ronjbase Posted April 12, 2013 Share Posted April 12, 2013 FCP7 won't let me open a file that is Media Manage from my GH3 videos. It gives me the sequence, all the files like normal. When I try to open the video I get General Error and when I hit the OK button I get out of memory. Please help. Link to comment Share on other sites More sharing options...
Axel Posted April 12, 2013 Share Posted April 12, 2013 I don't know. A possible explanation: 1. You shot "movs" with the GH3, which are Quicktime films, but nonetheless mpeg4 (as H.264, the same codec as AVCHD). 2. You created a log bin and imported those clips, using ⌘i (indicator: There is a log bin, but the clip names don't look logged). 3. The clips played back, and, since they are 'All-I', they played comparatively smoothly for a 32-bit player restricted to the use of 2,5 GB memory. 4. Perhaps not all clips are 'All-I' or perhaps 'All-I' mpeg4 is still more annoying for such an old software than DV, HDV or ProRes. 5. Then of course, opening a whole sequence with those problematic clips could overcharge the program. Again, I don't know what actually happened, but within the past few years, even with complex projects, I didn't experience problems of this kind. I always used ProRes, ingesting my footage after qualifying it, logging it in the Log&Capture resp. Log&Transfer window. I mixed Ex from the Sony EX3 with HDV from my XH A1 (I think it's G1 in America) with movs from my 7D - all transcoded to ProRes. I imported only what I intended to use, I sorted it, I renamed it. Perhaps you did this too. Then I can't explain it. If you imported original clips, the ProRes solution is your answer. Link to comment Share on other sites More sharing options...
