pietz Posted April 11, 2013 Share Posted April 11, 2013 Hey guys, i usually love working with premiere. i think this program really evolved over the past years and is pretty brilliant in the latest version. however on my new hackintosh i run into serious performance problems when looking through footage. the footage of my GH2 (wrapped to a .mov container) stutters so badly in my preview window that its impossible to work with. i have a plenty fast i7-3770k, geforce 650 ti and 8GBs of ram, but the video playback still stutters. it even stutters in my timeline when the clips are marked yellow, which usually means that premiere is able to play it somewhat smoothly. i even enabled mercury GPU acceleration for my graphics card, but that didnt help a bit. it also very often shows "media pending" for a second or two, which is weird since i loaded the entire footage on my SSD with 500MB/s read speeds. i installed fcpx just for kicks and everything is perfectly smooth. i never had this trouble with premiere on windows on my older machine. is somebody experiencing similar problems or can maybe help with mine? thanks a ton Link to comment Share on other sites More sharing options...
Leang Posted April 11, 2013 Share Posted April 11, 2013 Usually people that build Hackintoshes are blunt with using pirated software! Too risky investing on official software on non certified systems because they usually run into problems. :P Link to comment Share on other sites More sharing options...
AaronChicago Posted April 11, 2013 Share Posted April 11, 2013 Hey guys, i usually love working with premiere. i think this program really evolved over the past years and is pretty brilliant in the latest version. however on my new hackintosh i run into serious performance problems when looking through footage. the footage of my GH2 (wrapped to a .mov container) stutters so badly in my preview window that its impossible to work with. i have a plenty fast i7-3770k, geforce 650 ti and 8GBs of ram, but the video playback still stutters. it even stutters in my timeline when the clips are marked yellow, which usually means that premiere is able to play it somewhat smoothly. i even enabled mercury GPU acceleration for my graphics card, but that didnt help a bit. it also very often shows "media pending" for a second or two, which is weird since i loaded the entire footage on my SSD with 500MB/s read speeds. i installed fcpx just for kicks and everything is perfectly smooth. i never had this trouble with premiere on windows on my older machine. is somebody experiencing similar problems or can maybe help with mine? thanks a ton Are you dropping your footage into a new sequence, or creating a sequence prior to dropping in your footage? Link to comment Share on other sites More sharing options...
pietz Posted April 11, 2013 Author Share Posted April 11, 2013 i dont think thats relevant because the footage stutters in the preview before i even drop it in a sequence. to answer your question though, i dropped them into the sequences that premiere created when i set up the project Link to comment Share on other sites More sharing options...
AKH Posted April 11, 2013 Share Posted April 11, 2013 Try changing the extension of the footage from .mov to .mpg then re-import into CS6. If this solves the performance problem then I may know what the issue is. I'll elaborate further then. Link to comment Share on other sites More sharing options...
pietz Posted April 25, 2013 Author Share Posted April 25, 2013 what fixed the problem was simply not rewrapping the files to MOV and just using the original MTS files. i though i would help the performance by using MOV instead, but what happend was the opposite. @AKH i didnt try your way, but i guess that you may be right with your idea. could you explain why Premiere struggles with MOV files on OSX? Link to comment Share on other sites More sharing options...
/p/ Posted April 25, 2013 Share Posted April 25, 2013 Mine works with my GH3 .mov files perfectly. Link to comment Share on other sites More sharing options...
AKH Posted April 25, 2013 Share Posted April 25, 2013 I don't think this issue is particular to one OS. Premiere doesn't always make the right decisions when it comes to decoding .mov files. Best performance is usually achieved when Premiere uses its internal codecs to decode, but with some .mov files Premiere decides (wrongly) it cannot decode the file internally and falls back to using Quicktime for decoding duties. Changing the extension of the file forces Premiere to try it's internal codecs. I experienced bad stuttering with Nikon .mov files. Simply changing the extension to .mpg resulted in no more stuttering. The work-around solution came from Creative Cow. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted April 26, 2013 Administrators Share Posted April 26, 2013 Simply changing the extension to .mpg resulted in no more stuttering. The work-around solution came from Creative Cow. That would be interesting to try with 1D C footage. Stutters in Premiere but fine in FCPX or when converted to Prores. Link to comment Share on other sites More sharing options...
hmcindie Posted April 26, 2013 Share Posted April 26, 2013 That solution is for the older versions. CS6 should work properly already. Apparently the OP noticed this (why were you rewrapping them into .mov anyway?) Link to comment Share on other sites More sharing options...
pietz Posted April 29, 2013 Author Share Posted April 29, 2013 as i said i thought it would improve performance since MOV files were invented by apple (i hope thats not wrong) and MTS as a little weird to play with. also preview doesnt support MTS files for playback which is a bummer. and as i also said: im on cs6 and i still got the stutter bug with MOV files. as for my testings the "bug" is still there. Link to comment Share on other sites More sharing options...
Walter H Posted July 15, 2013 Share Posted July 15, 2013 I have switched to CS6 from FCPX in recent weeks and I am generaly pleased. I however also developed a stuttering with the 50mb mov files from my GH3. (I have a CUDA enabled GTX 660, 3770k, 16 gb RAM, ssd, raid for scratch disks, etc.) I wish the renaming to mpg would have worked but it did not. Transcoding to 442 via MPEG Streamclip has been my fix. Downside is the resulting larger files. Curious that others have no troubles with their GH3 files. Leaves me scratching my head... Link to comment Share on other sites More sharing options...
Peter Rzazewski Posted January 31, 2014 Share Posted January 31, 2014 I had a nightmare of a problem last night with stuttering footage on pans and dolly shots in premiere pro cs6. The culprit after about an hour of trial and error export settings, filters removed, etc, etc: footage speed. That is, at some point the client asked if I could speed up the entire video by 20% so I selected all the clips, right clicked, and chose speed duration and entered 120%. When I set the footage back to 100%, the footage was no longer stuttering in playback preview nor in the final export. Just throwing it out there in case anyone else is struggling. keywords: stuttering, jittery, choppy, premiere pro Link to comment Share on other sites More sharing options...
