0.4 doublet or if Redstan has any left his Angenieux +0.25). Link to comment Share on other sites More sharing options...
Julian Posted April 10, 2013 Share Posted April 10, 2013 I use the Minolta 35mm f/2.8, that's as wide as you can go, it might vignette a bit in the extreme corners, but doesn't show in every shot. Here's some footage on the GH2 with Minolta 35mm f/2.8, 50mm f/1.7, 100mm f/2.5 and the Kowa B&H. The Minolta's are cheap to find, it's easy to collect a whole set like that :) https://vimeo.com/53787515 Link to comment Share on other sites More sharing options...
Lucian Posted April 10, 2013 Author Share Posted April 10, 2013 Great advice. Julian, yes I have checked out your footage, that is why I was thinking of getting the minolta. Although i may go with the MIR 24 just to keep some consistency by using all russian glass. Your footage looks great, it has a very 70s feel. I'm going to mull it over on which wide lens to get but its either the minolta 35 or the MIR 24 :) Link to comment Share on other sites More sharing options...
