Chooboo Posted May 26, 2017 Share Posted May 26, 2017 Hi Guys, Got my Panasonic GH5 and im very happy with it but came across this quirk the other day. When setting it to MP4 LPCM mode and selecting 8Bit 4K at 25fps (PAL) for some reason the camera goes into MF mode only? I can't select AFC or AFS/AFF even when using the focus lever just stays if MF mode. Is this something that can be turned off? or just a feature of the camera? At first I thought it was a 4K thing whereby the camera couldn't handle it but when switching to 10bit 4K is seems to enabled just fine?!?! I dont know if im missing something or if its a qurik of the system of the camera is broken? Any light on the subject would be most welcome, or would be good to compare notes with other GH5 users. many thanks Chooboo Link to comment Share on other sites More sharing options...
Chooboo Posted May 26, 2017 Author Share Posted May 26, 2017 UPDATE:: Solved my own problem, for some reason it forces MF on certain video codec setups when variable framerate option is selected in the menu even when you are at the stock FPS, how bizarre, but there we go, mystery solved ;-) Link to comment Share on other sites More sharing options...
Orangenz Posted May 27, 2017 Share Posted May 27, 2017 18 hours ago, Chooboo said: Hi Guys, Got my Panasonic GH5 and im very happy with it but came across this quirk the other day. When setting it to MP4 LPCM mode and selecting 8Bit 4K at 25fps (PAL) for some reason the camera goes into MF mode only? I can't select AFC or AFS/AFF even when using the focus lever just stays if MF mode. Is this something that can be turned off? or just a feature of the camera? At first I thought it was a 4K thing whereby the camera couldn't handle it but when switching to 10bit 4K is seems to enabled just fine?!?! I dont know if im missing something or if its a qurik of the system of the camera is broken? Any light on the subject would be most welcome, or would be good to compare notes with other GH5 users. many thanks Chooboo Does your lens have a MF switch? Link to comment Share on other sites More sharing options...
